Old 01-15-2018, 11:29 PM   #1
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Oil Cooler FI
I was planning on hitting the track next season which means I'll need an oil cooler for sure. Currently I'm running an AVO turbo kit, and so I was wondering if mounting an oil cooler directly in front of the intercooler would have any adverse affect on the intercooler performing its job. Would I see a noticeable difference in charge air temperatures?
Also I was considering the Maximal Performance oil cooler which runs a 13 row Setrab core, similar to Perrin's. I've been reading around the forums and have heard some people saying the 13 row Setrab unit was enough cooling for FI on the track, while others are saying it's not enough. What oil coolers are you FI guys running on the track? I live in Washington so track day temperatures typically reach at most 90F.
tyler_win_photo is offline   Reply With Quote
Old 01-16-2018, 09:36 AM   #2
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
I know that someone with an edelbrock kit noticed an increase of IAT when having the oil cooler directly in front of his LTR. Being an air to water setup, is not sure how much it will effect air to air, but it is noticeable. Jackson racing places their oil coolers behind the intercooler, for what its worth. I think if you leave adequate space between the intercooler and oil cooler, along with keep your air flow foam piece in place, you should be okay. Probably an increase of IAT, but nothing to worry much about.
Barefootdan is offline   Reply With Quote
The Following User Says Thank You to Barefootdan For This Useful Post:
tyler_win_photo (01-16-2018)
Old 01-16-2018, 11:11 AM   #3
CSG Mike
CSG Mike's Avatar
A 13 row Setrab is not enough, if you're a decently fast driver.
Old 01-16-2018, 02:13 PM   #4
sw20kosh
Drives: 2013 Black FR-S
Dual series 9 setrab 25 row cores (I have since determined that dual series 6 cores may be sufficient and would fit with a bumper crash beam).
Harrop Supercharger 15 psi.
Series 6 13 row will definitely not be enough unless you are a beginner. As you get faster, you will outgrow it fast.
Placing it in front of the intercooler will super heat the intercooler core. The oil cooler sheds a ton of heat and it will go directly into anything behind it. I would recommend placing your oil cooler/coolers in the side vents.
The Following 8 Users Say Thank You to sw20kosh For This Useful Post:
byun (01-16-2018), CSG Mike (01-16-2018), gtengr (01-17-2018), mkivsoopra (01-16-2018), Surok (01-17-2018), Tristor (10-11-2018), Trueweltall (01-17-2018), tyler_win_photo (01-16-2018)
Old 01-16-2018, 05:52 PM   #5
-Phil
Drives: Rb25 neo brz
What are you doing for brake ducting if any?
-Phil
-Phil is offline   Reply With Quote
Old 01-16-2018, 06:01 PM   #6
sw20kosh
-Phil
Nothing. The Brembo Club Race kit with the large brake rotor is holding up fine.
The Following User Says Thank You to sw20kosh For This Useful Post:
byun (01-16-2018)
Old 01-16-2018, 09:27 PM   #7
tyler_win_photo
Would you recommend ducting or opening up the side marker hole for airflow to the cooler or would it be adequate as is
Old 01-16-2018, 09:28 PM   #8
tyler_win_photo
How about a Mishimoto 19 row? Or what other units would you recommend?
Old 01-16-2018, 10:15 PM   #9
CSG Mike
CSG Mike's Avatar
Your AVO kit precludes you from using any off-the-shelf oil cooler, except the AVO oil cooler. Sorry, but you gotta build your own, or modify one to work for you, if you want to go a different route.
PM me to order the AVO oil cooler.
Old 01-16-2018, 10:48 PM   #10
tyler_win_photo
Wait why is that?
Old 01-17-2018, 12:04 AM   #11
CSG Mike
CSG Mike's Avatar
Wait why is that?
You have an intercooler in the way; it occupies the space most oil coolers want to also occupy.
Old 01-17-2018, 01:38 PM   #12
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Just wondering, since I've been planning on going with that exact core, how did you mount your cores?
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 01-17-2018, 01:58 PM   #13
sw20kosh
Yes I have both coolers as well as the radiator completely sealed off with ducting to to their respective bumper openings. The heat shed by the cores flows through the space under the headlights, into the engine bay, and out the hood vents. Highly recommend hood vents especially on a FI setup to release the high pressure that builds up and pull air through all the cores.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
Tristor (10-11-2018), tyler_win_photo (01-17-2018)
Old 01-17-2018, 02:32 PM   #14
sw20kosh
L brackets to mounting points on chassis and AC condenser brackets.
Luftwaffel (01-17-2018)
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler TheMedakaBox Northern California 4 08-09-2017 10:16 PM
Oil cooler mynameis940 Engine, Exhaust, Bolt-Ons 9 05-12-2017 11:38 PM
WTB: FBM Oil Cooler Kit asnatlas Want-To-Buy Requests 0 10-07-2015 12:36 AM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
