#323 | |
Drives: GT86
I can buy only Mfactory things because they are in Europe or pay big extra. |
#324 | |
#325 |
Drives: 2016 FR-S
What is shock loading and how is it managed with suspension tweaks?
#326 | |
Another example is to not drive with TCS/VSA on. If VSA activates, it's grabbing the brakes at a rear wheel, which is a large shock load to the diff, which is already working to try to prevent wheel spin. This can result in differential failure. |
#327 |
Drives: Evo X FE/FRS 10 Series
Thinking I should do diff and shorter ring gear next!
#328 |
#329 |
Drives: 2016 FR-S
Then there is that slippery slope of contemplating an LSD "while you are there"
![]() That's my dilemma. Stay NA and do 4.56 rear gears or go JRSC which will make me want an LSD! Either way, I'm touching the diff! Pulls hair out
#330 |
Curious cat.
Drives: 86 GT base M/T - Red
Seems like a final drive gear swap would be a great thing to do along with a diff.
Boy oh boy CSG...you guys sure know how to scare the beejeezus out of my wallet.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
#331 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
I wanna see someone do a 5.1 in the AT. JUST DO IT
Sent from my A0001 using Tapatalk |
#332 |
#333 |
Drives: 2014 Toyota 86
Hey Mike.. I have been running into issues in the rear in the last couple of track days and on the street, wondering what you think/suggest.
It seems like I am spinning the rear inside tire under acceleration. When exiting the apex and unwinding the steering wheel while beginning to apply power i get this feeling of traction then all of a sudden i feel the RPMs jump up and what feels like the inside tire spinning even though i dont feel the car lift/tripod. It seems to happy mainly on the tigher lower speed stuff top of 2nd beginning of 3rd. Specially through a tight chicane on our local track while accelerating through it.. I have made some adjustments to the compression in the front and increased rebound alightly upfront. I have tried to reduce rebound in the rear incase the rear shock is not opening fast enough on transitions causing this issue but no hope. What changes do u suggest front/rear.. P.S a few track days ago I had done 35 mins of hot laps.. untill i felt the rear diff acting up.. when i entered the pits it was really really clunks and making loud bangs.. as usual i change rear diff fluid every 2-3 track days and run motul which helps it feel normal again. Could i have caused damage to oem torsen? |
#334 |
Drives: Subaru BRZ
bumping old thread
for those using os giken or cusco 1.5 way, did you just install straight into the diff or had it disassembled to adjust the clamping force? i've read that over-the-shelf setting is usually tuned for drifting and so adjustment is needed for grip driving. |
#335 | |
#336 |
Drives: Subaru BRZ
With regards to OS Giken Superlock, I've found two part# "TY421-HA" and "D-TC1FA20-S". How do they differ, if any?
| Tags |
| uberstupid |
| High-G Cornering Fueling Solution | EAGLE5 | Tracking / Autocross / HPDE / Drifting | 24 | 02-22-2017 08:04 PM |
| cornering-on-rails feeling | notout86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 09-20-2015 07:00 PM |
| Engine cutting power after hard cornering... | CSG Mike | Tracking / Autocross / HPDE / Drifting | 19 | 07-04-2015 08:40 AM |
| Traction control light comes even when not hard cornering? | Yamajee | Issues | Warranty | Recalls / TSB | 26 | 04-10-2014 01:04 PM |
| Anyone have the radio switching modes during hard cornering?? | silvercar | CANADA | 4 | 07-08-2013 12:49 PM |
