Old 08-13-2015, 01:53 AM   #323
GT86_PRAGUE
Drives: GT86
Originally Posted by CSG David View Post
Generally "helical" means "Torsen". Clutch-types are more predictable and consistent. If you would like a more custom setup, please let us know.
I would like to have your dif, but it is not gonna happen due to expensive delivery and huge import fees. In reality I would pay double what guys in US pay and thats not worth it but thanks for your offer.
I can buy only Mfactory things because they are in Europe or pay big extra.
GT86_PRAGUE is offline   Reply With Quote
Old 08-13-2015, 04:06 AM   #324
CSG David
CSG David's Avatar
The shock loading is what damages the Torsens/Helical LSDs. Suspension wise, you may need to dial that in to reduce that type of issue.
Old 08-13-2015, 08:21 PM   #325
Sleepless
Drives: 2016 FR-S
What is shock loading and how is it managed with suspension tweaks?
Sleepless is offline   Reply With Quote
Old 08-13-2015, 09:00 PM   #326
CSG Mike
CSG Mike's Avatar
In short, dial in the suspension to prevent dramatic changes in load, e.g. going from full load, to no load, to full load. An example is to prevent lifting a wheel, if possible (this isn't always possible depending on conditions).
Another example is to not drive with TCS/VSA on. If VSA activates, it's grabbing the brakes at a rear wheel, which is a large shock load to the diff, which is already working to try to prevent wheel spin. This can result in differential failure.
CSG Mike is online now   Reply With Quote
Old 08-14-2015, 12:12 PM   #327
GirlRepellent
GirlRepellent's Avatar
Drives: Evo X FE/FRS 10 Series
Thinking I should do diff and shorter ring gear next!
GirlRepellent is offline   Reply With Quote
Old 08-14-2015, 12:19 PM   #328
CSG Mike
CSG Mike's Avatar
Let us know when you're ready!
Old 08-14-2015, 12:32 PM   #329
Sleepless
Drives: 2016 FR-S
Then there is that slippery slope of contemplating an LSD "while you are there"
That's my dilemma. Stay NA and do 4.56 rear gears or go JRSC which will make me want an LSD! Either way, I'm touching the diff! Pulls hair out
Old 08-14-2015, 05:04 PM   #330
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Seems like a final drive gear swap would be a great thing to do along with a diff.
Boy oh boy CSG...you guys sure know how to scare the beejeezus out of my wallet.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 08-14-2015, 05:14 PM   #331
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
I wanna see someone do a 5.1 in the AT. JUST DO IT
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
Old 08-14-2015, 07:34 PM   #332
CSG Mike
CSG Mike's Avatar
It's been done, and I've driven it.
It makes 3rd gear almost like a MT's 3rd gear. 1st and 2nd are super short, but the gears are actually useable on track!
Old 12-19-2015, 02:41 PM   #333
wizzo
Drives: 2014 Toyota 86
Hey Mike.. I have been running into issues in the rear in the last couple of track days and on the street, wondering what you think/suggest.
It seems like I am spinning the rear inside tire under acceleration. When exiting the apex and unwinding the steering wheel while beginning to apply power i get this feeling of traction then all of a sudden i feel the RPMs jump up and what feels like the inside tire spinning even though i dont feel the car lift/tripod.
It seems to happy mainly on the tigher lower speed stuff top of 2nd beginning of 3rd. Specially through a tight chicane on our local track while accelerating through it.. I have made some adjustments to the compression in the front and increased rebound alightly upfront. I have tried to reduce rebound in the rear incase the rear shock is not opening fast enough on transitions causing this issue but no hope.
What changes do u suggest front/rear..
P.S a few track days ago I had done 35 mins of hot laps.. untill i felt the rear diff acting up.. when i entered the pits it was really really clunks and making loud bangs.. as usual i change rear diff fluid every 2-3 track days and run motul which helps it feel normal again. Could i have caused damage to oem torsen?
wizzo is offline   Reply With Quote
Old 01-17-2018, 10:23 AM   #334
n0thing
Drives: Subaru BRZ
bumping old thread
for those using os giken or cusco 1.5 way, did you just install straight into the diff or had it disassembled to adjust the clamping force? i've read that over-the-shelf setting is usually tuned for drifting and so adjustment is needed for grip driving.
n0thing is offline   Reply With Quote
Old 01-17-2018, 03:37 PM   #335
CSG Mike
CSG Mike's Avatar
Originally Posted by n0thing View Post
bumping old thread
LSDs ordered from CSG are typically custom configured to suit each driver.
Old 01-18-2018, 08:48 AM   #336
n0thing
Drives: Subaru BRZ
With regards to OS Giken Superlock, I've found two part# "TY421-HA" and "D-TC1FA20-S". How do they differ, if any?
uberstupid
High-G Cornering Fueling Solution EAGLE5 Tracking / Autocross / HPDE / Drifting 24 02-22-2017 08:04 PM
cornering-on-rails feeling notout86 Scion FR-S / Toyota 86 GT86 General Forum 38 09-20-2015 07:00 PM
Engine cutting power after hard cornering... CSG Mike Tracking / Autocross / HPDE / Drifting 19 07-04-2015 08:40 AM
Traction control light comes even when not hard cornering? Yamajee Issues | Warranty | Recalls / TSB 26 04-10-2014 01:04 PM
Anyone have the radio switching modes during hard cornering?? silvercar CANADA 4 07-08-2013 12:49 PM
