Old 01-16-2018, 11:54 PM   #43
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Originally Posted by arthur93 View Post
Don't forget us Aussies use nm and not ft lb for torque
it comes out to around 407 ft-lbs at the wheels.
Surok is offline   Reply With Quote
Old 01-17-2018, 12:13 AM   #44
arthur93
Drives: Toyota 86 GTS
Is this your daily or more of a weekend toy?
Check out my build: http://www.ft86club.com/forums/showthread.php?t=122736
Instagram: artym93
arthur93 is offline   Reply With Quote
Old 01-17-2018, 04:54 AM   #45
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
I drive it once every few weeks, if the weather is nice.
Mostly it just sits around collecting dust so I need to wash it before I drive it and then wash it again when I get back home.
I would love an indoor car cover like a supercar
Old 01-22-2018, 09:13 PM   #46
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Here are the new wheels! These are actually the first set of wheels i have ever bought new. You just cant beat RPF1 for value.
Fitted!
I went for a drive with my friends afterwards.
The Following 3 Users Say Thank You to Surok For This Useful Post:
ERA (05-28-2018), Mr.Impreza (01-23-2018), radroach (02-19-2018)
Old 01-22-2018, 10:30 PM   #47
Ghost of Akina
Ghost of Akina's Avatar
Drives: DE5 Integra Type S
Fitted!
Looks great!
"Precision without speed is empty, speed without precision, chaos."
Ghost of Akina is offline   Reply With Quote
Old 01-22-2018, 10:34 PM   #48
Ghost of Akina
450HP at the wheels at 18psi on E85.
It loves E85.
[/QUOTE]
I wish we could get E85 here in Canada!
Old 01-22-2018, 11:56 PM   #49
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
yes i suppose we are lucky in australia that we have a gas station that carries E85 in a few locations that makes it easy to run the fuel in major cities.
i am attending a trackday at SMSP on feburary the 8th. Its a very fast circuit, and you brake for turn 1 at around 240kph.
I might get some new pads before then if they can come from the USA in time.
The Following 2 Users Say Thank You to Surok For This Useful Post:
arthur93 (01-23-2018), Busybee (07-17-2018)
Old 01-23-2018, 10:52 AM   #50
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Curious to hear how you like the RS4s on the track...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 01-23-2018, 06:42 PM   #51
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
I will have a detailed report on the 9th for you. check back then.
Here is a video from the track, with a quick lap for a fast car. (not the best lap, since he slows to like 155 for the first turn, and i went through the first turn at 162 in my 86 when it was NA. )
[ame="https://www.youtube.com/watch?v=x5O-Kx55FiY"]Sydney Motorsport Park GP Circuit 1m 46.7 - YouTube[/ame]
this is the lap record for a "car"... i think i have watched a turbo ferrari F1 car do a 1:15..
[ame="https://www.youtube.com/watch?v=RYHVPsWxHWU"]Fastest Lap 2017 World Time Attack - MCA S13 Silvia 1:20.9 in 4K - YouTube[/ame]
why not.. have some old trackday videos. same track.
I dont know how to edit video, so here are the 1 minute clips from my dash cam, from back in 2013.
the cars only mods are MCA red/blue coilovers, 17x9 RPF1 AD08R, ferodo DS2500 brake pads and a kickass wheel alignment and corner balance setup.
the circuit is an expanded brabham circuit at SMSP, the laptime was i think 2:20, which is reasonable. i was happy with my performance that day, but of course i could always do better.
[ame="https://www.youtube.com/watch?v=RO_pwotAts8"]20150529 154449 E - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=MYOWjlFRnUY"]20150529 154545 E - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=-GTJ6t3Az1w"]20150529 154640 E - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=4r0xuuBFgOc"]20150529 154735 E - YouTube[/ame]
The Following User Says Thank You to Surok For This Useful Post:
Old 02-19-2018, 05:58 PM   #52
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
update: i missed a trackday this month due to an unfortunate discovery. that my DSS 600HP axle had an issue that it was not being retained by its c-clip under load.
The lovely people at DriveshaftShop have sent me a replacement inner axle to replace my naughty one.
I noticed this because the diff had a slight leak, so i replaced the whole diff too, just to be sure that i wasnt running any damaged components.
Old 03-14-2018, 10:56 PM   #53
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Here is a photo from the trackday i did last week.
I had a good evening , but it did expose some problems with the car, the axle above ^ was damaged and the rubber boot in the photo received a little cut in it during installation.
this spewed grease all over the inside of my rear left wheel and the other suspension components in the area when i was at the track. it is getting replaced today. some other issues came up like the oil cooler not being enough for sustained track action in its current location. i will have to move it over to the right side foglight and remove the foglight so it can get its own cool air. (its sitting in the middle behind the IC).
i had some issues with my clutch pedal position and also my brake calipers leaking due to some slightly loose bleed nipples.
i am heading to the track next week so i will have an updated report and maybe some new photos then
arthur93 (03-14-2018), olsonpg (03-14-2018)
Old 03-14-2018, 11:24 PM   #54
arthur93
Your car must be a bullet now around SMP. Out of curiosity, I'm heading to the Vsport twilight event on the 21st. Is that the one you are going to?
Also, how are the new RS4s. What is your opinion compared to the AD08Rs you run before. I am currently on my first set of AD08R. Been really happy on back roads. This will be its first track day.
Also, those glowing brake rotors!!! Great shot!
Instagram: artym93
The Following User Says Thank You to arthur93 For This Useful Post:
Surok (03-15-2018)
Old 03-15-2018, 08:33 PM   #55
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
i was really happy with the RS4 actually, but i never had this level of power when i was on AD08R. but any 245 that can control this car is pretty decent in my opinion. (i will however get 255 next) i was running them at 32 hot,and they were really nice. i dont run as many constant laps with the turbo unlike when i was NA, where i could run 15 laps at a time and then have time to get cranky with the tyres.
Im heading to wakefield next week sorry, not SMSP.
arthur93 (03-15-2018)
Old 05-28-2018, 12:44 AM   #56
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
SO i bought the Verus clutch fork, and pivot, i bought the fuel flap, and i am raising the compression ratio from 10:1 to 10.5:1, . retuning the motor for the same power but better off boost response and better idle etc.. should be good . using JE pistons now.
OLD pistons 10:1
new pistons 10.5:1
MattR's Tofu Runner MattR Member's Car Journals 31 08-12-2015 03:00 PM
Chicago Deliveries sieeegel Great Lakes 76 07-28-2012 12:26 AM
USA First Area 86 ichitaka05 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 07-01-2012 08:45 PM
Subaru BRZ Japanese Market Deliveries Pushed to Next Year Hachiroku BRZ First-Gen (2012+) — General Topics 88 04-16-2012 09:38 AM
Tofu-ten AE86 at Toyota History Garage Axel Other Vehicles & General Automotive Discussions 2 02-03-2010 01:21 AM
