Old 01-15-2018, 01:38 PM   #15
Submarinesonce
Drives: Frs
Can confirm, getting that ES bushing on was a massive PITA, I dropped the exhaust and driveshaft out of the way to get mine on, took every bit of force I could muster, but eventually went. lube is your friend.
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 01-15-2018, 04:29 PM   #16
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
I fussed with mine for exactly 10 minutes before I said, "be smarter than the bushing, Adrian." Some white lithium grease and an 18" pry-bar popped it right on.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
Spuds (01-17-2018)
Old 01-15-2018, 09:08 PM   #17
NRXRaptor
I also was suffering putting it on for 5 minutes. Then, because I had taken high school chemistry, I decided to soak the bushing in hot water for a few minutes. Pretty much slipped right on. EZPZ
NRXRaptor is offline   Reply With Quote
The Following User Says Thank You to NRXRaptor For This Useful Post:
Spuds (01-17-2018)
Old 01-16-2018, 06:22 PM   #18
silvarbullet
Thanks for all the feedback everyone. Just to be clear, several mentioned heat, and grease. In my original post I mentioned boiling the mount, and using lots of grease. The mount didn't have any of the brass bushings in place yet.
The MTEC springs have done wonders for the feel of the shifter, so I'm content waiting till spring to give this another go. I didn't mention this previously, but what about dropping the driveshaft out of the rear of the transmission? I removed the front pipe and went to lower the driveshaft again but saw that it was going to just slide right out of the tranny and didn't want to mess with that. I'm sure its possible that some parts are free floating in there and could also come out (very bad).
I had thought of trying to find a clamp or gear puller as Spuds mentioned, if I find a better way to do it I'll make sure to update this post.....in the spring
silvarbullet is offline   Reply With Quote
Old 01-16-2018, 07:40 PM   #19
FirstWinter
Drives: Car
If you're going to drop the driveshaft and still can't get it in then just take out the entire shifter carrier and install the bushing outside and reinstall. The driveshaft won't fall out by the way.
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
cjd (01-17-2018)
Old 01-17-2018, 07:01 AM   #20
NRXRaptor
He might be talking about the bracket thing that supports the driveshaft at its halfway point. I think it would give him more room to wiggle around and it is very easy to take out/put back in place. If I remember right, I think this car's driveshaft is bolted at the diff but slides into the transmission
Old 01-17-2018, 08:53 PM   #21
silvarbullet
The driveshaft wont slide out of the tranny? You sure? I let it move about 1" to 1.5" and it wasn't stopping. This is where the driveshaft goes into the rear of the transmission, I'm not talking about lowering the center section like they say to do in the DIY on this forum. With the driveshaft out of the way I'm 100% sure I could get it on, then I could actually get both of my meat hooks on it and just force it on.
I thought about removing the shifter carrier, but wasn't sure if what was involved in that.
Old 01-17-2018, 08:59 PM   #22
FirstWinter
Drives: Car
It might've been resting on my midpipe. It's been a while since I did it. I removed the bolts from the picture. It only slid out from the tranny a couple inches.
Edit: Looked at the process of removing the shifter carrier again and it's a pretty involved process requiring disconnecting the entire shifter. I would do this as a last resort if you can't install the shifter bushing but at that point I would probably just call it quits and have a beer lol
Old 01-17-2018, 09:55 PM   #23
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Do this. I feel dumb not having done this.
I recommend drying then applying grease in quick succession before putting it on.
Old 01-19-2018, 08:18 AM   #24
silvarbullet
Well it turns out the driveshaft will slip right out of the transmission, but thats ok. I just watched a video at FT86speedfactory about replacing your driveshaft. Just slide it out, and it can slide right back in. So I'll do that when I change my tranny fluid out with some nicer stuff. Get a two-fer.
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 10:57 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 02:41 AM
Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing swansons Issues | Warranty | Recalls / TSB 4 02-02-2014 03:27 PM
Shifter Bushing Vlady Want-To-Buy Requests 1 10-29-2013 06:39 PM
Whiteline transmission bushing and Perrin shifter bushing review. Superhatch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-09-2012 09:40 PM
