#15 |
in the recliner of rage
Drives: Asphalt FR-S
While lateral traction increases with additional load on a tire, it does not increase at a linear rate. As an example, if your front outside tire has 1000lbs of load on them from weight transfer in a turn on flat asphalt, and this produces 900lbs of lateral traction as determined by the tire's characteristics, this would result in a maximum lateral force of .9g before they lose grip. When you turn in while heading downhill, even more weight is transferred to the front outside tire, so it now has 1200lbs of load, but this may only produce 975lbs of lateral traction, which now limits you to a maximum lateral force of .8g in the turn before they lose grip. So you're right, traction does increase with additional weight transferred onto a tire, but not at the same rate, which is why the maximum lateral force the tire can produce actually decreases when turning in downhill.
| The Following User Says Thank You to Resolute For This Useful Post: | nico_rsx (01-15-2018) |
#16 | |
Drives: 2017 BRZ WR Blue
#17 |
Drives: unlimited cheap build N/A track car
Yes, I thought that's what I just said. Understeer on downhill turns and oversteer on uphill turns. Exceeding the tires static coefficient of friction. Same as the OP. I don't know of a way to setup the car to lessen this effect. Im not sure there is a way.
#18 | |
#19 |
Drives: '13 Whiteout
#20 |
#21 | |
Drives: BRZ 2017 Pure Red, MT
Thanks for taking the time to explain what actually happens. |
| Understeer after new wheels | carsebuco | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 12-04-2017 05:49 PM |
| understeer on 17 brz | alex.s | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 37 | 09-11-2017 04:05 AM |
| Not understeer, not oversteer... something else? | Mazikowski | Tracking / Autocross / HPDE / Drifting | 15 | 07-25-2016 09:24 PM |
| Do pigs understeer? | Thrustin | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 05-31-2014 09:42 AM |
| 03/23 Reviews --> No understeer complaints... | bloomy116 | BRZ First-Gen (2012+) — General Topics | 19 | 03-26-2012 11:06 AM |
