Old 07-07-2012, 12:00 PM   #71
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by MRZ415 View Post
I vaguely remember reading somewhere that the Spark Plugs on the new FA
engine on the BRZ only requires removal of both front wheels and wheel wells to
gain access.
(( I am probably totally wrong on this and that is probably why I am ONLY going
to attempt basic oil changes on my own and leaving spark plug change to PROS))
That was the original report.
However, I've looked down at the frame rails in my BRZ and there are no access ports. So it's business as usual for a Subaru plug change.
The thing is, I was thinking about this, and without taking a look under the panels beneath the car, lifting the engine might not be all that difficult. Without front axles to content with, it might just be a matter of two or four nuts and jacking it up.
Old 07-07-2012, 11:36 PM   #72
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Originally Posted by BMWDavid View Post
Well that might be a bit harsh and I fully understand your position. I was just a bit disapointed to see what a PITA it would be.
Kind of reminds me of the Porsche 964 and 993 with their dual plugged heads. The lower set of plugs required the removal of the mufflers and many of them never have had their lower plugs changed.
Try changing all eight of the sparkplugs in two 2003 E-350 vans.... twice.
I've never swore more in my life nor gotten as filthy working on a car.
IMO the opportunity to pull and engine and do some freshening is a good thing as long as you research it ahead of time, make sure you have the right tools, and plan ahead.
Chewie4299 is offline   Reply With Quote
Old 07-08-2012, 01:19 AM   #73
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I'm not worried about it. I will plan on adjusting the valves and replacing the valve cover gaskets at the same time.
Old 07-08-2012, 09:12 AM   #74
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
No valve adjustment needed. Self adjusting valves here.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 08-15-2012, 03:21 PM   #75
w4yn
Drives: Mazdaspeed Miata now
Changing Plugs
We have gotten lazy, I am old I know but in 60's plugs and points only lasted months not years!
I too looked at engine and told saleman the plugs were going to be a bitch but my 05 Mazdaspeed only has 14K on it so I probably will not live long enough to change plugs in FRS!
Tim
w4yn is offline   Reply With Quote
Old 09-05-2012, 08:45 PM   #76
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
has anyone attempted it yet just to see if they can even get a wrench in there? i am sure there is a way with the right extension and swivel socket...
driftartist is offline   Reply With Quote
Old 09-05-2012, 09:36 PM   #77
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
The problem isn't getting a wrench in there it's getting the coils out. No way to get the coils out with out dropping/raising the engine.
Touge Monster is offline   Reply With Quote
The Following User Says Thank You to Touge Monster For This Useful Post:
jcw99 (02-06-2015)
Old 09-05-2012, 09:40 PM   #78
driftartist
Kurenai Samurai
oh...sorry, super newb to boxers let alone this engine. thank you for your answer
Old 08-06-2013, 10:26 PM   #79
swift996
swift996's Avatar
Sucks for people running FI
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 08-06-2013, 10:34 PM   #80
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It really isn't that bad. Took me 2 to 3 hours in my driveway to raise the motor up and take a look at my plugs
Old 08-06-2013, 10:51 PM   #81
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Do a DIY bro
Old 08-06-2013, 10:52 PM   #82
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Tell me about it
Old 02-06-2015, 07:24 PM   #83
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
60K change per the car's schedule maintenance book.
I had the dealership look into replacing my spark plugs today because I'm at 51k miles and have a road trip across the continent coming up, so thought it a good idea to get everything checked on. Got quoted $450 because it's just labor intensive. Will still probably have them do it before I go.
Old 02-06-2015, 09:12 PM   #84
CoupedUpSubie
Drives: 2013 BRZ Limited
Thats probably 5 hours plus parts and misc charges. Not that bad actually, they are probably just estimating that because it isn't something they have done a lot of. I'd probably give a similar estimate if I was running a shop.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
The Following User Says Thank You to CoupedUpSubie For This Useful Post:
chanomatik (02-10-2015)
Subaru or Toyota drain plug? yayforaddison Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 05-06-2020 11:59 PM
Exhaust tip removal Draco-REX Cosmetic Modification (Interior/Exterior/Lighting) 97 05-27-2017 06:50 PM
Scratch Removal? feldy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 05-15-2014 11:12 PM
Spark plug type and heat ft86-UAE Engine, Exhaust, Transmission 4 06-10-2012 11:21 AM
What do you wish was changed about the brz/frs? GirlyScions BRZ First-Gen (2012+) — General Topics 16 06-04-2012 04:26 AM
