#141 | |
Drives: 2018 Cayman, 2013 FR-S
Another question that I couldn't find a clear answer to on Arkon's site: can the mount be removed from the arm and swapped for a different one? I rather like their Mobile Grip 2. |
#142 | |
#143 |
Drives: 2017 BRZ
I'm using the iOttie Easy One Touch 3 (https://www.amazon.com/gp/product/B01BZC262Q/).
The way I have it mounted, it gets in the way of the passenger seat being able to move all the way forward to access the rear "seat," but it's not like the rear seat is actually used for anything so I don't really care. I used the included dash pad to mount it and haven't had any issues in 6 months or so of use. Also gives me a nice place to hang my usb cord when I'm not using that. It also just barely gets in the way of the shifter going in and out of park, but isn't otherwise in the way of the shifter and is easy to work around once you adjust your grip to it being there. I don't know how this would work out with a manual though, might end up being in the way for some shifts. I like it because it doesn't require any modification to the interior of the car to install and it doesn't use a magnet on the phone case, which I've always been a bit hesitant to use. |
| The Following User Says Thank You to Brink For This Useful Post: | neilr (01-09-2018) |
#144 |
Is that the sticky pad? I've had poor luck with sticky suction cups and textured surfaces (they always fall off within 15 minutes), though I haven't tried the side of the tunnel. Thanks for another idea to try.
#145 |
Drives: 2017 BRZ
Yeah that's the sticky pad. The whole thing is at the limit of its adjustment range to get it positioned properly but it works. Hasn't fallen off yet, and just last week I did a ~120 mile round trip drive with my phone (iPhone 6s in an otterbox defender case) in it for the whole trip, parts of the drive on rough highway.
#146 |
I installed the iOttie earlier today. Seems to hold on much better than similar sticky mounts that I have around. Here's hoping it lasts. :-)
#147 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Here you go.
#148 |
Drives: 13' FRS
Here is what happened to my Scosche Magic Mount after a week. Doesn't seem to like the 90 + degree weather on the east coast... looking to make a mount similar to Beat sonic qbf13 or one similar to what extrashaky made, thanks for the idea
#149 |
Drives: Scion FRS 2016
Custom holder with magnet
This is my solution for older FRS/BRZ with split front pannel.
I wanted to use magnet mount but without any glue. I used Beat-Sonic QBF13 idea. It was simple to make. I bought magnet mount $21 CAN: https://www.amazon.ca/Magnetic-Phone...017KXRLSS?th=1 I have removed 3M sticking pad from it and it exposed screw so you can disconnect metal ball and plastic base. I also bough Staples® Stainless Steel/Cork Base Rulers 15 cm for $1.35CAN https://www.staples.ca/en/Staples-St...6_1-CA_1_20001 I also got 2 metal bars (8mm) from homedepot to do my bent which I have returned after. Steps to do: 1) bent around 8mm steel bar to create proper shape. 2) Use dremel to round short side to much magnet base 3) Drill hole for to screw in magnet. Carefull make sure that mounting hole small enough for screw to hold. Second hole I made bigger to pass screwdriver trough. 4) First I spray painted it, but it did not look good. (have not waited enough). So I used blackout tape. looked much better. 5) Screw base with ball to bent ruler. Ruller has cork inside, so it protects panel finish. Attach as Beat-Sonic QBF13https://www.youtube.com/watch?v=TDiRa--o_5o This is final result and few steps in between. Took about 45 minutes if you remove failed painting steps and time to plan it. Works very well, holds my Note 4. Phone rotates a bit, so bottom of the phone touching panel, but it is in perfect position. Last edited by Lim; 09-11-2018 at 01:08 PM. Reason: NEw picture |
#150 | |
Drives: 2015 Scion FRS Release Series 1.0
I did it too! Thanks for the help
1. My primary goal was to make something that can hold the phone during any track day, when oil temps and coolant temps are most necessary to view. Any suction or vent clip holder will not work, the iPhone XR + case is too heavy. 2. I also used the seamer from HF (Thank you!!) but a found a vice grip and a hammer helped too. If you have a drill attachment that lets you tighten the bolt from an angle (i forgot the name of it) then you don't need to drill an extra hole on the phone holder surface. 3. For this to work, the phone holder has to have a flat back. I found the MPow brand makes a perfectly flat back, minus the middle piece. i used a dremel and file to sand that flat. then i used 3M double sided tape. 4. The store I went to only has 22 gauge metal. After completing it, I would've liked to use 18 gauge. It's slightly bendy n hard bumps, but not a problem. 5. I used a truck bed paint to give it one coat for a texted finish. I found flat black showed too much of my sanding and dremel work. 6. I would recommend using the edge of a hard surface, and a hammer to enunciate any metal bends you make. |
| The Following 4 Users Say Thank You to ozafar For This Useful Post: |
#151 |
Drives: 2014 BRZ Limited
#152 |
Drives: 2019 BRZ Sport-Tech RS
Scosche adhesive mount with the flexible foot. It doesn't make perfect contact here as you can see the back lifting up. But it's been holding for almost a year.
| The Following 2 Users Say Thank You to N_Raged For This Useful Post: | soundman98 (05-11-2020), wolffbite (05-12-2020) |
#153 |
Drives: 2016 Scion FRS Asphalt
Berrolia Vent Dock with a 3D printed clip mount
#154 | |
I've resorted to a vent mount off amazon until I can DIY something like ozafar did. |
| Phone holder | Tim_Asphalt_FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 79 | 04-02-2016 03:28 PM |
| Is it possible to use a phone as a BRZ key? | Killianti | Electronics | Audio | NAV | Infotainment | 19 | 08-13-2014 04:55 PM |
| Window weld motor mounts (poor man's solid mounts) | unsurety | Engine, Exhaust, Transmission | 8 | 06-05-2014 02:36 AM |
| Let's talk phone mounts | l0aded | Electronics | Audio | NAV | Infotainment | 41 | 06-14-2013 12:53 PM |
| Phone app. | DanoFA20 | Site Announcements / Questions / Issues | 6 | 10-22-2012 11:55 PM |
