Old 01-02-2018, 01:56 AM   #1
noonedoesnt
Drives: 2016 Toyota 86 GTS - Manual
Unhappy Clunk noise when turning steering wheel to right
Hi, I've been getting a clunk noise when I turn the steering wheel to the right. It happens always at a certain point from the neutral position of the steering wheel when turning clockwise.
It makes a sound like the following video:
[ame="https://www.youtube.com/watch?v=Snrb-OOuR9o"]steering clunk noise - YouTube[/ame]
Check video at:
- 0:44
- 1:32
Only happens when turning it right. Any ideas?
Regards
noonedoesnt is offline   Reply With Quote
Old 01-02-2018, 04:41 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
What mods have you done suspension wise recently?
If so something is not tighten down properly.
Most common issues are top strut not loose, bad endlink, steering rack bushing/mounts. And swaybar mounts.
Old 01-02-2018, 12:19 PM   #3
stevesnj
stevesnj's Avatar
Check
Lug nuts torqued correctly
Caliper bolts
front axle shafts and CV joints
Tie rod ends
Strut mount bolts
My 2016 Build thread
Old 01-02-2018, 08:51 PM   #4
noonedoesnt
Suspension is fully stock, only mod is full exhaust.
Old 01-03-2018, 08:49 PM   #5
noonedoesnt
bump
Old 01-03-2018, 09:26 PM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Tc.
Old 01-03-2018, 10:25 PM   #7
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
sway bar end links? I don't know anything about tCs.
dowroa is offline   Reply With Quote
The Following User Says Thank You to dowroa For This Useful Post:
sato (07-04-2018)
Old 01-03-2018, 11:41 PM   #8
Tc.
I think the OP was just using someone else's video to demonstrate the sound ....
Old 01-03-2018, 11:43 PM   #9
Originally Posted by noonedoesnt View Post
bump
Well, several suggested possible sources of that sound have been posted.
Have you investigated them .. ??
If so, what were your findings ...??
Old 01-04-2018, 02:15 AM   #10
noonedoesnt
I should've been clearer, yes I inspected with the best of my knowledge and r seemed fine. The car only has 12,000km.
Old 01-04-2018, 02:15 AM   #11
noonedoesnt
Tc.
It's someone else's video, same sound that my 86 makes.
Old 01-04-2018, 02:26 AM   #12
Well, if you have checked those possibilities listed above, to the best of your abilities, and didn't see of feel anything lose or broken, I reckon its time to take the car into a shop.
If it's still under warranty, I'd suggest you take it to the dealer.
Personally, I would take it into an automotive shop where I knew the folks and ask them to do a complete suspension and front end inspection and check the tires and the brakes and check the alignment.
I hope you get it figured out ....... keep us posted ....
Old 02-01-2018, 12:44 AM   #13
noonedoesnt
Bump. Got the car serviced, turns out the noise was due to a faulty strut mount.
The Following User Says Thank You to noonedoesnt For This Useful Post:
stevesnj (02-01-2018)
Old 02-01-2018, 02:36 AM   #14
Yaaaaa........... @stevesnj 's shotgun blast hit it .........
Glad you got it fixed, OP .....
Creaking from front end when turning steering wheel finch1750 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 12-05-2015 03:21 AM
Noise when turning steering wheel at low speed Slant Issues | Warranty | Recalls / TSB 7 11-06-2015 08:53 AM
Clunk noise at 24mph only once... Mikem53 Scion FR-S / Toyota 86 GT86 General Forum 0 10-27-2014 05:22 PM
Squeaking Noise From Steering Wheel tonytduc Scion FR-S / Toyota 86 GT86 General Forum 4 01-28-2013 07:58 PM
buzzing noise from steering wheel FR-S :DK Scion FR-S / Toyota 86 GT86 General Forum 1 10-07-2012 01:52 AM
