Old 01-02-2018, 11:26 PM   #38165
Originally Posted by cjd View Post
No kidding. Only boats move by rowing. Or does that also apply to a sideways column of vehicles too...? Now I'm not sure.
Started strong but...
Ultramaroon is offline
Old 01-02-2018, 11:31 PM   #38166
In case you missed it, this is funny ......
humfrz is offline
Ultramaroon (01-02-2018)
Old 01-02-2018, 11:38 PM   #38167
I got an echo dot as a gift... Not sure what to do with it.
My daughter got a kick out of it when she asked which My Little Pony is her favorite though.
See post #38170 .....maybe you should have gotten the silver version .....
humfrz is offline
Old 01-02-2018, 11:58 PM   #38168
Cole
Not a troll
Cole's Avatar
Hmmm, have decided to try LED bulbs for the headlights. Can't wait to see the results
Cole is offline
Old 01-03-2018, 12:07 AM   #38169
Well, hell yes, Cole, it's a new year ..... time to change SOMETHING ........
humfrz is offline
Old 01-03-2018, 12:10 AM   #38170
Cole
Not a troll
Cole's Avatar
For thirty bucks, can't go wrong. Worst case, they're garbage and I sell them to someone for 20.
Cole is offline
Old 01-03-2018, 12:22 AM   #38171
Without considering time and effort that's still ten bucks of wrong.
You could buy someone else's used wrong for 20 and break even when you sell.
Cole (01-03-2018)
Old 01-03-2018, 01:02 AM   #38172
Oh, maybe we should let ol @Cole go ahead ........ $30 is cheaper than a $1,000 new phone .....
humfrz is offline
Old 01-03-2018, 01:21 AM   #38173
Cole
Not a troll
Cole's Avatar
It'll be 10 dollars of entertainment for a lonely, bored guy who doesn't need to go to work until april.
That ten dollars will cover the joy of receiving the pack, unboxing, install and testing
Cole is offline
The Following 2 Users Say Thank You to Cole For This Useful Post:
humfrz (01-03-2018), Ultramaroon (01-03-2018)
Old 01-03-2018, 01:29 AM   #38174
I blew a lot of money on dumb stuff in my 20s.
Old 01-03-2018, 02:45 AM   #38175
You go poor boy ...........
humfrz is offline
Cole (01-03-2018)
Old 01-03-2018, 02:53 AM   #38176
Ya, I hear that ......
Considering I made a dollar an hour working at hard labor, I reckon I spent a bunch of money from the JC Whitney catalog on car do dad things .......
I WILL learn to fly this damn 4 prop, plastic, battery powered thing ...... or I will destroy it trying to learn.......
nite pops
humfrz - ZZZZZZ
humfrz is offline
Old 01-03-2018, 06:37 AM   #38177
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
Originally Posted by x808drifter View Post
Anyone ever notice that the alphabet doesn't "need" to be in any particular order?
or that we don't need the letters "s" and "k" because "c" makes both sounds.
echo419 is offline
The Following 2 Users Say Thank You to echo419 For This Useful Post:
Spuds (01-03-2018), x808drifter (01-03-2018)
Old 01-03-2018, 08:33 AM   #38178
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
This should help with your run of the mill mini quadcopter. If yours has multiple stability modes, put it into the most stable for learning.
The trick is to start with just the throttle. Go to the most wide open room you have and place it in the center. Get it hovering about a foot off the ground, then gently put it down. Then repeat. It will likely move laterally a bit, but that's fine. If there are trim controls, you can try to balance it out.
Next add in rotation. Hover a foot over the ground and then rotate 90 degrees. Then another 90 degrees. Repeat in both directions.
Next, add in a small bit of forward motion. Might want to just add some trim to make it go without using the right stick if possible. Use your hover and rotation skills to keep it from hitting anything. Once you have that down, use the stick to increase speed a bit. At this point you are likely to start crashing more since you need to modulate the throttle at the same time. Master this and you are 80% there. Keep increasing speed as you get better.
Lastly, when you start zipping around the room, you will notice that rotation just isn't cutting it for the turns you have to make. That's where you add in roll. Same motions as before, but when turning, add just a pinch of roll to keep it in line. You will need a bit more throttle to make it without losing altitude so expect to crash when adding roll in.
Spuds is offline
The Following 3 Users Say Thank You to Spuds For This Useful Post:
Dadhawk (01-03-2018), humfrz (01-03-2018), Ultramaroon (01-03-2018)
