#38011 |
Drive From Home
Drives: BRZ STI Performance
#38012 | |
Drives: 2017 BRZ
Can you get the ARP studs? Stock length. Might be better than anti seize, which could lead to stretched/snapped lugs at factory torque values.
| The Following 3 Users Say Thank You to cjd For This Useful Post: |
#38013 |
Not a troll
Amazing that a small-town hardware store had exactly the bolts and nuts (had to get 3/8 washers instead of 1.25, but that's fine). Now I need to find enough wood to pile under my front wheels to be able to get to the header/op joint.
#38014 | |
Drives: frs
Anti seize works so far, i apply them with a Q-tips so doesnt get rust fast. I will rotate tires every 3k miles to see |
| The Following User Says Thank You to Teseo For This Useful Post: | cjd (12-31-2017) |
#38015 |
Drive From Home
Whatsapp is dead bitches!!!
#38016 |
Drives: frs
#38017 | |
Over the past 70 years, I have taken and put on maybe thousands of wheels on tractors, hay wagons, trucks and cars and never used anti-seize or a torque wrench and NEVER had a stud snap off, or a lug nut that I couldn't get off. Nope, never had a wheel fall off either. ![]() humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | cjd (12-31-2017), Ultramaroon (12-31-2017) |
#38018 |
Add me to the confused column. Not once, ever, have I buggered a wheel lug. And yes, I remove and reinstall my wheels regularly.
Not saying others are doing something wrong. It's just a real head scratcher.
#38019 |
Where's that picture of the guy welding under his propped-up truck?
#38020 |
Drives: 2017 BRZ
Yeah, that's my theory. I should note I don't really drive the car in the winter either, so not a whole lot of the salt and garbage they put on the roads possibly getting into the works either. But it seems to be some type of chemical issue that's really the problem, not inherently weak studs. Then again, I hear noise that other Subarus also have stud issues...
Watch, I'll snap a whole mess of studs in the spring when I start working on the car now (I think about 324 miles on it...)
| The Following User Says Thank You to cjd For This Useful Post: | humfrz (12-31-2017) |
#38021 | |
Drives: frs
| The Following 2 Users Say Thank You to Teseo For This Useful Post: | humfrz (12-31-2017), Ultramaroon (12-31-2017) |
#38022 |
You're also on the ocean. I learned when I lived on Guam, how quickly everything rusts in salt air.
#38023 | |
![]() humfrz |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#38024 | |
![]() That's "lug nut tight". humfrz |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 10:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
