#99 |
Drives: 2013 BRZ Limited
| The Following User Says Thank You to Swoldier86 For This Useful Post: | Ultramaroon (12-29-2017) |
#100 | |
B) Do these in the following order: 1. Lift up and push to floor very slowly. Does clutch fully disengage? Can you get it in and out of gear? 2. Leave it pushed to the floor. Does it gradually bleed down so you can no longer get in and out of gear? Just keep shifting in and out. 3. Lift up and push all the way quickly. Does it make a difference? Humor me here. I want to make sure we are exactly on the same page.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Swoldier86 (12-29-2017) |
#101 | |
I will test these as soon a so get to my car (currently at the gym). Just to clarify when you say lift up are you meaning to raise the clutch up with my foot from underneath? Or just simply letting go of the clutch? |
#102 | |
#103 |
You had to lift all the way from the floor. I know that because I know you still have your assist spring.
#104 |
For cryen out loud ........ REPLACE SOMETHING ....... the suspense is killing me .......
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Swoldier86 (12-29-2017) |
#105 | |
2. Clutch stayed pressed to floor and could shut tinto all gears fine. 3. Lifting up and pushing quickly made no difference. Also how can I check to see if the PO removed the spring and lowered the pedal? Thanks. |
#106 | |
Oh, and you have to get onto your back and look up for the spring or its absence. Factory adjustment of the pedal is an inch or more above the brake pedal. It can be lowered to about even with the brake pedal.
#107 |
#108 |
YIKES!....... THAT is ugly ......
![]() Seriously, if you had it to do all over again, would you have replaced the TOB as a preemptive, preventative maintenance measure .. ?? If so, what would be the indicator and/or at how many miles ......?? humfrz |
#109 |
No. I had to pop it up about half an inch at the end of travel. Because the bloody TOB was catching on the shaft.
#110 |
I honestly have no clue how long it takes to sag because it has only done this a handful of times, when I am driving it works fine at stop signs red lights etc. it has worked good all day after the first issue this morning.
Now at any point when I let go of the clutch I can take my foot and pull Up and it will come up about an inch maybe after every time I press the clutch down and let go. I don’t know if normally you are supposed to be able to pull the clutch up at all. Also there is a slight noise down at the pedal when I pull up almost like it clicks into its final position. Edit: it’s actually not an inch I just looked it’s more like half an inch. |
#111 | |
shit. I gotcha. But dammit, by that point you would have felt the rumble in your foot for a long time. Right?
#112 |
| Urgent need of help | 86z | Issues | Warranty | Recalls / TSB | 6 | 11-12-2016 10:48 AM |
| Urgent help needed to identify blown engine | driftking96 | Engine, Exhaust, Transmission | 30 | 06-14-2016 10:32 PM |
| WTB: CAMSHAFTS urgent! | Ondreiko | Want-To-Buy Requests | 0 | 09-25-2014 01:17 AM |
| FS LED kits(Urgent) [WA] | GTiko | Australia Classifieds | 1 | 10-29-2012 10:43 AM |
