Old 12-29-2017, 07:31 PM   #99
Swoldier86
Swoldier86's Avatar
Drives: 2013 BRZ Limited
By clamping the hose you did the same thing the TOB bearing is doing by preventing the springs from pushing the fluid back to the master. The SPRINGS create the return pressure not the master.
Oh okay gotcha, that’s makes sense.
Swoldier86 is offline   Reply With Quote
The Following User Says Thank You to Swoldier86 For This Useful Post:
Ultramaroon (12-29-2017)
Old 12-29-2017, 07:48 PM   #100
Originally Posted by Swoldier86 View Post
There seems to be no difference between fast and slow. If I try it over and over and over it will not work fast or slow. But as soon as I move it up about an inch it works fine the next Press.
Also the mechanic said that the fluid was very brown but to me it looked only slightly yellow.
A) I am pretty sure the PO removed the assist spring and lowered the pedal.
B) Do these in the following order:
1. Lift up and push to floor very slowly. Does clutch fully disengage? Can you get it in and out of gear?
2. Leave it pushed to the floor. Does it gradually bleed down so you can no longer get in and out of gear? Just keep shifting in and out.
3. Lift up and push all the way quickly. Does it make a difference?
Humor me here. I want to make sure we are exactly on the same page.
Swoldier86 (12-29-2017)
Old 12-29-2017, 07:52 PM   #101
Swoldier86
Swoldier86's Avatar
Thanks for the replies man. Much appreciated.
I will test these as soon a so get to my car (currently at the gym).
Just to clarify when you say lift up are you meaning to raise the clutch up with my foot from underneath? Or just simply letting go of the clutch?
Old 12-29-2017, 07:59 PM   #102
Yeah. Lift up with your toe.
Old 12-29-2017, 08:01 PM   #103
I had to lift the pedal when mine went. Why I think I had to lift it is explained above.
You had to lift all the way from the floor. I know that because I know you still have your assist spring.
Old 12-29-2017, 08:13 PM   #104
For cryen out loud ........ REPLACE SOMETHING ....... the suspense is killing me .......
Old 12-29-2017, 08:14 PM   #105
Swoldier86
Swoldier86's Avatar
1. Clutch fully disengages and goes into gear fine.
2. Clutch stayed pressed to floor and could shut tinto all gears fine.
3. Lifting up and pushing quickly made no difference.
Also how can I check to see if the PO removed the spring and lowered the pedal?
Thanks.
Old 12-29-2017, 08:20 PM   #106
Thanks.
Thanks. Ok, next. How long does it take to sag on the next press?
Oh, and you have to get onto your back and look up for the spring or its absence.
Factory adjustment of the pedal is an inch or more above the brake pedal. It can be lowered to about even with the brake pedal.
Old 12-29-2017, 08:20 PM   #107
Swoldier86
Swoldier86's Avatar
Trust me it’s killing me even more lol. I just don’t want to replace a working part and waste money that I don’t have.
Old 12-29-2017, 08:21 PM   #108
This is what happens if you wait too long:
YIKES!....... THAT is ugly ......
Seriously, if you had it to do all over again, would you have replaced the TOB as a preemptive, preventative maintenance measure .. ??
If so, what would be the indicator and/or at how many miles ......??
Old 12-29-2017, 08:27 PM   #109
No. I had to pop it up about half an inch at the end of travel. Because the bloody TOB was catching on the shaft.
Old 12-29-2017, 08:29 PM   #110
Swoldier86
Swoldier86's Avatar
I honestly have no clue how long it takes to sag because it has only done this a handful of times, when I am driving it works fine at stop signs red lights etc. it has worked good all day after the first issue this morning.
Now at any point when I let go of the clutch I can take my foot and pull
Up and it will come up about an inch maybe after every time I press the clutch down and let go. I don’t know if normally you are supposed to be able to pull the clutch up at all. Also there is a slight noise down at the pedal when I pull up almost like it clicks into its final position.
Edit: it’s actually not an inch I just looked it’s more like half an inch.
Old 12-29-2017, 08:29 PM   #111
oh!
shit. I gotcha.
But dammit, by that point you would have felt the rumble in your foot for a long time. Right?
Old 12-29-2017, 08:29 PM   #112
Swoldier86
Swoldier86's Avatar
You have me so scared lol. I hate this. I just can’t afford to waste money that’s why I am trying to troubleshoot as much as possible.
Urgent need of help 86z Issues | Warranty | Recalls / TSB 6 11-12-2016 10:48 AM
Urgent help needed to identify blown engine driftking96 Engine, Exhaust, Transmission 30 06-14-2016 10:32 PM
WTB: CAMSHAFTS urgent! Ondreiko Want-To-Buy Requests 0 09-25-2014 01:17 AM
FS LED kits(Urgent) [WA] GTiko Australia Classifieds 1 10-29-2012 10:43 AM
