Old 12-29-2017, 02:31 PM   #15
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
So, I'll be 75 next month
You're younger than I thought.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 2 Users Say Thank You to 8RZ For This Useful Post:
humfrz (12-29-2017), Hyper4mance2k (12-30-2017)
Old 12-29-2017, 02:39 PM   #16
OMG ........
Do I sound THAT old .......
8RZ (01-02-2018)
Old 12-29-2017, 04:24 PM   #17
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Originally Posted by Asian View Post
I've been wanting to install an exhaust cutout to control how loud my car can be. I've run into a problem where my HKS front pipe is 60mm or 2.36in in diameter and the exhaust cutout diameter of the pipe comes in at either 2.25in or 2.5in. Could an exhaust shop be able to weld the cutout to my front pipe? Or would it be a better idea just to sell and get a 2.5in front pipe? Thanks
I had a QTP cutout installed when I did 2.5 inch from the overpipe back. The shop had a hard time finding a good spot to put it, they ended up right where the gap between the floor pan and gas tank are so they had a place for the motor to sit up out of the way.
BirdTRD is offline   Reply With Quote
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
Asian (12-30-2017), Hyper4mance2k (12-30-2017)
Old 01-03-2018, 04:33 PM   #18
2slo4u
Drives: Rare Jade Pearl dipped
My kit came with a 2.5 Y pipe. I have it installed on my front pipe before the resonator. It does hang a little low though so speed bumps may not be your friends now if your car is lowered.
2slo4u is offline   Reply With Quote
Electric Exhaust Cutout = Loud as %$#@ M-17 Engine, Exhaust, Transmission 44 05-05-2019 05:59 PM
Custom 2.5" exhaust with QTP cutout valve BirdTRD Engine, Exhaust, Transmission 0 07-04-2017 01:21 PM
Vacuum activated exhaust cutout Wil Engine, Exhaust, Transmission 0 06-27-2017 01:26 AM
muffler shop for exhaust welding/quad tips adjusts Northern California 5 06-05-2016 09:44 PM
Good affordable exhaust welding shop, Houston TX fmsida Southwest 1 10-05-2012 07:13 PM
