Old 12-27-2017, 08:48 PM   #15
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
LOL! Good one! This is not an issue! You are WAY over thinking it!
Since you only use the car to pick up Grandma and go to Church on Sunday, you may be right.
funwheeldrive (12-29-2017), Leonardo (12-28-2017)
Old 12-27-2017, 08:51 PM   #16
dinfern22
dinfern22's Avatar
Drives: 2016 Scion FR-S(Halo)
dinfern22 is offline   Reply With Quote
The Following 3 Users Say Thank You to dinfern22 For This Useful Post:
15limited (12-29-2017), bcj (12-27-2017), Sapphireho (12-27-2017)
Old 12-27-2017, 08:57 PM   #17
dinfern22
dinfern22's Avatar
Thanks for all the suggestions guys, but I ended up going with the TurboXS License Plate Relocation Kit, just placed the order.
It's almost identical to the Grimmspeed yet much cheaper.
The Following User Says Thank You to dinfern22 For This Useful Post:
bcj (12-27-2017)
Old 12-27-2017, 09:11 PM   #18
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Ok. It's aluminum though. Don't go wild with the roid rage arm strength.
Mean it in this case. Blue LocTite and moderation.
dinfern22 (12-27-2017)
Old 12-27-2017, 09:16 PM   #19
Originally Posted by dinfern22 View Post
A reason I'm hesitant to put a licence plate right in front of the grill.
....Though I'm not sure if it's actually true or just a myth.
I had a front plate smack dab in the middle of the grill on my Miata for 8 years and my FR-S for 5 years. I drove in temps up 105 degrees F in both and never had a overheating problem.
Track use in hot weather might be a different story .....
Old 12-27-2017, 09:16 PM   #20
dinfern22
dinfern22's Avatar
FUCK!
Did not notice that.
..Think it'll be much different from Grimmspeed in terms of quality?
Old 12-27-2017, 09:30 PM   #21
bcj
Geo Tyrebighter Esq
bcj's Avatar
It's only holding a lightweight piece of aluminum. Don't overthink past your classification
The Following 2 Users Say Thank You to bcj For This Useful Post:
dinfern22 (12-27-2017), humfrz (12-27-2017)
Old 12-28-2017, 02:11 PM   #22
dinfern22
dinfern22's Avatar
Guys, in case of an emergency like I need to have my car towed, am I shit out of luck since I have the license plate relocator screwed into the tow hook?
What would someone in an emergency case like this do?
Old 12-28-2017, 02:14 PM   #23
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Remove plate relocate, insert tow hook.
Old 12-28-2017, 02:26 PM   #24
jordan7831
Drives: 2016 Halo FRS
Installation is the opposite of removal
jordan7831 is offline   Reply With Quote
Old 12-28-2017, 02:43 PM   #25
Brink
Drives: 2017 BRZ
I have the Grimmspeed relocate and I keep tools in the glove box to remove it just in case. Just a couple T-handle hex wrenches and a 17mm combo wrench in a zippered leather bag so they don't beat up the glove box. Also make sure you've got some anti-seize on the bolt that threads into the tow hook to make removal less painful.
Brink is offline   Reply With Quote
Old 12-28-2017, 02:47 PM   #26
......... I'm starten ta worry bout you, dinfern22 .......
Joyride86 (12-28-2017)
Old 12-28-2017, 02:50 PM   #27
If you had a few more posts on this forum ....... I'd ...... .... you for that comment.
Old 12-28-2017, 02:53 PM   #28
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I agree that for cars with parts that add heat or for track use; decreased airflow is not what you are looking for.
I've never had any kind of heat issue on the street though.
Plus, I've added some air flow... Hand cut these myself.
I LIKE TIRES!
DIY: License Plate Relocator zeal86 DIY (Do-It-Yourself) Guides 6 06-08-2015 09:21 PM
WTB: License Plate Relocator 1Cor10:23 Canada Classifieds 4 06-20-2014 12:25 AM
License plate relocator FRSBeginner Want-To-Buy Requests 1 11-10-2013 02:09 PM
Do I need to use a torque wrench when installing Grimmspeed front license kit? Meanderchap Cosmetic Modification (Interior/Exterior/Lighting) 3 06-01-2013 07:09 PM
license plate relocator Jeong Scion FR-S / Toyota 86 GT86 General Forum 2 10-24-2012 01:18 AM
