Old 12-26-2017, 08:10 PM   #1
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
How long to wait before changing MT fluid?
I just picked up my '17 BRZ the other day, and am already feeling the famous 1st/2nd gear clunk/notchiness.
I know I'll replace the MT fluid eventually, but should I wait till the car/transmission is broken in before replacing the fluid?
mistople is offline   Reply With Quote
Old 12-26-2017, 08:17 PM   #2
StraightOuttaCanadaEh
Wes
The notchiness will be there for several thousand km. It'll gradually get slightly better and you'll learn to push the clutch in - wait a second - and then engage first. First to second is notchy til the fluid warms up.
I just swapped mine at 20K km and my mechanic said it was black. I switched it out to Motul 300 and that just made it even more notchy. So either use OEM or something else other than Motul. Honestly wouldn't recommend it for colder climates.
Instagram: @gt86ws
Old 12-26-2017, 08:34 PM   #3
mistople
mistople's Avatar
I hear it will get better over time. So I'm willing to wait for a bit.
The weather in the PNW isn't so cold in the winter. Shouldn't be a problem.
Old 12-26-2017, 11:24 PM   #4
Congratulations on your purchase and welcome to our forum .......
I suggest you refer to your car's maintenance manual for frequency of fluid changes for average driving. The manual for my 2013 says to inspect at 22,500 miles ....... it never does say to change it ......
The 1>2 gear change on a cold transmission seems to just be the nature of the beast. I suggest you let the transmission warm up a bit and then just pull the shifter slowly and firmly into 2nd gear.
Be more concerned about running up onto parking stops ...... OUCH!
Old 12-27-2017, 01:06 AM   #5
mistople
mistople's Avatar
I was actually talking about an unschedule transmission oil change. Basically I want the better shifter feel as soon as possible--not necessarily when the manual says so.
Old 12-27-2017, 01:19 AM   #6
Well OK then.
You can change the transmission oil to whatever oil you want as often as you wish. There are about a half dozen brands of oil recommended here on the forum, with the first change being from 1,000 miles to never.
So, when is the transmission "broken in" ..?? Some say it's broken in from the factory, some say after 20-30,000 miles, some say ..... never.
The MT on my 2013 FR-S has always shifted just fine, warm or cold, so, I haven't changed the transmission oil in the past 5 years or 25,000 miles.
I believe ol @Tcoat has over 100,000 miles on his FR-S with the factory fill.
Then some other folks change transmission oil faster that Johnny Cash can kiss a duck.
Your call ......
Old 12-27-2017, 08:10 AM   #7
Teseo
Drives: frs
Change it right now!
The Following User Says Thank You to Teseo For This Useful Post:
Ultramaroon (12-27-2017)
Old 12-27-2017, 02:21 PM   #8
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
In my experience so far the transmission feels better as the miles pile up. Haven't changed the lube yet, will probably do that at 30k. In the meantime, you might try a weighted shift knob. That, in addition to breaking the box in, changed the feel of mine substantially for the better.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 12-27-2017, 06:07 PM   #9
Lust
Drives: 2017 Subaru BRZ
Intervals can vary anywhere from 15k-30k depending on how you drive the car.
Lust is offline   Reply With Quote
Old 12-27-2017, 07:20 PM   #10
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
It was recommended to me to change the trans fluid after you break in the car. Many have complained the fluid was milky and had shavings from the factory. Mine was this way too when i changed it at 3k.
Many people recommend Motul gear 300 for trans and diff, and i do too. I'm coming up on 25k which is the recommended mileage, so ill be doing mine shortly. Since i can't find shops that sell it locally, i ordered from Counterspace Garage who also send crush washers. Waiting on that package to arrive.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 12-27-2017, 07:27 PM   #11
lol
Old 12-27-2017, 07:38 PM   #12
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
Followed break-in period. Changed at 2000 miles.
Shifting actually feels better or placebo? Either way, shifting feels better...LOL
TofuJoe is offline   Reply With Quote
The Following User Says Thank You to TofuJoe For This Useful Post:
TorontoNat (01-10-2018)
Old 12-28-2017, 04:52 PM   #13
mistople
mistople's Avatar
Thanks for the replies!
I drove for a bit longer and definitely noticed a huge difference once the car was properly warmed up. I'm sure a combination of the the transmission breaking in, swapping fluids, and installing a new shifter/bushing setup will be more than enough to do the job
Old 12-30-2017, 03:04 AM   #14
dutchman1
Drives: 2017 86 6-Speed
Maybe I'm the oddball, but I bought a '17 86 last November, have 22000 miles on it and around 150 autocross runs. Haven't felt any notchy shifts or ground a single gear so far. Just changed over to MT-90, still feels the same.
It doesn't get freaky cold here, but I do spend a fair bit of time in Wenatchee and even in 15-20 degree weather it feels just fine cold.
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Found this while changing my tranny fluid Dipstik-sportech Engine, Exhaust, Transmission 25 12-28-2022 04:08 PM
Changing Differential and Transmission fluid Seabass47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-20-2017 12:21 AM
FRS Fluid Changing (Beginner) SmireyFase Engine, Exhaust, Transmission 10 06-27-2016 03:07 AM
Changing Automatic Transmission Fluid euthqt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 06-01-2016 03:16 AM
Using higher quality brake fluid vs using cheap but changing more often ayau Tracking / Autocross / HPDE / Drifting 41 06-14-2015 01:20 PM
