#43 | |
Panda Trueno
Drives: No twin now.
#44 |
Drives: 09 vw gti
That turbo im interested in is water cooled. Is this ok?
#45 |
Drives: 09 vw gti
#46 |
Drives: 09 vw gti
Between these turbos which one should i get?
https://m.ebay.com/itm/Turbocharger-...UAAOSw8w1X~Iwk https://www.ebay.com/itm/Turbocharge...VX~I4T&vxp=mtr https://rover.ebay.com/rover/0/0/0?m...2F152577603851 https://rover.ebay.com/rover/0/0/0?m...2F162544915587 Last edited by nickdd6237; 12-22-2017 at 01:04 PM. |
#47 |
Panda Trueno
#48 |
Drives: 09 vw gti
| The Following User Says Thank You to nickdd6237 For This Useful Post: | Summerwolf (12-22-2017) |
#49 | |
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
If you call JDL they can customize your kit and put whatever you like on it. I got mine customized to my specifications, and Alan has a ton of experience and can help you more than an internet forum can.
| The Following User Says Thank You to mjanmohammad For This Useful Post: | nickdd6237 (12-25-2017) |
#50 |
Drives: 2013 Asphalt FRS
I scanned thru this post and didn't see the most important part. WHATS YOUR BUDGET?????
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#51 |
Drives: 09 vw gti
#52 |
Drives: 09 vw gti
I think I'm going to go with this turbo.
Arashi Billet Ball Bearing GTX2860R GTX2860 turbocharger (Anti-Surge) Turbo performance provides 200 ~ 400 HP Arashi Performance is professional Japanese racing parts manufacturers. COMPRESSOR WHEEL: 45.7 / 60 mm (GTX 11 Blades Billet, Blue Color) COMPRESSOR HOUSING: Anti-Surge 3" inlet (76 mm inlet) , 2" outlet (51 mm outlet ) BACK PLATE: Blue Color TURBINE WHEEL: 47.1 / 53.8 mm, (9 Blades) Trim 76 TURBINE HOUSING: 0.72 A/R High Inconel Turbine Housing BEARING: Arashi Ceramic Ball Bearing COOLING: Water Cooled System FLANGE: V-Band They have the same turbo thats an A/R 57. Which one do u guys think would be better? |
#53 |
That's not going to happen if you stick to reputable parts. maybe if you went used
| The Following User Says Thank You to FRS Justin For This Useful Post: | CSG Mike (12-27-2017) |
#54 | |
Forced induction isn't something to cheap out on. It's far cheaper to get an established kit and build it right than have to buy a new engine because your eBay turbo blew itself up.
| The Following User Says Thank You to mjanmohammad For This Useful Post: | CSG Mike (12-28-2017) |
#55 | |
Drives: 09 vw gti
#56 |
Rust bucket enthusiast
If you don't want to listen to the experience of a forum, why not just ask this in the comments section of YouTube videos you watch? Seriously, we're of the function to help guide you, not perpetuate the nonsense (usually) that spreads cancerously to cause a higher tally of blown engines. Will an eBay everything work? Yes. Will it be less expensive? No. Cost of admission is not your total expense; cheap parts WILL BREAK MUCH MORE OFTEN, and will cause more damage when they go. Would you rather replace the ebay turbo 5 times a year, or a quality turbo once every 5-10 years?
When the expensive turbo does go, you'll likely have to have the seals in the turbo replaced. When the cheap turbo goes, you'll be replacing whatever else it breaks with its catastrophic failure. Do you see what we're playing at here? The expensive part is not the initial buy in. You may want to roll your eyes at every forum post on the internet, by that one guy with a 3641 post count and a smug avatar, that advises "Do it right the first time". There's a reason there's one of them for every 50 10 post eBay warriors; because doing it right gives them the time to post. EBay warriors are out trying to fix their car still. Last edited by DarkPira7e; 12-28-2017 at 08:37 AM. Reason: Grammar |
| The Following 4 Users Say Thank You to DarkPira7e For This Useful Post: |
| Mod ideas? | _anthonygd | BRZ First-Gen (2012+) — General Topics | 42 | 09-08-2015 06:28 PM |
| New Here Need Ideas | FRStrent | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 07-10-2014 10:22 PM |
| In Need Of Ideas!! | bh7990 | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 05-19-2014 12:14 PM |
| Turbo, white smoke out the exhaust, ideas? | Synack | Forced Induction | 44 | 09-09-2013 09:57 AM |
| Need ideas for possible (new-to-me) used car | suprachica79 | Other Vehicles & General Automotive Discussions | 66 | 02-20-2012 06:42 PM |
