Old 12-22-2017, 10:13 AM   #43
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Originally Posted by nickdd6237 View Post
Does anybody know if that Full Blown intercooler kit is straight bolt on without any modifications like cutting the crash beam or whatever. The price seems a bit steep so I was thinking i can go a cheaper route but i would also like an easy install. I was hoping I could piece one together for under $500.
Im already $2000 in with the turbo and turbo manifold. Plus about $1600 for the Ecutek and flex fuel kit. Would like to keep it around $5000 to get all this done.
Also im not gonna tap the stock oil pan so I'm assuming i need a pre drilled one?
Why I initially said just look at SBD.
Old 12-22-2017, 12:41 PM   #44
nickdd6237
Drives: 09 vw gti
That turbo im interested in is water cooled. Is this ok?
nickdd6237 is offline   Reply With Quote
Old 12-22-2017, 12:42 PM   #45
nickdd6237
Drives: 09 vw gti
I dont want to buy a kit tho.
Old 12-22-2017, 12:54 PM   #46
nickdd6237
Drives: 09 vw gti
Between these turbos which one should i get?
https://m.ebay.com/itm/Turbocharger-...UAAOSw8w1X~Iwk
https://www.ebay.com/itm/Turbocharge...VX~I4T&vxp=mtr
https://rover.ebay.com/rover/0/0/0?m...2F152577603851
https://rover.ebay.com/rover/0/0/0?m...2F162544915587
Old 12-22-2017, 12:58 PM   #47
Summerwolf
Panda Trueno
Summerwolf's Avatar
Spend more money for the same result.
Old 12-22-2017, 01:03 PM   #48
nickdd6237
Drives: 09 vw gti
I don't want an internal wastegate turbo like most kits come with.
The Following User Says Thank You to nickdd6237 For This Useful Post:
Summerwolf (12-22-2017)
Old 12-24-2017, 10:54 AM   #49
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Why is that?
If you call JDL they can customize your kit and put whatever you like on it. I got mine customized to my specifications, and Alan has a ton of experience and can help you more than an internet forum can.
mjanmohammad is offline   Reply With Quote
The Following User Says Thank You to mjanmohammad For This Useful Post:
nickdd6237 (12-25-2017)
Old 12-27-2017, 12:32 AM   #50
FRS Justin
Drives: 2013 Asphalt FRS
I scanned thru this post and didn't see the most important part. WHATS YOUR BUDGET?????
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-27-2017, 12:39 AM   #51
nickdd6237
Drives: 09 vw gti
Would like to keep it under $5,000. This is for turbo parts, e85 kit, and tuning software.
Old 12-27-2017, 12:44 AM   #52
nickdd6237
Drives: 09 vw gti
I think I'm going to go with this turbo.
Arashi Billet Ball Bearing GTX2860R GTX2860 turbocharger (Anti-Surge)
Turbo performance provides 200 ~ 400 HP
Arashi Performance is professional Japanese racing parts manufacturers.
COMPRESSOR WHEEL: 45.7 / 60 mm (GTX 11 Blades Billet, Blue Color)
COMPRESSOR HOUSING: Anti-Surge 3" inlet (76 mm inlet) , 2" outlet (51 mm outlet )
BACK PLATE: Blue Color
TURBINE WHEEL: 47.1 / 53.8 mm, (9 Blades) Trim 76
TURBINE HOUSING: 0.72 A/R High Inconel Turbine Housing
BEARING: Arashi Ceramic Ball Bearing
COOLING: Water Cooled System
FLANGE: V-Band
They have the same turbo thats an A/R 57. Which one do u guys think would be better?
Old 12-27-2017, 02:15 PM   #53
FRS Justin
That's not going to happen if you stick to reputable parts. maybe if you went used
710whp
The Following User Says Thank You to FRS Justin For This Useful Post:
CSG Mike (12-27-2017)
Old 12-28-2017, 01:50 AM   #54
mjanmohammad
FLANGE: V-Band
Do you really want to put a $700 eBay turbo on your $30,000 car and hope for the best?
Forced induction isn't something to cheap out on. It's far cheaper to get an established kit and build it right than have to buy a new engine because your eBay turbo blew itself up.
CSG Mike (12-28-2017)
Old 12-28-2017, 03:26 AM   #55
nickdd6237
Drives: 09 vw gti
It cost $1000 and is made in Taiwan. Not China.
Old 12-28-2017, 08:34 AM   #56
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
If you don't want to listen to the experience of a forum, why not just ask this in the comments section of YouTube videos you watch? Seriously, we're of the function to help guide you, not perpetuate the nonsense (usually) that spreads cancerously to cause a higher tally of blown engines. Will an eBay everything work? Yes. Will it be less expensive? No. Cost of admission is not your total expense; cheap parts WILL BREAK MUCH MORE OFTEN, and will cause more damage when they go. Would you rather replace the ebay turbo 5 times a year, or a quality turbo once every 5-10 years?
When the expensive turbo does go, you'll likely have to have the seals in the turbo replaced. When the cheap turbo goes, you'll be replacing whatever else it breaks with its catastrophic failure. Do you see what we're playing at here? The expensive part is not the initial buy in. You may want to roll your eyes at every forum post on the internet, by that one guy with a 3641 post count and a smug avatar, that advises "Do it right the first time". There's a reason there's one of them for every 50 10 post eBay warriors; because doing it right gives them the time to post. EBay warriors are out trying to fix their car still.
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post:
Brink (01-14-2018), JazzleSAURUS (01-12-2018), Summerwolf (12-28-2017), Tcoat (01-02-2018)
Mod ideas? _anthonygd BRZ First-Gen (2012+) — General Topics 42 09-08-2015 06:28 PM
New Here Need Ideas FRStrent Scion FR-S / Toyota 86 GT86 General Forum 30 07-10-2014 10:22 PM
In Need Of Ideas!! bh7990 Scion FR-S / Toyota 86 GT86 General Forum 28 05-19-2014 12:14 PM
Turbo, white smoke out the exhaust, ideas? Synack Forced Induction 44 09-09-2013 09:57 AM
Need ideas for possible (new-to-me) used car suprachica79 Other Vehicles & General Automotive Discussions 66 02-20-2012 06:42 PM
