Old 12-22-2017, 08:09 PM   #15
Chicotunner07
any update on this OP?
having almost the exact same issues....
2013 BRZ 81k miles
only mod is a mishimoto intake tube and k&n drop in that have been on for 40k with no issues. This just started today out of the blue at a stop light, noticed rough idle, hopped on highway with no issues at all, car felt completely normal.
getting off the highway the rough idle started again and the CEL came on, threw on my obd2 scanner and pulled codes p219a and p0302. Got home, cleaned the filter, and cleaned the MAF, reinstalled cleared codes and test drove, after about 15 miles same codes came back.
Dont know where to start diagnosing.....
Chicotunner07 is offline   Reply With Quote
Old 01-31-2018, 01:20 AM   #16
RavioliG
Poor Adult Male
RavioliG's Avatar
Drives: 2013 Subaru BRZ
2013 BRZ 81k miles
Nope I never fixed it. Swapped the motor out.. Did you ever get anywhere?
RavioliG is offline   Reply With Quote
Old 06-20-2019, 10:27 PM   #17
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
Reviving an old thread because I'm having exact same issues and they seem unresolved.
Same issue here with my 14 BRZ. Misfires will accumulate on cylinder 2 like crazy. After driving awhile, then coming to a stop and idling it will start misfiring like crazy. Sometimes suddenly a change and it smoothes out and no misfires for the remainder of the drive.
Tried replacing spark plug, coil pack, direct injector. Nothing solves it. Have not looked at the hpfp pressures though......
Tonrogs is offline   Reply With Quote
Old 08-29-2019, 06:37 PM   #18
FRSCHKN
Drives: Firestorm
I'm having the same issues as well as my ltft is up around 14%-22%. They're also pulling the same codes as Ravi's car. I'm starting to believe that the valves need to be adjusted.
FRSCHKN is offline   Reply With Quote
Old 08-29-2019, 06:42 PM   #19
steve99
Drives: FT86
Most common caise of high positive fuel trims at low rpm is intake or exhaust leaks.
Old 08-29-2019, 06:48 PM   #20
kev0
Drives: '14
My tuner made my tune richer to counter the vacuum leak, to the point where my fuel trims are -20% when driving. What kind of damages am I looking at long term?
kev0 is offline   Reply With Quote
Old 08-29-2019, 09:20 PM   #21
steve99
Drives: FT86
Best get vaccuum leak fixed then get tuner to fix up tune
Old 09-29-2019, 09:12 PM   #22
FRSCHKN
Drives: Firestorm
Still having the same issues, just wondering if the motor has to come out for valve adjustment
Misfire when cold Lawnik Engine, Exhaust, Transmission 5 10-05-2014 09:40 PM
Idle Misfire/Stumble Nightbringer Issues | Warranty | Recalls / TSB 20 09-19-2013 12:27 AM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 10:02 PM
Misfire Jono AFRICA 49 12-12-2012 07:01 AM
ECU replaced. Still has slight misfire, rough idle xomp Issues | Warranty | Recalls / TSB 1 11-01-2012 09:53 AM
