Old 12-20-2017, 09:22 AM   #15
nickdd6237
Drives: 09 vw gti
How's 2600RPM for full spool under street conditions?
What size turbo would u recommend?
nickdd6237 is offline   Reply With Quote
Old 12-20-2017, 12:56 PM   #16
CSG Mike
CSG Mike's Avatar
The smallest that will meet your goals.
JazzleSAURUS (01-12-2018)
Old 12-20-2017, 12:57 PM   #17
CSG Mike
CSG Mike's Avatar
Well if its thats easy then I'll be able to do this sooner than I thought. Shit if I can save all that money, why not?
How much can these stock motors hold up with a good tune? The high compression with a turbo worries me. I would want to lean towards 350hp more than 300hp.
High compression boost is the future.
Low comp turbo is a 90's thing.
Again, throw out everything you know, because it's only going to hurt you going in this project. Leave behind your preconceived notions.
The Following 6 Users Say Thank You to CSG Mike For This Useful Post:
CxG (01-05-2018), JazzleSAURUS (01-12-2018), Joveen (08-02-2020), mrg666 (12-20-2017), nickdd6237 (12-20-2017), strat61caster (12-20-2017)
Old 12-20-2017, 07:45 PM   #18
nickdd6237
Drives: 09 vw gti
I'm thinking a GT28 or GT30.
Old 12-20-2017, 08:04 PM   #19
nickdd6237
Drives: 09 vw gti
I'd like to keep the price of the turbo under $1000. Any suggestions?
Old 12-20-2017, 08:10 PM   #20
nickdd6237
Drives: 09 vw gti
I was thinkin E85 also. This wont be my daily driver since i still have my GTI. I have a gas station down the road that sells E85. Would it be worth the upgrade?
Old 12-20-2017, 08:49 PM   #21
nickdd6237
Drives: 09 vw gti
Eyeballing these turbos....
https://www.ebay.com/itm/Precision-0...lXC0En&vxp=mtr
https://www.ebay.com/itm/Authentic-G...pT9gEq&vxp=mtr
Old 12-20-2017, 09:21 PM   #22
Somerandom18
Drives: 2017 manual BRZ
Try for a ball bearing turbo
https://www.turbobygarrett.com/turbo..._ball_bearings
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 12-20-2017, 09:33 PM   #23
nickdd6237
Drives: 09 vw gti
Gonna go with this turbo piping - https://www.maperformance.com/produc...xoCcJYQAvD_BwE
and
this intercooler kit - http://fullblownmotorsports.com/full...ntercooler-kit
Old 12-20-2017, 09:35 PM   #24
nickdd6237
Drives: 09 vw gti
I was checking those out but their over my budget for a name brand one.
Any insight on these???
https://www.ebay.com/itm/Arashi-4-An...VZORUE&vxp=mtr
Old 12-20-2017, 09:54 PM   #25
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
A gt28 sized turbo with e85 can hit 350whp easy. Check out the dyno sticky above to get a better idea of how much boost you're going to have to run for a certain turbo to get your said power goal.
tyler_win_photo is offline   Reply With Quote
Old 12-20-2017, 10:58 PM   #26
nickdd6237
Drives: 09 vw gti
Thanks..Would the e85 be worth the upgrade? Will it be more reliable? If not I can get 93 anywhere around here.
Old 12-20-2017, 11:01 PM   #27
nickdd6237
Drives: 09 vw gti
Would a gt28 be about the same as a t3 .63 trim? Want to get a turbo with external waste gate instead of internal. I see most of the gt28s come internal.
Old 12-20-2017, 11:22 PM   #28
CSG Mike
CSG Mike's Avatar
E85 is always worth it.
I can hit 350whp with my 18G. A GT28 with E85 can hit far, far higher.
My stock clutch can slip if it's cold enough at 6.5psi. The known slipping point of the OEM clutch is in the realm of 285-315lb/ft, give or take.
Mod ideas? _anthonygd BRZ First-Gen (2012+) — General Topics 42 09-08-2015 06:28 PM
New Here Need Ideas FRStrent Scion FR-S / Toyota 86 GT86 General Forum 30 07-10-2014 10:22 PM
In Need Of Ideas!! bh7990 Scion FR-S / Toyota 86 GT86 General Forum 28 05-19-2014 12:14 PM
Turbo, white smoke out the exhaust, ideas? Synack Forced Induction 44 09-09-2013 09:57 AM
Need ideas for possible (new-to-me) used car suprachica79 Other Vehicles & General Automotive Discussions 66 02-20-2012 06:42 PM
