Old 12-20-2017, 03:55 PM   #43
TorontoNat
Drives: 2013 Scion FR-S Asphalt [Gray]
Originally Posted by ILLSMOQ View Post
Welcome back Mat, You were so focused on center of gravity and body roll, I completely missed where you actually addressed any part of my comments.
Also, I wouldn’t call your information “information”...it’s more of an opinion and you know what those are like. Everyone’s got one. You can flush what comes out of yours next time thanks
Don't worry so much, you will be able to fix the body-roll with suspension setup.
TorontoNat is offline   Reply With Quote
The Following User Says Thank You to TorontoNat For This Useful Post:
ILLSMOQ (12-20-2017)
Old 12-20-2017, 04:27 PM   #44
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Wish I would have seen that kit before ordering the Cusco strut tower brace. Any idea if it’s aluminum or steel? Looks pretty good. Those items will help for sure since the subframes are not very robust. I had to bend the rear subframe to open it up a bit to be able to slip the 8.8 diff into place...it bent pretty easily with a pry bar.
I'd be curious to know if they're steel or aluminum as well...that seems like a pretty comprehensive kit, but a fair amount of weight to add. Not an issue with you swap guys, but for those of us who are counting every ounce with stock motors, it'd be a bigger deal.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 12-20-2017, 04:38 PM   #45
ILLSMOQ
Drives: 2017 WR BLUE BRZ
https://www.agency-power.com/shop/8p...s-toyota-gt86/
These are aluminum
ILLSMOQ is offline   Reply With Quote
Old 12-21-2017, 08:31 AM   #46
Tokay444
Read through the swap thread and it doesn't look like you have compromised the integrity of the chassis to any great degree. Looks like it was pretty well thought out.
I would skip the idea of a cage for adding strength though. Any increase in rigidity it may give is poorly located and of little value anyway. A long piece of pipe with several bends in it and a very small contact footprint with the car is not going to gain you much.
If I was in your position I would go with one of the available brace kits. You may have to do some minor surgery to get some to work with your engine though.
https://www.frsmod.com/products/fr-s...it-for-frs-brz
A cage will most DEFINITELY increase rigidity, and likely by a fair margin.
Also strength and rigidity are not synonymous.
Old 12-21-2017, 08:37 AM   #47
Any increase is marginal at best and actually counter effective at worst.
Old 12-21-2017, 08:40 AM   #48
Tokay444
Show your work.
Old 12-21-2017, 09:50 AM   #49
Show your work.
Don't have to show anything. Unless you are mounting the cage directly to your suspension points there is little to be gained. Bolting a cage onto the floor supports of the car just allows the cage itself to flex. As strong as it may seem there is still some substantial deflection over several feet of tubing. In order to deal with that deflection you would need several cross braces high up in the cage. This adds weight and raises the COG to a point where any advantage in rigidity is negated. If the cage is too heavy it can actually cause flex at the body mounting points.
It seems counter intuitive unless you look at the big picture.
Old 12-21-2017, 09:55 AM   #50
venturaII
venturaII's Avatar
Adding a cage can undo the work put into chassis design to intentionally permit and accommodate flex. Safety gained at the expense of performance.
The Following User Says Thank You to venturaII For This Useful Post:
Tcoat (12-21-2017)
Old 12-21-2017, 10:03 AM   #51
Safety in a roll over situation only. Cages are used and sometimes even required for track use where there is little or no chance of a head on or high speed side impact. On the street where the bigger risk is that truck smashing into you they can turn a safe car into a death trap.
They serve a great purpose when racing and are used with all the other proper equipment but boy racers like them in street cars (that never, ever will see a track) so they can play racecar and pretend to be cool.
Old 12-21-2017, 10:05 AM   #52
Tokay444
lol.
Ok boys.
Who anchors their cage to the floor?
Old 12-21-2017, 10:07 AM   #53
lol.
Ok boys.
Most of the pretenders.
I did not say directly to the floor now did I?
Old 12-21-2017, 10:15 AM   #54
venturaII
venturaII's Avatar
Cages can offer considerable side impact protection as well, if their design included this requirement. More to my point though, is that randomly increasing the rigidity of one section of the chassis does not equate to better performance. Infinite rigidity does not make the car go faster, and very possibly degrades the overall ride quality.
The Following 2 Users Say Thank You to venturaII For This Useful Post:
Hades (12-21-2017), Tcoat (12-21-2017)
Old 12-21-2017, 10:20 AM   #55
Tokay444
My guess is neither of you have ever measured torsional rigidity before and after a proper cage install, and are talking out of your asses.
This is something a can agree with, but no one is looking for comfort in a caged race car...
Old 12-21-2017, 10:30 AM   #56
You have?
A proper cage install in a well engineered, dedicated racecar is a rare thing. We are talking about slapping something into a modified street car. The effect is not going to be the same. To say that "A cage will most DEFINITELY increase rigidity, and likely by a fair margin" is not a catch all nor accurate statement by any means.
HELP: Spoon Front Subframe Rigid Collar Install nichiolas DIY (Do-It-Yourself) Guides 1 12-25-2016 07:44 AM
SPOON rigid collars install mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 11-16-2015 03:24 PM
Rigid Collars? Calum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 11-04-2015 01:38 AM
New Rigid Industries Capture LED Light w/ Built in GoPro could be sweet for the track 86_Insider Cosmetic Modification (Interior/Exterior/Lighting) 0 07-02-2015 07:53 PM
