Old 02-25-2017, 11:18 PM   #15
imnotsureaboutbrz
Drives: between cars...
I'm guessing there was a pic there? If so, I stand corrected I will have to look for myself when mine gets here...
imnotsureaboutbrz is offline   Reply With Quote
Old 02-26-2017, 09:13 AM   #16
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
Originally Posted by ~el~jefe~ View Post
Hey Yo's,
Anyone have the specifications for these new wheels? Also, simpler question that seems to not be coming up in searches for me is: what are the specifications for the BRZ oem wheels?
Thanks
http://www.ft86club.com/forums/showp...&postcount=791
dowroa is offline   Reply With Quote
The Following 2 Users Say Thank You to dowroa For This Useful Post:
R_E_L (08-30-2018), ~el~jefe~ (02-27-2017)
Old 02-27-2017, 01:03 AM   #17
~el~jefe~
Drives: 2019 MX-5 RF
The approximation is not the specs. I appreciate the link however. I need to know the exact weight so I can determine if a new wheel and tire weight is notably better or not.
I wish someone would just dismount the tire and weight a rim, or a dealer/part guy weigh one. Tall order it seems. I will try and do so at some point when I get mine.
~el~jefe~ is offline   Reply With Quote
The Following User Says Thank You to ~el~jefe~ For This Useful Post:
funwheeldrive (02-28-2017)
Old 02-28-2017, 02:13 PM   #18
funwheeldrive
I would like to know this too.
The Following User Says Thank You to funwheeldrive For This Useful Post:
~el~jefe~ (02-28-2017)
Old 03-05-2017, 02:05 PM   #19
RBman
Drives: 2017 BRZ Limited PP
I replaced oem with wheel/tire I had on my 2013 brz. I had to add a spacer for the front to fit the brakes. oem tire/wheel weighed 42.6 lbs
RBman is offline   Reply With Quote
Old 03-10-2017, 05:22 PM   #20
prattusa
Drives: 2017 BRZ series.yellow
they are +48 offset and the brembo calipers "just" clear them
prattusa is offline   Reply With Quote
The Following User Says Thank You to prattusa For This Useful Post:
jmark (08-03-2017)
Old 03-10-2017, 05:26 PM   #21
imnotsureaboutbrz
How big of a spacer did you need to use?
Old 03-16-2017, 10:36 PM   #22
RBman
I used 15mm.
Old 12-19-2017, 08:39 AM   #23
tomm.brz
Drives: brz 2017 hksv2
I used 15mm.
What kind of spacers do you have? with or without the columns/nuts?
i have too 15mm spacers but with columns, and to mount them without the wheel touching them I had to cut a few millimeters out of the stock lugs
Old 01-02-2018, 07:54 AM   #24
RBman
Without
Sent from my SM-G950U using Tapatalk
Old 01-02-2018, 10:44 AM   #25
tomm.brz
ok, makes sense
Old 04-04-2018, 05:34 PM   #26
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
FYI, GT86 TRD wheels are forged, 17 x 7.5 with a 43mm offset. Much better in my opinion. I'm looking at them for my new BRZ limited.
rvoll is offline   Reply With Quote
Old 08-30-2018, 01:37 PM   #27
R_E_L
He's got this.
R_E_L's Avatar
Drives: 50th Anni BRZ
EDIT: didn't realize it was covered in the link above.
22 LBS for those looking
Double Edit: That's apparently an estimation, any exact numbers out there for the wheel alone?
Don't worry, I'm certified... promise.
R_E_L is offline   Reply With Quote
Old 08-30-2018, 05:59 PM   #28
86MLR
86MLR's Avatar
Like dis
2017 BRZ Performance Package Brembo Brakes Part Numbers Veloist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 146 04-27-2023 09:36 AM
To get the Performance Package or Not? Thread Zaku BRZ First-Gen (2012+) — General Topics 141 12-06-2016 10:04 PM
*Wheels Collection* Winter Package 2015-2016 (Alloy Wheels + Tires) wheelsco Canada Classifieds 4 10-08-2015 03:55 PM
Specs on PRS BRZ Wheels Bach415 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-01-2014 01:54 PM
Dyno results for the Nameless Performance street package! John@Nameless Announcements, Contests, Giveaways 31 06-26-2012 04:37 AM
