Drives: '17 PP BRZ
Joying H/U questions, recommended apps, BT issue
Got this head unit https://www.carjoying.com/779.html and had it installed at a shop since I'm sick and really didn't feel like messing with it and am having a few issues. Bluetooth works fine when it's just my phone, but when I pair both my phone and the OBD2 adapter it cuts out every few seconds. Any suggestions how to fix this?
As far as the dash piece goes in the '17 model, for that Canadian piece, do you need to buy the entire dash piece or could I just get the piece surrounding the unit? Which cable needed to be moved around to utilize the OEM amp? I took the car back again and they moved some wires around but it still sounds flat so I'm almost positive they did it incorrectly. Any recommendations on good launchers/EQ's/overall useful Android HU apps? For some reason this model came with a 3-band EQ and it's not that good. |
#2 |
Drives: 2013 BRZ Limited / 2024 G70 3.3T
Plenty of reading material over here, there's several threads about that family of units:
https://forum.xda-developers.com/and...oid-head-units AFAIK there aren't any custom ROM's for the Intel based models but there are plenty of tweaks and utilities, at a minimum you should be able to root it and install viper4android which will take care of your EQ. Car Launcher Pro and CarWebGuru launcher are both pretty good launcher-wise. Not sure on the bluetooth, but I'd suggest a USB OBD2 device like the OBDLink SX...there's probably 1000 threads on XDA by people who can't their bluetooth devices to work. I don't know if Joying does this, but some of the android head unit outfits are known to have code in their bluetooth stack so it will only pair/work properly with their own adapters (usually by requiring the device's bluetooth name to adhere to a specific naming convention, IIRC). |
| The Following User Says Thank You to BRZyJ For This Useful Post: | texastwurkt3am (12-13-2017) |
#3 |
Drives: 2017 BRZ Limited
| The Following User Says Thank You to ncted For This Useful Post: | texastwurkt3am (12-14-2017) |
#4 | |
Drives: '17 PP BRZ
| The Following User Says Thank You to texastwurkt3am For This Useful Post: | BRZyJ (12-14-2017) |
#5 | ||
| The Following User Says Thank You to BRZyJ For This Useful Post: | texastwurkt3am (12-15-2017) |
#6 | |
Drives: '17 PP BRZ
#7 |
Drives: '17 PP BRZ
After reading a few more threads it seems it's a problem super prevalent in the latest build, and should have a fix in the next update. Something about Google Play services in China or something or another, but that's a giant weight lifted since one of the main reasons I bought this HU was for better BT lol
| The Following User Says Thank You to texastwurkt3am For This Useful Post: | BRZyJ (12-15-2017) |
#8 | |
I never had to do this on the car, but I know on some phones in order to get it to work you need to disable or get rid of one of the system audio files. If you have a root file manager installed try renaming /system/etc/audio_effects.conf to something else and rebooting. It may be somewhere else but I'm pretty sure that's where it usually is. |
| The Following User Says Thank You to BRZyJ For This Useful Post: | texastwurkt3am (12-16-2017) |
#9 |
I forgot there is a dude with this model who got banned from XDA for some reason, he's got a long thread on Joying's forums. Might be something of interest there, he seems like he knows what he's doing:
https://forum.carjoying.com/thread-1...kishness-.html |
| 2013 FRS Immobilizer Issue - bunch of questions | sfruski | Engine, Exhaust, Transmission | 31 | 12-07-2022 01:38 PM |
| AVH-4200NEX + Apps | Chronology | Electronics | Audio | NAV | Infotainment | 10 | 02-16-2017 05:33 PM |
| Any nitrous apps yet? | 86pro | Forced Induction | 20 | 02-07-2014 11:00 AM |
| smart phone apps | autobrz | Tracking / Autocross / HPDE / Drifting | 11 | 09-27-2013 05:24 AM |
| Best Car Apps For A Ipad | travace | Other Vehicles & General Automotive Discussions | 2 | 09-19-2012 04:53 PM |
