Old 12-13-2017, 12:31 PM   #1
Hades
Hades's Avatar
Drives: 2013 Scion FRS
e85 or headers
Anybody have some input on this? I currently run the OFT e85 tune and am satisfied with the top end power, but would like some more lower end grunt. My debate is that if I go with headers, I want one of the better ones, so that means either Ace or PTuning and an ecutek tune. How would this compare to my current OFT e85 tune? Would I be satisfied going back to 91 with headers? Hoping for similar top end, and more mid range torque.
Hades is offline   Reply With Quote
Old 12-13-2017, 12:55 PM   #2
fika84
fika84's Avatar
Don't forget about the Nameless Long Tube headers
fika84 is offline   Reply With Quote
Old 12-13-2017, 01:15 PM   #3
Hades
Hades's Avatar
Yea, I've heard nameless are quite loud, though. Definitely a good choice, forgot about them. I guess I should also shout out to JDL since I've heard great things about them. I'm just primarily looking at the Ptuning & Ace since they seem pretty well tested & have proven results at the track.
Old 12-13-2017, 01:30 PM   #4
jasonojordan
Drives: 2013 satin white brz limited
I have the ace headers and the flexfuel delicious tune. I can tell a huge difference when I am running 93 vs e85. So my easy answer do both!
I ran the car with e85 on stock headers as well and I feel the gains are comparable between e85 and stock headers and 93 and aftermarket header.
jasonojordan is offline   Reply With Quote
Old 12-13-2017, 01:37 PM   #5
Hades
Hades's Avatar
Thanks! Unfortunately, I don't think the points are going to work out for e85 + headers for me. But I'm definitely considering the FlexFuel kit for the option to run 91, 100 octane, and/or e85.
Old 12-13-2017, 01:46 PM   #6
jasonojordan
If your going to spend the money and go ecutek I highly recommend the flex fuel kit. I used to run just an e85 and a 93 map on my wrx. Was a pain to switch and back forth.
Old 12-14-2017, 12:17 AM   #7
FunnyGopher
Drives: 2015 BRZ Limited
To this point, if you DON'T have enough for flex fuel at the moment, AND you have a reliable source of E85, then just having two maps for both fuel types is an option. There's a guy in our club that runs an E54 tune, and a 91 tune. Tuning for that static E85 map should be less than a flex kit. With EcuTek, this is easy. Then later down the road you just get the flex kit.
FunnyGopher is offline   Reply With Quote
Old 12-14-2017, 12:26 AM   #8
Hades
Hades's Avatar
I'm sort of confused how this works. Would I have to pay for two tunes? Thinking of going with delicious.
Old 12-14-2017, 12:30 AM   #9
steve99
Drives: FT86
If you want lower end grunt get the ACE possibly the CS400 header, The P tuning is a great header but it orientated to top end power ie racetrack.
If your satisfied with current top end power on E85 with stock header, then you could save yourself a bunch of money and buy a gruppe-s uel or the 1320 header(unless you hate uel sound) they will give similar low end grunt as ACE but not as much top end, good header for street use on a budget.
E85 is so variable in ethanol content in USA you need a reliable source of stable e85 or a flex kit.
both ecutek and oft can do flex.
Old 12-14-2017, 01:07 AM   #10
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
From what I've seen relative to what I've ran on my own car (tomei el and nameless "type" header) comparing torque curves on various dyno results... it look like nameless makes the most gain where the torque dip is on a stock header, but at the expense of power below 3000 rpms and some under-hood real estate. Ace (original design) look to gain a lot of mid range torque without loosing power below 3000, but cost 3-4 times more than your UEL options. The more popular and proven UEL's will gain you most of the mid range of these expensive long tube el's with gains in the low end not much off a loss at the top-end compared to any of the el headers with proper tune.
If I had to do it over again, I would have gotten the Tomei, JDL or OFH UEL instead of the Tomei EL the first time 'round and spend the rest of my time dialing the tune and call it a day. I'd have money left over for flex fuel if I only had the money I already spent on breathing mods.
Then again.. the thought of having uneven exhaust pulses and possibly uneven engine wear with UEL bothers me a little..
Intent > Content
Old 12-14-2017, 01:12 AM   #11
FunnyGopher
That depends on the tuner, and I'm not sure about Delicious. We have a local club tuner, so mileage will vary. I too just bought header and a tune from Delicious, but I bought a 91 tune. If I had to buy an E85 tune, I imagine you would pay for both tunes. Idk. You might just need to ask about it. I don't even see that they sell a static E85 tune.
Old 12-14-2017, 01:33 AM   #12
steve99
Drives: FT86
That depends on the tuner, and I'm not sure about Delicious. We have a local club tuner, so mileage will vary. I too just bought header and a tune from a Delicious, but I bought a 91 tune. If I had to buy an E85 tune, I imagine you would pay for both tunes. Idk. You might just need to ask about it. I don't even see that they sell a static E85 tune.
delicious only do flex they don't do map switch E85 tunes.
moto-east will do it though
Old 12-14-2017, 07:51 AM   #13
jasonojordan
As steve pointed out with delicious you get the flex fuel tune and module and its one map that works for 91 to e85 and anything in between.
Old 12-14-2017, 12:10 PM   #14
lutfy
lutfy's Avatar
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Since I had the OFT and didnt want to get EcuTec. I went forward with PTuning headers along with @steve99 custom maps for my car. Steve sent me a baseline and we sent it back and forth (data logs from OFT) until it was fine tuned with zero knocks and such. Car is MUCH more lively up top and power punch is phenominal. Map was optimized (curve etc) including camtiming matched to the PTuning header. I had to reduce hp up top to stay in class but mid range unaffected so we pulled timing a bit.
I could have used a bunch of local turners but went with Steve as his support was SPOT on. Always responsive, knowledgeable and would share (as to why its doing something vs here you go just upload it). Very happy and car holds track records for fastest NA FRS at two north east tracks. My goal was to "win" in my time trial class and Steve delivered just that.
No affiliation, just a happy customer.
Lutfy
2015 FRS NASA ST/TT5
2022 LR Defender
2023 BMW M2
lutfy is offline   Reply With Quote
wtb uel headers justinh77 Want-To-Buy Requests 7 11-22-2016 04:21 PM
WTB: UEL Headers KungFuWaffle Want-To-Buy Requests 3 08-31-2016 08:52 PM
WTT: Tomei uel headers for EL headers 86Tony Canada Classifieds 6 07-27-2015 09:42 PM
WTB: UEL Headers iamdaspoon NY / NJ / CT / PA 9 04-16-2015 08:01 PM
Injen SES Headers/ Agency Power headers Choong86 Engine, Exhaust, Transmission 10 12-27-2013 09:51 PM
