Old 12-12-2017, 03:28 PM   #1
SGTPanda
SGTPanda's Avatar
Drives: 2017 SUBARU BRZ PP
BRZ MY17+ front lip options?
Hey guys just wanted to see if anyone knows of MY17+ BRZ front lips. I already know of the STI lip and other replicas. Have they made any besides those? And yes I already googled it.
THIN BLUE LINE
SGTPanda is offline   Reply With Quote
Old 12-12-2017, 09:38 PM   #2
dvniemela
dvniemela's Avatar
Believe RallyBacker makes some sort of lip/splitter for the 17'.
https://sites.google.com/view/rallyb...a-86-version-2
dvniemela is offline   Reply With Quote
Old 12-12-2017, 10:13 PM   #3
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
We make a front splitter, very similar to the FRS/BRZ of previous years.
https://www.verus-engineering.com/pr...front-splitter
Thank you,
Eric
VerusEric is offline   Reply With Quote
Old 12-12-2017, 10:50 PM   #4
NRXRaptor
Go to 86speed (dot) com, mouse over the "More" tab, and click on "Kouki 86-BRZ." Not much there in terms of splitters, but I bet drilling some new holes on a splitter for a 2016 wouldn't be so hard. Even easier for a front diffuser. Honestly you should just find vendor sites like 86speed, subispeed, rallysport, etc and peruse their selections in their entirety. I guess that's an advantage of having the older car: more parts
NRXRaptor is offline   Reply With Quote
Old 12-13-2017, 12:12 AM   #5
SGTPanda
SGTPanda's Avatar
Thanks for the input guys but those are all toyotas lips. I'm looking for lips that fit the MY17+ BRZ.
THIN BLUE LINE
Old 12-13-2017, 03:41 PM   #6
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
Welcome to my hell!
The only companies with 2017+ lips are:
APR - Has replicas
Chargespeed Version 1 - Has replicas
STI and STI reproductions
Chargespeed Version 2
S-Craft
HT Autos - Pics on next page
IKON style lip (found it on ebay - a reproduction of the 12-16 style lip but fitted for 2017+ bumpers)
AIMGAIN (The lip will look weird alone, needs the accompanying front bumper (side burn) wide body extensions)
*VIS Racing said they are looking to make a 17+ brz lip in the future. Nothing has come about this in over a year.
Companies that have made 2017+ 86 lips:
Rallybacker
Greddy
Stance Nation x Aimgain collaboration
TRD (Looks bad ass if you get the LED lights option)
Grazio
Modellista
Garage Vary
VIS Racing
Battle Aero
C-West
Silk Blaze
TOM'S
Seibon is currently working on an 86 lip
TachyonBomb is offline   Reply With Quote
Old 12-13-2017, 05:07 PM   #7
VerusEric
VerusEric's Avatar
Our splitter bolts up to 2017+ BRZ and GT86 bumpers, no problem .
Thanks,
Eric
Old 12-13-2017, 11:11 PM   #8
NRXRaptor
Thanks,
Eric
Are those the Valenti headlights? Kinda wish I got those and re wired them to fit left hand drive instead of getting the Intec ones. The Intecs do have a really nice Audi style led strip though
Old 12-22-2017, 10:02 PM   #9
derekbrz24
derekbrz24's Avatar
Drives: 2017 Subaru BRZ WRB PP
Thanks,
Eric
What rear spats are on the car?
derekbrz24 is offline   Reply With Quote
Old 12-23-2017, 12:30 AM   #10
NRXRaptor
Probably theirs
Old 12-23-2017, 12:41 AM   #11
Brink
Drives: 2017 BRZ
Thanks,
Eric
Can you confirm your splitter requires the support rods to be installed on a 2017 BRZ? Yours was a product I liked the looks of (particularly with the added endplates), and I liked for previous model years that there was the option of installing without support rods for <90 MPH, or with rods for greater speeds. It seems due to changes to the front end of the 2017 model year the mounting points now require the support rods for all installations. Is this true? I don't like the idea of drilling into the front crash beam to install this if that is the case, so I'll probably end up going in a different direction. Right now the APR front air dam (and other aero kit) is at the top of my list but I'm waiting a bit longer to see if anything else becomes available since there isn't much for 2017+ yet.
Brink is offline   Reply With Quote
Old 12-24-2017, 08:23 AM   #12
VerusEric
VerusEric's Avatar
I believe Daniel runs our rear spats.
The front support rods are necessary on the 2017+ GT86 and BRZ due to the forces the front splitter sees at anything above 80ish MPH. The previous generations were able to have mounting on the bumper further forward which could handle the forces up to 100MPH. The newer generations have mounting very far rearward, the support rods allow the front splitter to handle the load.
Hope that helps make sense of everything. The drilling is minimal and 100's of people have done it so far. If you want a front splitter that produces reasonable amounts of downforce, you'll need to figure out a way to connect the splitter (any brand) to a support structure on the front of the vehicle (crash beam, rad support, etc).
Thanks,
Eric
Old 01-21-2018, 07:58 PM   #13
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Originally Posted by TachyonBomb View Post
Welcome to my hell!
APR
Chargespeed
*I think the URAS front lip may be able to fit the 2017+ brz. But someone should test fit this just to confirm.
Rallybacker
Greddy
Chargespeed
Grazio
Modellista
Garage Vary
VIS Racing
Battle Aero
C-West
Silk Blaze
TOM'S
The 2017+ BRZ are getting shafted pretty hard when it comes to things specific to just the 2017+BRZ.
IE:
- Front fog/led lighting options
- Lips
- Bumper mustache options
- Canards
- Fog light bezel options
- Brake options which explicitly state (For Performance Package/Brembo)
- Brake options that cater to the factory brembos
- Wing/Trunk-lip options which work with the limited models wing mounting -
- points or modify the existing wing
- Springs that where created using the SACHS dampers
- Things that revolve around the changes made with the intake manifold (oil cooler sandwich line connections, intakes, throttle bodies) **Should be noted that this last area is getting worked on faster than the others**
Things which overlap both the 2017+ BRZ and 2017+ 86 get pushed out a bit quicker.
IE:
- Axleback exhausts
- Head/Tail Lights
- Tuning updates
- Supercharger/Turbo options
- Front Splitters
- Interior trim (Fingers crossed for a carbon fiber 2017+ steering wheel)
Though it should be noted that the BRZ/86 model updates have only been around for a little over a year while the older models have been around for about 6 years now.
Thank you
ILLSMOQ is offline   Reply With Quote
Old 07-13-2018, 03:48 PM   #14
TachyonBomb
BRZ list updated.
After 7 months only new lips offered for the 2017+ BRZ are the FT86 speed factory reproductions of the sti & chargespeed style lips along with S-Craft offering a new style of lip.
Also I came across an IKON style lip on ebay. They seem to have reproduced one of the IKON style lips but made the upper part mold to the bottom of the 17+ bumper.
Front Splitter Options for BRZ? BRZZZZZZZZZZ Cosmetic Modification (Interior/Exterior/Lighting) 6 03-26-2015 01:52 PM
FR-S Front Lip, Options/ Suggestions? _j_anthony Cosmetic Modification (Interior/Exterior/Lighting) 5 07-11-2014 06:12 PM
Front LCA options, not sure yet. puma Tracking / Autocross / HPDE / Drifting 3 05-01-2014 11:06 PM
brz - front bumper options cantaloupe Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 08-30-2013 04:32 PM
FR-S Front Grille Options Borgore Cosmetic Modification (Interior/Exterior/Lighting) 21 11-14-2012 04:03 PM
