Old 12-11-2017, 07:34 PM   #1
MrR7343
Drives: 2013 Silver BRZ
OFT LC issues
Hey guys,
got a little thing going on with my OFT LC Tune, i have my LC activated for 4600rpm (3000 on tune with rom raider) and for some reason if i'm not clutched in my car will only rev to 4100rpm, but if i clutch in and go in first it will go to 4600rpm which is my set LC.
Not sure if this has happened to others, but i'm just trying to see if anyone has a solution to this.
And is there a way to rev to redline with LC activated or do I have to go above the speed limit or threshold set (6mph) for it to de-activate LC and rev to redline.
Thanks,
MrR7343 is offline   Reply With Quote
Old 12-12-2017, 01:34 AM   #2
steve99
Drives: FT86
Yeah i think that happens, do you have flat foot shift set ?? As it wkrks of clutch switch
Old 12-12-2017, 03:21 PM   #3
MrR7343
No i have the flat foot shift off and i made sure by checking in romraider and it is at 0 :/.
Old 12-12-2017, 03:29 PM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I have LC and FFS set up and I can hit the rev limiter at idle (in N and no clutch obviously) and while driving. FFS works like it should and so does LC
Maybe you need FFS set up and on for it to work?
guybo is offline   Reply With Quote
Old 12-12-2017, 03:39 PM   #5
MrR7343
Yeah thats the weird thing, if i go above 10kph it works, which is what my speed thing is at. (6 or so mph).
Not sure I even unplugged my battery but no luck. I will probably flash a non LC tune and we will see how that works.
launch control, oft, open flash tablet
Issues with my 86 please help belleh Issues | Warranty | Recalls / TSB 11 12-14-2016 06:45 AM
Lug Nut Issues! srizzors25 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 04-07-2015 07:25 PM
Issues and more issues MEGA_Tawn Issues | Warranty | Recalls / TSB 7 02-16-2015 07:42 PM
Oft e85 issues sosick Software Tuning 14 05-22-2014 05:40 PM
more issues after CEL fix.. DrewZ926 Issues | Warranty | Recalls / TSB 2 11-07-2012 08:15 PM
