Old 12-11-2017, 04:41 PM   #29
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Darth Khan View Post
MMMM, I knead to pruf reed better.
I agree, the one thing I don't do any more is shift down the gears to slow down. I just hit the breaks and go direct the lowest gear I think I will "knead".
Double clutch to be kind to your synchros when you do that.
ineedyourdiddly
Old 12-11-2017, 06:35 PM   #30
ermax
ermax's Avatar
Which I do but most people don’t and/or don’t know how.
Old 12-11-2017, 09:49 PM   #31
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by driggity View Post
I know this is an old post, but yes pads can give a different feel but I don't think that's the case for your pads. Does the pedal feel change much from when the pads are cold vs. when you've been putting a lot of heat into them?
What are the size of the pistons in the Wilwoods compared to stock?
I add speed bleeders and did a power bleed. I tried to cycle the ABS too before bleeding in case any air was trapped. It is much better but not 100%. In general the pedal feel is amazing at high speeds when I have to punch the brakes. Not as much at low speeds. Im planning to rebleed in a few months and then try EBC red stuff for the street when my pads need changing.
Old 09-07-2019, 09:30 PM   #32
GrantedTaken
How are you supposed to check the pad thickness ?
I had the wheels off and I could not even see the pads.
Do you need to remove the caliper to check the pad thickness ?
GrantedTaken is offline   Reply With Quote
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
swapping brake fluid: taking FOREVER to bleed the air!! snuff58 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 11-02-2015 03:09 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
