Old 12-09-2017, 02:04 PM   #1
halujeddo
Drives: Subaru BRZ
OFT: Cannot create a tuning file
Hi all,
I have been searching similar threads for hours but couldn't find an answer to solve my problem.
I have just read my ecu, which is ZA1JF10G
When I plug OFT device to OBD port, device says "Mod file not found. Cannot create a tuning file for ZA1JF10G"
Then I downloaded latest tuned file zip file from oft website.
I've tried to upload all the files zipped in that file to the device but none of them were compatible to my calibration file. What should I do?
One more question, i see "pedal dance" function on videos but this function doesn't even appear on my OFT device. is it normal?
Car: 2015 BRZ, from Turkey (EU market)
Thanks
halujeddo is offline   Reply With Quote
Old 12-09-2017, 04:20 PM   #2
steve99
Drives: FT86
If oft read your ecu ok, it just means it doesnt have F10G roms in its database, go to the oft website and diwnliad tune pack and upliad the F10G rom you need to oft
Also you may need to update oft firmware by loading openfladh manager onto you windows computer its on oft site as wrll and plug in oft to computer so it updates this should get pedal dance function. If still no good updste template file theirs one at end of OFT TIPS link below
Old 12-09-2017, 04:56 PM   #3
elBarto
elBarto's Avatar
Drives: Toyota GT86
Steve, the tunepack doesn't have F10G roms. Latest is D00G for EU roms.
@ OP, you need to e-mail openflash support for a ROM. Tell them you have a unsupported ROM (include the stock ROM). They should send you a correct ROM.
Verstuurd vanaf mijn Xperia L met Tapatalk
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 12-09-2017, 06:56 PM   #4
steve99
Drives: FT86
Originally Posted by elBarto View Post
Steve, the tunepack doesn't have F10G roms. Latest is A01G for EU roms.
Arrh ok
F10G is compatable with A01G, so bast option is to hack it, that way you get launch and ffs patch good definitions and good tunes
Old 12-09-2017, 11:11 PM   #5
halujeddo
Drives: Subaru BRZ
I've sent a mail to sales@openflash, i hope this is correct address and I would get a response
I've already connected the device to laptop with wifi connection and have done lots of updates. Now HW version: 1.35 SW version 1.47
Is this a method: Open another "supported" tuned rom file with romraider, compare the differences with that rom's ori file and apply those differences to my own rom?
Will I have same stage1 tune file with this?
Thanks
Old 12-09-2017, 11:14 PM   #6
steve99
Drives: FT86
Thanks
Yes you could manually transfer all the changed tables, however sometimes the definitions between say A01G and F10G will not match up
Old 12-10-2017, 05:39 AM   #7
halujeddo
Drives: Subaru BRZ
I got a respond from openflashtablet quickly. Thats really nice.
They sent all the files.
Here's the question: I've tried to open stg1 tuned file at RomRaider to check the differences with ori file. But the definition XML file which is suitable for my ori file is not supporting new tuned files which are came from Openflashperformance.
Is it normal? Is there any encryption?
Old 12-10-2017, 11:38 AM   #8
elBarto
elBarto's Avatar
Drives: Toyota GT86
There is no encryption, but the error is probably because the rom has been cal id hacked.
I've uploaded a small program to check te CalId (created by Wayno and Steve99). Place the program in a folder and paste the rom inside it. Let it run and paste the output here.
Then we know which definition you really need.
link= Calid checker
This is a example picture of how it should look:
Old 12-10-2017, 12:12 PM   #9
halujeddo
Drives: Subaru BRZ
Thank you for your response.
This is how it looks:
ZA1JF10G: is the stock file which i read from my car's ecu by OFT
Stg1 F10G: is the file which openflashperformance sent me upon my request via email.
So will it work if i flash it to my car's ecu?
Old 12-10-2017, 01:17 PM   #10
elBarto
elBarto's Avatar
Drives: Toyota GT86
No problem flashing the stage1 file, it will work.
Also I've added a definition file for you.
It's A01G def edited for use with your OFT F10G rom's.
Do not use this with your original rom!
link= OFT F10G Definition
Old 12-10-2017, 01:28 PM   #11
halujeddo
Drives: Subaru BRZ
Thank you so much! Appreciate!
Do you also have stock bin file for that "hacked f10 stg1" rom in order to compare tuned file vs stock file?
Old 12-10-2017, 03:19 PM   #12
elBarto
elBarto's Avatar
Drives: Toyota GT86
In Steve99's topic "Tactrix EcuFlash Info for BRZ 86 FRS Rom flash update and logging there are stockroms at the bottom of the first post. Use a A01G rom to compare. Less chance to use a wrong definition since all OFT G-roms are A01G based.
edit:
Since you are from the EU, you can look at Wayno's roms also. They are more optimized for the EU fuels.
Wayno's topic - alternate maps
tuning file John27 Software Tuning 3 04-22-2017 01:23 PM
OFT - Can't Load Tuning File BRZBuzz Software Tuning 0 07-18-2015 08:04 PM
OFT - Mode file not found. Cannot create a tuning file. focobrz Software Tuning 11 07-17-2015 09:22 PM
How to create Nav SD card backup? Moss Scion FR-S / Toyota 86 GT86 General Forum 0 08-27-2013 06:29 AM
When will too much +/- offset create problems? Hanakuso Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 11-01-2012 06:53 PM
