Old 12-09-2017, 09:59 PM   #365
H1C
Drives: 2014 FR-S MT
The stock setup of the clutch is frustratingly vague because there is too much leverage between the clutch pedal and the pressure plate. I started looking for ways to change the diameter ratio between clutch and master cylinders when I stumbled into the no-brainer solution. The stock slave cylinder has a 13/16" bore. Subaru has another clutch slave cylinder with a slightly narrower bore of 3/4". It is otherwise identical to stock but decreases the leverage by 17%. Here is the original thread leading up to this DIY. Enjoy.....
I've been meaning to thank you for this thread for the longest time. I did this mod back in the spring, after putting on a catless header, and it greatly improved clutch feel -- being able to tell where the bite point is.
For some reason, after installing the header and tune, I was slipping the clutch a lot more than previously from stop lights. Maybe it was the filled-in torque curve, but I was having the hardest time being able to feel where the clutch was biting. I've been driving manual for 30 years, and when the car was stock I thought the clutch was on the light side but ok in feel. After the header and tune I was slipping the clutch a lot more than I intended to. This mod really restored the drivability of the clutch. Thanks a lot for sharing it with us!
H1C is offline   Reply With Quote
The Following User Says Thank You to H1C For This Useful Post:
Ultramaroon (12-09-2017)
Old 12-09-2017, 10:25 PM   #366
Thank you for the feedback! Never gets old hearing from folks who like it.
H1C (12-09-2017)
Old 12-09-2017, 10:36 PM   #367
H1C
My pleasure -- thank you for all your technical knowledge and level-headedness. I've learned a ton from your posts!
Old 12-10-2017, 11:06 AM   #368
jcw99
Drives: swp mt '14 brz premium
Ditto
jcw99 is offline   Reply With Quote
The Following User Says Thank You to jcw99 For This Useful Post:
Ultramaroon (12-10-2017)
Old 01-27-2018, 06:37 PM   #369
chickunfut
Low-Buck Ramp Truck
chickunfut's Avatar
Drives: 2016 Scion FR-S Release 2.0 #502
Just finished the swap today. Best mod for this car without a question. Makes a huge difference in the drivability of the car. Worth every penny. Thanks for the info !!
chickunfut is offline   Reply With Quote
The Following User Says Thank You to chickunfut For This Useful Post:
Ultramaroon (01-27-2018)
Old 03-24-2018, 10:31 AM   #370
PA-86
PA-86's Avatar
Drives: Scion FR-S Ultramarine, Triumph STR
Finally gave this slave cylinder swap a try after owning the car for several years (prompted by driving my gf's Cooper GP which has a stiffer clutch pedal). Thanks very much for the suggestion and walk-through, this is one of my favorite mods for sure! Initial impressions are; much more predictable engagement point, shorter overall pedal travel, and slightly stiffer pedal feel. The swap took about a half hour and that's only because I decided to completely change out the old brake fluid. Parts were sourced from subaruonlineparts.com
PA-86 is offline   Reply With Quote
The Following 2 Users Say Thank You to PA-86 For This Useful Post:
funwheeldrive (04-12-2018), Ultramaroon (03-24-2018)
Old 03-24-2018, 02:13 PM   #371
My pleasure! Thanks for your feedback.
With over 40 Kmiles of daily stop-&-go commuting, my clutch cylinders continue to work flawlessly.
Old 03-26-2018, 09:53 AM   #372
PA-86
PA-86's Avatar
I'm almost at 50k miles, just recently cooked a coil pack. Only clutch related issue I've been experiencing is a squeaky/stiff feel in the clutch pedal when I get to the last inch or so of travel. Not at all related to the slave install, by the way.
The Following User Says Thank You to PA-86 For This Useful Post:
Ultramaroon (03-26-2018)
Old 03-26-2018, 12:48 PM   #373
Yeah. I've had the same. Squeaky is the dry fork. Stiff is the TOB slowly gouging out the quill. Shitty design.
Old 03-26-2018, 06:13 PM   #374
HSUBLU
Drives: 2017 BRZ WR Blue
I still need to do this at some point...
HSUBLU is offline   Reply With Quote
The Following User Says Thank You to HSUBLU For This Useful Post:
Old 03-26-2018, 09:26 PM   #375
funwheeldrive (04-12-2018), HSUBLU (03-26-2018), MJones_RB (05-04-2018)
Old 04-12-2018, 05:44 PM   #376
N234
N234's Avatar
Drives:
Has anybody put a speed bleeder on this? Is it the same size as the original slave's bleed screw?
Sent from my SM-G930W8 using Tapatalk
N234 is offline   Reply With Quote
Old 04-12-2018, 06:24 PM   #377
funwheeldrive
Me too. I'm nervous that I'm going to mess something up. I'm pretty comfortable with doing regular maintenance, but I've never messed with master cylinders or stuff like that.
Old 04-13-2018, 03:14 PM   #378
It's just plumbing. If you can fix a faucet, this'll be a cakewalk. Cleanliness is the key factor.
clutch line, slave cylinder
Clutch Engagement Improved! enjoyminutemaid Engine, Exhaust, Transmission 53 11-07-2018 06:31 PM
Can steering feel, tactility, be improved? Without sacrificing adjustability? Trettiosjuan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 101 08-16-2016 08:14 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 10:22 AM
Hate the feel of the clutch FRSGeek Engine, Exhaust, Transmission 18 07-10-2013 01:24 PM
Clutch feel? Shit Luck Engine, Exhaust, Transmission 5 04-21-2013 05:32 PM
