Old 12-08-2017, 09:51 AM   #17991
Originally Posted by rookietopro_frs View Post
See I heard about that issue, when people go to 18 inch wheels the speedo is off. That would annoy me honestly ...
Originally Posted by Lococholo84 View Post
Yeah same here lol
Going to an 18" wheel does not throw the speedo off. It is the size of tire that you put on that wheel that can do it. Wheel size means nothing it is the overall diameter that the speed is based on. Smaller overall means the wheel does more turns and the speed would indicate as faster. Larger means the wheel makes less turns and it would show as slower.
Leonardo (12-08-2017), Lococholo84 (12-08-2017), rookietopro_frs (12-09-2017)
Old 12-09-2017, 08:27 AM   #17992
rookietopro_frs
rookietopro_frs's Avatar
Drives: 2013 Scion FRS
So what tire size would you recommend if I went with 18s, so I don't throw off my speedometer?
rookietopro_frs is offline   Reply With Quote
Old 12-09-2017, 11:06 AM   #17993
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
go to the tire rack's website and select tire and wheel package for your car. when you select a larger rim it will suggest the correct tire size.
I put larger rims on my accord and the speedo is still spot on.
fx1mark is offline   Reply With Quote
Old 12-09-2017, 12:19 PM   #17994
See below
This ^
You don't have to buy from them but it will give you all the info you ever needed.
rookietopro_frs (12-10-2017)
Old 12-09-2017, 05:43 PM   #17995
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Driver mod!
Took her to Phillip Island GP Circuit for an introduction to motorsport day. Did two sessions with an instructor and two solo sessions later in the day. All I can say is WOW, this car feels incredible on the track. It comes alive and shows it's poise and ability in the corners and the Hankook RS3's felt great.
Wise is offline   Reply With Quote
The Following 2 Users Say Thank You to Wise For This Useful Post:
Dadhawk (12-09-2017), guybo (12-10-2017)
Old 12-09-2017, 06:07 PM   #17996
arxm
Drives: 2013 FR-S, 2023 BRZ
after runnings 18's for a few months, the speedo being like 1-2kph off at like 100 was a non issue, the bigger problem was how much the extra weight threw off handling, im sure that can be fixed by expensive lightweight wheels, but for most people id say go for 18's for looks, 17's for driving dynamics
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
The Following User Says Thank You to arxm For This Useful Post:
Old 12-09-2017, 06:48 PM   #17997
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
My car handles better with 18s. Go figure.
StraightOuttaCanadaEh (12-09-2017)
Old 12-09-2017, 06:54 PM   #17998
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
16s for even more driving dynamics.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 12-09-2017, 08:55 PM   #17999
Well then ........ this ought to handle really well .......
Old 12-09-2017, 09:08 PM   #18000
Teseo
Drives: frs
And 16 is more cheap, wait...
Old 12-09-2017, 09:42 PM   #18001
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I would handle her real well, if you know what I mean.
Wait, I think I stole that from someone...
humfrz (12-09-2017)
Old 12-09-2017, 11:23 PM   #18002
Yep, I've seen that phrase before ...... several times ....... from that pre-vert member ......
DANG, I wished those "wheels" could remind me of a story .......
Old 12-10-2017, 02:43 PM   #18003
arxm
lol i found that mainly braking performance was hindered (exra weight more inertia, i know) and it just felt lighter on its feet, not to mention cheaper tires
Old 12-10-2017, 08:36 PM   #18004
mokee92
Drives: Lunar Storm - Series 2.0
Got them snow boots to tackle the snow. :-D
Also sort of fixed the annoying sidemarker issue that plagues this car. Used a zip tie.
mokee92 is offline   Reply With Quote
The Following 2 Users Say Thank You to mokee92 For This Useful Post:
Clipdat (12-12-2017), Myriad (12-11-2017)
