#155 |
I think I have a project for the weekend. Thanks for the help guys.
Edit: Just curious, what do you use to wax them? |
#156 | |
#157 | ||
Drives: GT86
Ultra is right, the furry material can be easily removed during cleaning and they are cheap to buy even if it turns out that the originals could have been saved. Quote:
I found this the best option up to now, however, I also had to realize that even if I press the scraper seal completely to the glass, it still allows water inside the door. I created a small test to verify this and it seems to me that water ingress is somewhat expected, so maybe the solution against the squeak would be to not push the glass that much outside and thus the outer guides would hardly touch the glass leaving no chance for squeak. |
| The Following 2 Users Say Thank You to mausr For This Useful Post: | sato (07-06-2021), Ultramaroon (12-07-2017) |
#158 |
Drives: 2016 BRZ
#159 | |
#160 |
So I was checking prices for the parts and it looks like they are a good bit cheaper from Subaru Vs. Toyota. I also noticed that Subi has a picture of the stabilizer:
![]() This is for sure what is scratching my glass. If I pull the seal back a little and look inside the door I can see the stabilizer and it lines right up with the scratches. I just didn't realize this was the "stabilizer" until I saw the picture of it. |
| The Following User Says Thank You to ermax For This Useful Post: | Ultramaroon (12-07-2017) |
#161 |
I struggled with this last night. Even went to bed agonizing a little over it. I've tried to help explain a few times but feel like I couldn't do it justice.
It's really a goddamn counter-intuitive mechanism. Based on your description, I think you're pretty close. A few points to maybe help: 1. The front rail sets the angle of the window inboard-to-outboard. 2. Set the rear rail to follow accordingly. 3. The rear rail, along with the inner adjustable felt glides, sets the pressure at which the window pushes against those outer glides (which are the problem.) 4. I wasn't able to find a decent setting that worked for the window both open and closed so I settled for protecting the glass. With the window down there's a bit of play between the inner and outer felt glides. I put up with the rattle knowing the mechanism is happy.
#162 |
Drives: GT86
#163 |
Tried to get pics but can't get one clear enough to be of any value. I think what Ultra said is probably your best bet anyway.
#164 |
Drives: GT86
So, after several session of window adjustment and wait for rainy days, I have finally found what caused the problem for me. It was not the adjustment.
The issue was that due to the poor design of the whole mechanism, not only the guides collect a lot of dirt but also the front rubber guide of the window (that is part of the small fixed window, see attached pic). Any of these can make the window squeak in rainy days. Unfortunately, soaking with silicone did not help in my case, so I had to remove the fixed window, cleaned the rubber and the window (both were extremely dirty) and problem solved. I used 4-5 shop rags while the rubber got finally cleaned:Btw, the newest iteration of the water seals (6th maybe?) is still rubbish. There was sleety rain some weeks ago and when I opened the frozen door, a lot of fur was removed from the seal by the frozen water ingress stuck between the seal and the window: |
| The Following 2 Users Say Thank You to mausr For This Useful Post: | BRZyJ (02-24-2018), Ultramaroon (02-24-2018) |
#165 |
Interesting. Let us know how it holds up.
Learning new stuff every day.
| Pockmarks on windows? | Dang Lad | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 20 | 09-27-2012 03:52 PM |
| Remotely lower windows with key fob? | Kido1986 | BRZ First-Gen (2012+) — General Topics | 25 | 07-16-2012 10:11 PM |
| Anyone else have problems with their windows after pushing the car too hard? | track_warrior | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 06-21-2012 11:39 PM |
| Tinted Windows | koolhawk | CANADA | 20 | 06-19-2012 07:27 PM |
| Windows 7 Theme | ToyotaObsession | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 05-28-2011 03:27 AM |
