Drives: 2013 frs
any DIY for 4.56 final drive install?
im searching and searching for a final drive DIY write up
#2 |
Drives: 2015 FR-S
There's one in the DIY section. http://www.ft86club.com/forums/showt...ht=final+drive
All the pics are dead now though. |
#3 |
#4 |
Drives: 2016 White Pearl BRZ Premium
A buddy and I swapped his ratio for a 4.88 using the DIY thread and a copy of the factory manual on hand. It took the two of us (paranoid, but mechanically adept engineers) lots of time, shims, tools, checking, re-checking, re-work, pressing things on and off, and patience to get it all done and buttoned up and correct. You can do it, just take your time, measure everything, and have a proper hydraulic press handy! |
| The Following User Says Thank You to Joesurf79 For This Useful Post: | fika84 (12-05-2017) |
#5 |
Drives: GTS 86
There are plenty of instances when I thought, after spending hours on something that I should have gone to a shop to do it. And in the case of the final drive change, i did! I don't think I would have the time, the patience, tools and most likely the knowledge to do it.
A shop would charge between 300-500 AUD to do it properly here. Or you can simply search online and see who is selling one that has already been done. I went crazy with mine (micropolished, Supra bearings, etc.) |
#6 |
Patience, the right tools and the right manual is what you need. Make sure you get a press and a dial in-lb torque wrench and be ready for your car to be down for a while, unless you pick up a spare carrier to work with.
There's links out there for service manuals as well. |
#7 |
Drives: Sterling BRZ Ltd
Possible with patience, the side shims are also not included in any kit I know of. About $8 a piece.
This is the service manual for MK3 Supra, rear diff is the same. http://www.cygnusx1.net/Supra/Librar...aspx?S=RA&P=40 If you buy the Ring and Pinion from Weir they have a good install kit. There solid pinion spacer may take a little more time, but it takes the guess work out of crush sleeves.
| The Following User Says Thank You to mrk1 For This Useful Post: | jcw99 (12-06-2017) |
#8 |
Drives: 2013 frs
yeah I called my nearest shop and I'm probably just going to take it to them. I'm a big DIY guy but don't really have some of the tools required. Also i don't want to F it up.
#9 |
Drives: frs
| 4.8 final drive | drift86 | Engine, Exhaust, Transmission | 29 | 11-28-2022 12:49 PM |
| Needed: drive line shop in Houston for 4.56 final drive install - good experiences? | Joesurf79 | Southwest | 3 | 03-10-2017 12:21 AM |
| San Antonio/Austin install final drive | Zacharary | Southwest | 0 | 07-02-2016 08:09 AM |
| Final drive | tcroft91 | Engine, Exhaust, Transmission | 19 | 02-08-2016 11:09 AM |
| Shop for Final Drive install? | jaorocks1 | Southern California | 14 | 07-14-2015 12:13 AM |
