Old 12-04-2017, 12:42 PM   #4131
JoeeStacks
Drives: Brz
Originally Posted by MartyMcfly View Post
Thanks. My tuner said there's nothing in the tune for a supercharger that would alter the boost levels. He said that it may be a vacuum leak or a problem with the recirc valve. There is no electronic boost controller for superchargers, or at least not for this supercharger, so nothing in the tune that would cause intermittent boost problems. No DTCs either.
Have you tried reinstalling the supercharger system?
Daily Project: Honda s2000
Track: 707 WHP Turbo Honda Civic EG
Old: Kraftwerks Supercharged Subaru Brz
JoeeStacks is offline   Reply With Quote
Old 12-04-2017, 02:13 PM   #4132
CSG Mike
CSG Mike's Avatar
Have you tried replacing your boost gauge?
PM me some datalogs, doing the exact same thing.
Old 12-04-2017, 02:26 PM   #4133
JoeeStacks
Drives: Brz
+1. AEM has a software for data logging gauge. Maybe cross reference with the Ecutek log?
Old 12-05-2017, 08:11 PM   #4134
MartyMcfly
MartyMcfly's Avatar
Drives: FRS
Thanks for the replies!
I'll have to get some logging for it again since I have no idea which logs are which anymore.
The gauge is fine. Whenever the gauge shows low boost, the car feels stock. When it shows good boost, the car is gobs more powerful. So, this tells me that the boost gauge is working properly enough. Otherwise, I'd feel no difference in power between when it's reading low boost and when it is reading high boost. I would have blamed the boost gauge right away.
Yes. I did reinstall it actually. No dice
2018 Audi RS3 - Iroz
2005 Long Travel Tundra 4x4
2008 Long Travel Tundra 2wd
MartyMcfly is offline   Reply With Quote
Old 12-05-2017, 08:23 PM   #4135
CSG Mike
CSG Mike's Avatar
Sounds like something else is going on. Idle vacuum should be the same, regardless of anything else. If idle vacuum is different, something's going on.
Go do what you were doing in the video, and log it, and then send that to me.
Old 12-05-2017, 09:42 PM   #4136
MartyMcfly
MartyMcfly's Avatar
Drives: FRS
I'll try to replicate it and log it tomorrow. It hasn't acted up for the last 4 drives over a period of a few days.
Old 12-09-2017, 12:37 PM   #4137
MartyMcfly
MartyMcfly's Avatar
Drives: FRS
4 idle logs generated with a few revs in them. I was able to reproduce the issue exactly as in the video.
PM sent.
Thanks!
Old 01-23-2018, 02:13 AM   #4138
Calbee
Drives: B8 A4
so has anyone with the new belt kit tried it and have any reviews? im so tired of belt snapping
Calbee is offline   Reply With Quote
Old 01-23-2018, 03:51 PM   #4139
Freeze2196
Freeze2196's Avatar
Drives: 2013 Scion FRS
I ordered the 30mm upgrade 4 months ago...
Every time I call they tell me they will get stock in soon!
Funny thing is this might be the longest I have gone without snapping a belt.
Freeze2196 is offline   Reply With Quote
Old 02-24-2018, 12:19 AM   #4140
Super Dave
Stuck In a Sandbox
Drives: FRS RS1.0
Hey guys! I picked up some Innovate gauges the last few days and had a few questions... I got the Oil Temp, Oil Pressure, and AFR gauges. Where can i tap into for each of these sensors? If i recall (ive been away from my car for a few months) i should be able to tap into one of the ports in my catless JDL header for the AFR? For oil press/temp do i need an oil cooler with a sandwich plate with those ports? or is there somewhere else i can run them to? Thanks for any help
Super Dave is offline   Reply With Quote
Old 03-04-2018, 11:38 AM   #4141
Ongky
Ongky's Avatar
Drives: 2013
Just installed 3cm belt
Sent from my ONEPLUS A3010 using Tapatalk
Ongky is offline   Reply With Quote
The Following User Says Thank You to Ongky For This Useful Post:
JoeeStacks (03-04-2018)
Old 03-04-2018, 12:52 PM   #4142
JoeeStacks
Drives: Brz
30 mm belt is awesome!
Old 03-07-2018, 09:53 AM   #4143
Helios
Helios's Avatar
Drives: 2014 Red Subaru BRZ
I just ordered the upgraded 30MM belt system. Does it change the sound any? No retune required?
Helios is offline   Reply With Quote
Old 03-08-2018, 06:52 PM   #4144
Super Dave
Stuck In a Sandbox
Drives: FRS RS1.0
alright ill try asking again. I'm trying to gauge my options here, I need to figure out a solution to where to run my oil temp and pressure gauge sensors. Ive only heard bad things about the kraftwerks oil sandwich plate so id rather avoid that. should I just run the sensors to the block? or is there another sandwich plate I can use?
I asked this question to kraftwerks and to no surprise I got "Our sandwich adapter can be found here: http://skunk2.com/brz-frs-oil-filter...ooler-kit.html. As far as leaking, we have not had any issues with that."
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
