Old 12-01-2017, 05:58 PM   #1
Gio_reyes_93
Drives: 2013 frs
any DIY for 4.56 final drive install?
im searching and searching for a final drive DIY write up
Gio_reyes_93 is offline   Reply With Quote
Old 12-01-2017, 10:30 PM   #2
Impureclient
Drives: 2015 FR-S
There's one in the DIY section. http://www.ft86club.com/forums/showt...ht=final+drive
All the pics are dead now though.
Old 12-03-2017, 02:34 AM   #3
Hi ya Gio_reyes and welcome.
My short answer is to suggest you take it to a shop that knows how to do it, has the tools and shims and won't screw it up.
See how easy that is ......
Old 12-05-2017, 06:11 PM   #4
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
A buddy and I swapped his ratio for a 4.88 using the DIY thread and a copy of the factory manual on hand.
It took the two of us (paranoid, but mechanically adept engineers) lots of time, shims, tools, checking, re-checking, re-work, pressing things on and off, and patience to get it all done and buttoned up and correct.
You can do it, just take your time, measure everything, and have a proper hydraulic press handy!
Joesurf79 is offline   Reply With Quote
The Following User Says Thank You to Joesurf79 For This Useful Post:
fika84 (12-05-2017)
Old 12-05-2017, 07:00 PM   #5
Hawk77FT
Drives: GTS 86
There are plenty of instances when I thought, after spending hours on something that I should have gone to a shop to do it. And in the case of the final drive change, i did! I don't think I would have the time, the patience, tools and most likely the knowledge to do it.
A shop would charge between 300-500 AUD to do it properly here.
Or you can simply search online and see who is selling one that has already been done. I went crazy with mine (micropolished, Supra bearings, etc.)
Hawk77FT is offline   Reply With Quote
Old 12-05-2017, 07:24 PM   #6
fika84
fika84's Avatar
Patience, the right tools and the right manual is what you need. Make sure you get a press and a dial in-lb torque wrench and be ready for your car to be down for a while, unless you pick up a spare carrier to work with.
There's links out there for service manuals as well.
fika84 is offline   Reply With Quote
Old 12-05-2017, 08:19 PM   #7
mrk1
Drives: Sterling BRZ Ltd
Possible with patience, the side shims are also not included in any kit I know of. About $8 a piece.
This is the service manual for MK3 Supra, rear diff is the same.
http://www.cygnusx1.net/Supra/Librar...aspx?S=RA&P=40
If you buy the Ring and Pinion from Weir they have a good install kit. There solid pinion spacer may take a little more time, but it takes the guess work out of crush sleeves.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
jcw99 (12-06-2017)
Old 12-07-2017, 01:38 PM   #8
Gio_reyes_93
Drives: 2013 frs
yeah I called my nearest shop and I'm probably just going to take it to them. I'm a big DIY guy but don't really have some of the tools required. Also i don't want to F it up.
Old 12-07-2017, 08:45 PM   #9
Teseo
Drives: frs
Tell us how was it. Cost of labor, the time, etc.
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 12:49 PM
Needed: drive line shop in Houston for 4.56 final drive install - good experiences? Joesurf79 Southwest 3 03-10-2017 12:21 AM
San Antonio/Austin install final drive Zacharary Southwest 0 07-02-2016 08:09 AM
Final drive tcroft91 Engine, Exhaust, Transmission 19 02-08-2016 11:09 AM
Shop for Final Drive install? jaorocks1 Southern California 14 07-14-2015 12:13 AM
