Old 12-01-2017, 09:59 PM   #1
Qc86
Drives: 2017 Toyota 86 M6
Question about crackle and pop..
I was wondering how to get my car crackle and pop just for... fun.
I know with the openflash tablet you can have a special tune for it but the thing is:
I dont have OFT
I have Ecutek
Running a gruppe s uel headers and overpipe, invidia catless resonated front pipe and an invidia n1
Now the question is:
Should i get a special tune added to my ecutek so i can switch between normal and let say crackle and pop
OR
Should i change my front pipe for a none resonated (which i dont really want since i really like the sound but if i have to do it for the pop then... )
OR
Both?
Let me know what you think is the best way, what would work and what wouldnt
Tank you
Qc86 is offline   Reply With Quote
Old 12-02-2017, 02:20 AM   #2
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
You need the resonator gone
Dr. BRZ is offline   Reply With Quote
Old 12-02-2017, 03:30 AM   #3
steve99
Drives: FT86
adding pops is just as simple with ecutek as oft.
with ecutek you can just switch it in via a custom map.
you can use either a spare map mode to switch it on/off or switch it via the TRAC/VSC switches on console, ie pops only in vsc/sport mode
Old 12-02-2017, 08:55 AM   #4
Qc86
I switch map with my cruise control,
But we have 2 different answer....
My car did 3 huge pop in 8000km i think the resonator delete will help yes but if i have the tune reworked it would help a lot more .. right?
Or i can just get the tune done and if its not enough for me i delete the resonator
Old 12-02-2017, 03:17 PM   #5
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
You don't necessarily need to change to unresonated front pipe if you pull the timing enough when you let off the throttle in the tune, but it will be easier to achieve the pops/crackles with an unresonated front pipe and the system you're running.
You can use Ecutek or OFT doesn't matter, you just have to get someone to input that sort of change in your tune for you.
tyler_win_photo is offline   Reply With Quote
Old 12-02-2017, 06:21 PM   #6
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
sorry
so morning
such rice
Old 12-02-2017, 08:47 PM   #7
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
And to think I used to spend hours fiddling carburetors to keep cars from crackling and popping.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 12-02-2017, 09:05 PM   #8
FirstWinter
Drives: Car
I usually add some Rice Krispies into the fuel.
FirstWinter is offline   Reply With Quote
Old 12-03-2017, 02:28 AM   #9
Yep, back in the day ....... just cut off the ignition switch and turn it back on ..... gets you a BIG pop. The crackling comes after that, as the muffler is dragging on the road ........
Old 12-03-2017, 02:30 AM   #10
sorry
so morning
such rice
OR ....... just cross up a couple of spark plug wires ........
Old 12-03-2017, 01:49 PM   #11
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
The resonator has nothing to do with pops and bangs. At all. Look up what a resonator does.
I've played with this (OFT, but Ecutek can do it just as easy) and the hardware that silences pops and bangs are cats and your axleback. Even with cats you can get some pops and bangs, but a muffler kills the sound.
I recently experimented with making pops and bangs (going by the instructions in that thread) and tried a few different things, playing around. Then I wanted to go back to the stock stage 2 OTS tune for a 900 mile road trip to the Tail of the Dragon. Just to quiet the car down for the long trip. But my OFT screen broke and I didn't have time to get another or fix it so I took the trip with my loud ass pops and bangs tune. I had a Berk muffler delete too, so it was LOUD. So I strapped on the OEM muffler. What popped and banged like crazy before, barely made any noise after.
Leave the resonators alone. Get rid of the cats. Lose the muffler. Tune it.
guybo is offline   Reply With Quote
Turn Signal Relay Question (Dumb Question) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 3 06-23-2017 01:58 AM
Snap, crackle, pop over 70mph FRiSson Issues | Warranty | Recalls / TSB 13 03-25-2015 08:59 AM
Cat or axle back with the most snap, crackle and pop? tawheed Engine, Exhaust, Transmission 4 08-20-2014 02:55 AM
Stock speakers wearing out already? Crackle and pop! A few questions as well... dem00n Electronics | Audio | NAV | Infotainment 2 04-13-2013 01:53 PM
Exhaust crackle and pop? Kiwi Engine, Exhaust, Transmission 19 03-22-2013 03:14 PM
