#4313 | |
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
This is the unit that I switched to. Hope this can help someone. I've always had good luck with Forge products. |
| The Following User Says Thank You to axelthrasher For This Useful Post: | mrg666 (11-28-2017) |
#4314 | |
CSG experimented with many aftermarket intercoolers, and was unable to find one that increased output over the provided FMIC without incurring a substantial cost (and consequently, not being even close to worth it). |
| The Following User Says Thank You to CSG Mike For This Useful Post: | mrg666 (11-28-2017) |
#4315 | |
pessimistic skeptic
If you want to fine tune the recirculation valve, you could try this Before anything read carefully JR's recent response on this topic. |
#4316 | |
Drives: 2015 Subaru Brz
#4317 | |
Drives: 13 BRZ
I'm not planning to change my setup for awhile but it seems like a good solution if you were upgrading to run really high boost. Seems to eliminate the trail and error of picking the correct spring - valve combination. Do you think it would work with the JRSC system? |
#4318 | |
pessimistic skeptic
Either use a valve compatible with the original design, or leave it alone before damaging your compressor, imho.
#4319 | |
Heres a link: https://www.amazon.com/gp/aw/d/B01N6...WDL&ref=plSrch |
| The Following User Says Thank You to Brzxton For This Useful Post: | Jmonty (12-02-2017) |
#4320 |
Drives: 2014 FR-S
I used this as a replacement recirc valve and it is fantastic, much smoother than my failing stock recirc valve.
Its a direct fit, and made of metal. https://www.amazon.com/RKX-Precision...diverter+valve |
#4321 | |
#4322 |
#4323 |
Drives: 2017 BRZ PP
Are there any updates on the development for the 2017 BRZ/86’s?
#4324 | |
You may want to pre-order a kit from @CounterSpace Garage. |
#4325 |
Famous Potatoes
Drives: '15 ultramarine
My replacement was covered by warranty. From the time I emailed to replacement was a month.
#4326 | |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
