Old 11-28-2017, 10:13 AM   #4313
axelthrasher
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
Originally Posted by Brzxton View Post
You think this atmospheric bov would work?
https://www.ecstuning.com/b-cts-part...0aAi0gEALw_wcB
Its made for the same car the other diverter valves were made for, but im not sure how atmospheric vs recirculated will affect it.
https://www.forgemotorsport.com/Turb...duct--756.html
This is the unit that I switched to. Hope this can help someone. I've always had good luck with Forge products.
axelthrasher is offline   Reply With Quote
The Following User Says Thank You to axelthrasher For This Useful Post:
mrg666 (11-28-2017)
Old 11-28-2017, 12:43 PM   #4314
CSG Mike
CSG Mike's Avatar
Would i be a downgrade? I was always told the bigger the better when it comes to intercoolers
You're not going to significantly lower charge temperatures, but you will have a larger volume to fill, and have a larger pressure loss, ultimately resulting in a loss of power.
CSG experimented with many aftermarket intercoolers, and was unable to find one that increased output over the provided FMIC without incurring a substantial cost (and consequently, not being even close to worth it).
mrg666 (11-28-2017)
Old 11-28-2017, 03:31 PM   #4315
mrg666
pessimistic skeptic
mrg666's Avatar
I am not sure if it would work. But I don't see any advantage of converting recirculation valve to a blow off valve either. It might change the sound a bit.
If you want to fine tune the recirculation valve, you could try this
Before anything read carefully JR's recent response on this topic.
Old 11-28-2017, 06:20 PM   #4316
Brzxton
Drives: 2015 Subaru Brz
Yea main reason would be sound. Just was wondering if the atmospheric bov would work because i have to upgrade mine either way so if i could use the atmospheric that woukd be sweet. But i wouldnt mine just upgrading to the rkx like you and a few other people have.
Brzxton is offline   Reply With Quote
Old 11-29-2017, 10:44 AM   #4317
rns294
Drives: 13 BRZ
Originally Posted by Jackson Racing View Post
We recommend running a recirculation valve for best transient response and emissions compliance for street vehicles. The most important thing to remember is make sure you run the SOFTEST spring on a "adjustable spring" valve. The vacuum connection should be controlling the valve, not the spring. Too much spring pressure will not allow the engine vacuum to properly pull the valve back. This causes compressor surge and will damage the Rotrex unit.
Hey JR, do you have any thoughts on this product in conjunction with a different recirculation valve on the JRSC: https://www.forgemotorsport.com/Inta...uct--1060.html
I'm not planning to change my setup for awhile but it seems like a good solution if you were upgrading to run really high boost. Seems to eliminate the trail and error of picking the correct spring - valve combination. Do you think it would work with the JRSC system?
rns294 is offline   Reply With Quote
Old 11-30-2017, 02:12 PM   #4318
mrg666
pessimistic skeptic
mrg666's Avatar
I wouldn't just do bov for sound. It will probably be smelly too Either use a valve compatible with the original design, or leave it alone before damaging your compressor, imho.
Old 11-30-2017, 04:19 PM   #4319
Brzxton
Nvm i found a rkx splitter valve which will work as both a bov and a recirculating valve its pretty cool actually.
Heres a link: https://www.amazon.com/gp/aw/d/B01N6...WDL&ref=plSrch
The Following User Says Thank You to Brzxton For This Useful Post:
Jmonty (12-02-2017)
Old 12-01-2017, 02:25 PM   #4320
GenRuleAThumb
GenRuleAThumb's Avatar
Drives: 2014 FR-S
I used this as a replacement recirc valve and it is fantastic, much smoother than my failing stock recirc valve.
Its a direct fit, and made of metal.
https://www.amazon.com/RKX-Precision...diverter+valve
GenRuleAThumb is offline   Reply With Quote
Old 12-02-2017, 01:57 AM   #4321
Brzxton
Yea i got that one except its a splitter version where there is a screw on piece that either makes the valve a full recirculation or full bov.
Old 12-02-2017, 01:59 AM   #4322
Brzxton
And also im on e85 so my gas smells like cotton candy
Old 12-04-2017, 04:14 AM   #4323
kimcheefists
kimcheefists's Avatar
Drives: 2017 BRZ PP
Are there any updates on the development for the 2017 BRZ/86’s?
kimcheefists is offline   Reply With Quote
Old 12-04-2017, 01:10 PM   #4324
CSG Mike
CSG Mike's Avatar
"soon".
You may want to pre-order a kit from @CounterSpace Garage.
Old 12-04-2017, 10:47 PM   #4325
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
My replacement was covered by warranty. From the time I emailed to replacement was a month.
Old 12-05-2017, 09:43 AM   #4326
Brzxton
Can you show a picture of how you installed it? I installed mine but udk if i did it right because all i get a bunch of turbo flutter.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
