Old 11-29-2017, 01:22 PM   #29
Somerandom18
Drives: 2017 manual BRZ
Expensive NA Porsches have dips too.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
The Following 2 Users Say Thank You to Somerandom18 For This Useful Post:
Irace86.2.0 (11-30-2017), strat61caster (11-30-2017)
Old 11-30-2017, 12:59 AM   #30
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by gtengr View Post
They would have a similar discrepancy in flywheel horsepower too. FI takes hp to operate but it's not the same as drivetrain losses.
Drivetrain losses seem to be a percentage of horsepower. Spinning a supercharger is probably more of a fixed number. Big blowers might take 200hp to turn. Small ones much less. Regardless, a turbo will show higher whp for a given engine hp.
Originally Posted by 86 South Africa View Post
Lol. No manufacturer would do this on purpose.
The torque dip is the nexus of emissions and global laws Toyota had to meet combined with building a “cheaper” sports car.
More time and money (& a change in design) and they’d probably solve this.
Just headers + a tune remove the dip.
Yeah it is there for emissions and gas mileage probably mostly. I’m just suggesting it could be a good thing, and if so perhaps designed.
Old 11-30-2017, 10:39 AM   #31
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
A bit off topic, but a top fuel drag car takes 600hp to turn their monster super chargers.
Mind blowing!
I like driving!
86 South Africa is offline   Reply With Quote
The Following User Says Thank You to 86 South Africa For This Useful Post:
Somerandom18 (11-30-2017)
Old 11-30-2017, 09:30 PM   #32
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Originally Posted by guybo View Post
You said you only wanted around 250 at first (that's how everyone starts out).... pushed it to 278... now you want 350.... or 400.... then what? Either you blow the engine or want more. There's no stopping.
From all the threads I have read here, 278 is about the safe limit, then you will start to break shit. There's not only the engine and fueling, but driveline, gearbox, tranny etc etc. You're going down a rabbit hole that can only be filled with money.
So the only answer is- the stock engine will take however much money you want to shovel inside of it.
Fk that hole, grab a shovel! I'm in, lol!
Turbo kit being fabricated. I will be trying to stick with 8-12 boost internals permitting. Planning to update rods and pistons. I don't want insane. I just want boost and reliability, as much as possible. But I run the car hard 110% : (.
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 11-30-2017, 10:50 PM   #33
whataboutbob
AutoX-10/10ths every run
^This.
Build thread:Here
Old 12-01-2017, 10:33 PM   #34
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Originally Posted by ajc209 View Post
160WHP stock and 250WHP boosted - much more than that and its a bit of a lottery if you have good set of rods or not.
This is the correct answer.
I ran 260WHP for two years, heavy track use no problems. Upped to 320 and lost two engines due to rods. Now back to 260.............
Sleepless is offline   Reply With Quote
The Following 2 Users Say Thank You to Sleepless For This Useful Post:
ajc209 (12-02-2017), choiboie (12-02-2017)
Old 12-02-2017, 12:13 AM   #35
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
The general information I have gathered is that it will handle about 280whp reliably on the stock engine with proper tune and fuel, but it requires a few supporting mods such as clutch and oil catch can, and possible cooling. Beyond that you are looking at replacing your connecting rods, which are the weakest part of your engine. You should get forged pistons and bearings done at the same time.
The shop near me called AWD Tuning does those 3 things to support 500hp. Beyond that you are looking at sleeves and possible head work.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 12-18-2017, 01:20 AM   #36
Kalebhall
Drives: 2013 Subaru BRZ limited
Originally Posted by FRS Justin View Post
push until you find the happy spot or blow it up, no worries as long as you have 7k I will sell you a built fa20
Is it fully built?
Kalebhall is offline   Reply With Quote
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 02:22 AM
What is good boost for the FA20 now? Exhaust Forced Induction 16 12-05-2015 09:52 PM
How much extra hp/trq can the stock tires handle sci3 Scion FR-S / Toyota 86 GT86 General Forum 7 10-31-2015 02:36 PM
How much can stock drive shaft handle?? Argento_FR-S Forced Induction 24 06-01-2013 08:54 PM
FA20 Fuel lean at high boost fix cf6mech Forced Induction 15 05-20-2013 04:33 PM
