Old 11-28-2017, 05:35 PM   #1
8686guy
CEL - P0016 - Quick Question
So I now have the pain in the butt P0016 code.
Long story short:
August - Car was stock, got P0018, Dealer replaced the Cam gear and ECU
September - All's good and a EB Supercharger goes on the car, drive for 500ish miles, and I get a P0016 code.
I've done some looking and I'm hoping since the ECU and Cam gear was replaced already, that I don't have to do it again...
: I swapped oil/ ran some detergent through the car
: Cleaned the sensor
: I swapped sensors to see if the code followed, it didn't
Other items of note:
I am being tuned via ECUTEK
I'm running 5W30 Synthetic
Short of the exhaust and supercharger the car is mechanically stock.
I guess my question for those who have dealt with the issue before is where do I go next in my testing?
Is it possible to "Tune" out the code all together?
I imagine taking it to the dealer with the supercharger isn't an option...
Your thoughts are appreciated.
Thanks.
8686guy is offline   Reply With Quote
Old 11-28-2017, 05:43 PM   #2
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Why did you switch to 5w30? It's not the recommended weight and can cause all kinds of issues
guybo is offline   Reply With Quote
Old 11-28-2017, 05:56 PM   #3
8686guy
Well to be honest, the shop who installed the supercharger put it in there and I kept the same weight they did. I'll need to look into this.
Old 11-28-2017, 08:09 PM   #4
Don't bother with the sensor. Swap the solenoids. The manual calls them oil control valves but they aren't actually the valves.
Look in my sig line for the service manual.
It's not the ECU.
Old 11-28-2017, 09:02 PM   #5
8686guy
It's not the ECU.
Thanks for the reply Maroon, I reviewed the doc. I wasn't clear I did switch the oil control valves. Not just the sensors.
Old 11-28-2017, 10:00 PM   #6
Assuming that you cleared the code and observed it reappear, I suspect the actual valve in the gear is contaminated and jammed like it was previously on the other side.
If you have techstream you can manually slew each of the camshafts in both directions to test.
Old 11-28-2017, 10:45 PM   #7
8686guy
Awesome. I did and I'll look in to trying that.
Old 11-28-2017, 11:16 PM   #8
I posted my experience with this issue here. OP hasn't yet updated.
Old 11-29-2017, 02:53 PM   #9
Icecreamtruk
Drives: Track preped NA FRS
I support @Ultramaroon in this idea.
This may be pure coincidence, but the time I had P0016 was after I switched to 5W30 oil. I wanted to compare oil temps and pressures (btw, not worth it if you have oil cooler, 0W20 gets the job done). Something to think about maybe.
Icecreamtruk is offline   Reply With Quote
The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post:
davidsn_670 (05-17-2018), Ultramaroon (11-29-2017)
Old 11-29-2017, 03:36 PM   #10
8686guy
Yeah going to change out the oil again see if that helps.
Old 05-17-2018, 05:50 PM   #11
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
What is the part # for the replacement ECU for a BRZ?Are there any other items needed along with this? for the record this is a 2013 limited 6 speed. Do I replace with a newer ECU?
Jmonty is offline   Reply With Quote
Quick question TRD CAI Packofcrows Issues | Warranty | Recalls / TSB 8 06-21-2017 01:55 PM
OFT P0016 and TSB question mmmcambelsoup Software Tuning 10 05-24-2017 10:24 AM
Quick Question BRZUK Scion FR-S / Toyota 86 GT86 General Forum 11 11-07-2014 11:48 PM
Quick Question??? soontobrz BRZ First-Gen (2012+) — General Topics 12 12-16-2012 12:02 PM
Quick question.... be6sti Engine, Exhaust, Transmission 8 11-04-2012 10:53 PM
