Old 11-17-2017, 07:18 PM   #85
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by mrg666 View Post
Let me ask this way. Suppose you are not drag racing but you will try to brake a speed record for your car and you have access to a very long straight track. The length of the track is not going to limit your end speed. What final drive gear would you choose for your 700+ hp car? I would choose the smallest final drive I can, i.e. less than 4.1. Am I wrong?
You'd pick the final drive that allowed the engine to be at (or just past...) it's peak horsepower at the same time the car arrives at it's drag-limited (both aerodynamic and parasitic) top speed for the power produced. This, however, does not necessarily produce a vehicle that is relaxing to drive and fuel efficient under normal conditions. This why our gearing allows for a theoretical top speed of something like 170mph in 6th based on gearing alone, but the stock car would never ever achieve that unless it was pushed off a cliff. Stock gearing is too tall to pull peak rpm in 6th with the power it produces.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following 2 Users Say Thank You to venturaII For This Useful Post:
ermax (11-17-2017), FRS Justin (11-17-2017)
Old 11-17-2017, 07:35 PM   #86
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Originally Posted by FRS Justin View Post
weir performance in American canyon cali sells anything you need for gearing and does installs, Ive used them and never been disappointed. Mark Spencer in NH also does gear setups if on the east coast and he's awesome too.
Both of these guys (Spence Weir and Mark Spencer) are awesome but Mark doesn't do diff's any longer.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Old 11-17-2017, 07:53 PM   #87
FRS Justin
Drives: 2013 Asphalt FRS
to a degree yes you are correct but you cant just say the lowest number you can find like a 2.73. example. car one is a stock N/A frs 148whp bone stock in the salt flats to reach top speed you would need a 3.55 gear ratio and 10m miles of track to hit 175mph (totally hypothetical numbers)car 2 is a turbo frs with 700hp on same track you could use a 2.73 and hit 300mph both the cars have the same aero same weight same everything except hp rating. my point is drag v/s hp will depend on the gear ratio needed to obtain max speed. yes lower number ratio has the POETENTIAL for higher mph but factors such as drag and hp dictate the limits for the ratio best suited.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
mrg666 (11-17-2017)
Old 11-17-2017, 09:40 PM   #88
mrg666
pessimistic skeptic
mrg666's Avatar
I agree, I don't know why we had to disagree in the beginning. Thanks for stopping by.
Old 11-17-2017, 09:43 PM   #89
ermax
ermax's Avatar
10 million mile track. 😉
Old 11-17-2017, 09:44 PM   #90
ermax
ermax's Avatar
You are obviously still confused.
Old 11-17-2017, 09:46 PM   #91
ermax
ermax's Avatar
Well explained. So all but one person in this thread is on the same page.
Old 11-18-2017, 07:20 AM   #92
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
EDIT
You want facts here you go, My N/A car 13.74 @ 101mph 4:10 gears 13.47 @ 104 mph with 4:56 gears in the quarter,
Did you have a higher rev limiter in this N/A car? Let's say @7600?
Old 11-18-2017, 08:11 AM   #93
ermax
ermax's Avatar
That isn’t really relevant to the stock power output. We will never hit redline in top gear with stock output. Not on the 4.3 gear that this thread was originally discussing.
Old 11-18-2017, 09:21 AM   #94
gtengr
Drives: 2017 BRZ
As an aside, and maybe something else we can all argue about, my calcs indicate that it would take ~280 rwhp to redline 6th with the 4.30's. That is based on rolling resistance and aero drag that fits the stock top speed, but the usual disclaimers that come with using the same rolling resistance and drag coefficients at different speeds.
gtengr is offline   Reply With Quote
Old 11-18-2017, 10:06 AM   #95
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I was asking for the 1/4-mile times and more specifically the redline limiter of 4th gear. Not about the top speed. Just curious..
Old 11-18-2017, 10:18 AM   #96
gtengr
Drives: 2017 BRZ
Yeah that would've been higher redline or non-stock tire diameter. Doubt he was shifting to 5th.
The Following User Says Thank You to gtengr For This Useful Post:
nikitopo (11-18-2017)
Old 11-18-2017, 08:31 PM   #97
FRS Justin
I don't remember my final rpm in the qtr but it wasn't at redline, man that's been awhile lol
710whp
nikitopo (11-19-2017)
Old 11-18-2017, 08:32 PM   #98
FRS Justin
ya I was in 4th
710whp
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Lexus is300 diff swap M98 3.91 ogrowup Engine, Exhaust, Transmission 5 02-28-2017 10:45 AM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 02:59 PM
RR Diff swap Triumphrider Engine, Exhaust, Transmission 25 10-21-2014 08:34 PM
Diff swap help wootwoot Engine, Exhaust, Transmission 30 06-10-2013 11:05 AM
