Old 11-16-2017, 08:35 PM   #631
Ribface
Drives: 2014 FR-S Hot Lava
It's halfway between DS and STX pax. Look like a good starting point to me.
Ribface is offline   Reply With Quote
Old 11-16-2017, 10:03 PM   #632
DaWorstPlaya
Drives: 2016 FR-S
Originally Posted by iLuveKetchup View Post
That soft pax looks like they picked a spec tire slower than the Nexens. That would blow chunks!!!
Here's to hoping it's RE71Rs.
DaWorstPlaya is offline   Reply With Quote
Old 11-16-2017, 10:04 PM   #633
M0nk3y
Spec Twin?
Don’t get your hopes up.
You can pretty much cross out Rivals or RE-71Rs
Kyle H. - #89 STX
Old 11-17-2017, 12:36 AM   #634
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Too good to be true. I’m waiting for the catch.
No way will it be REs. Sounds like a new Falken tire.
iLuveKetchup is offline   Reply With Quote
Old 11-17-2017, 01:56 AM   #635
tony_r
tony_r's Avatar
Drives: '15 STX
So the Z2SS then? Because they're the same compound. I hated that tire.
tony_r is offline   Reply With Quote
Old 11-17-2017, 03:43 AM   #636
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Source? That's interesting, though.
G_Ride is offline   Reply With Quote
Old 11-17-2017, 09:49 AM   #637
TrqlessWonder
Drives: 2014 FR-S
And expected to be just a whisker faster than the ND. That feels like a bit of a reach for something that is not very different from a CS FR-S.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
The Following User Says Thank You to TrqlessWonder For This Useful Post:
strat61caster (11-17-2017)
Old 11-17-2017, 09:58 AM   #638
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I expect the 8" wheels and camber to make it faster than my CS setup was. (on Rival S or RE71)
The alignment is a PITA too. The rear has a lot of cross-talk between toe and camber so we had to keep going back and forth between the two. The front gets a good chunk of camber from slop but it's not a simple matter of just maxing it out because of clearance issues. (At least with the rivals)
Twinz is offline   Reply With Quote
Old 11-17-2017, 11:57 AM   #639
tony_r
tony_r's Avatar
Drives: '15 STX
It's on that one forum somewhere. You can probably ask Mike Maier, too.
I'd be interested in doing a true test with the CS ND and the SSC car. I drove them back to back and put down extremely similar times on a 60s course. I think they're both just as fast as one another. PAX is "accurate" given similar tires. I drove both cars with 225 Rival S.
Yeah, the ND is just that fast.
The Following User Says Thank You to tony_r For This Useful Post:
Old 11-17-2017, 12:02 PM   #640
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
idk I read that pax as 'give an 86 a better alignment and it's actually on par with an ND'
No way is a lame tire on an SSC prepped 86 going to run times with CS
The SSC kit isn't STX-lite, it's a Street+
ineedyourdiddly
Racecomp Engineering (11-17-2017)
Old 11-17-2017, 12:11 PM   #641
tony_r
tony_r's Avatar
Drives: '15 STX
On certain courses, it is STX-lite. It handles very similarly with a tad more roll. So long as you don't spend a lot of time in the torque dip they will be pretty close to each other.
I've driven a few STX cars, the CS trim, DS trim and now the SSC car. It certainly handles more closely to an STX car without the power, since you don't have to tip toe around a junk front end.
Old 11-17-2017, 12:36 PM   #642
strat61caster
Most definitely this is the biggest performance enhancer available with the SSC goodies. You're probably right and I'm underestimating how quick an SSC car is with good rubber if the alignment is there.
You've alluded to getting over -3 degrees of camber on an SSC car I think, but it's not by much right?
After seeing you drive Rich's car at Round 1 this year I have no doubt you know what you're talking about.
ineedyourdiddly
Old 11-17-2017, 12:50 PM   #643
tony_r
tony_r's Avatar
Drives: '15 STX
Close to -3.5 with +40.
Old 11-17-2017, 01:35 PM   #644
G_Ride
G_Ride's Avatar
I keep forgetting that Mike runs Falkens. I'll have to ask him.
I agree, it will all depend on what tire SSC runs.
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 01:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 09:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 11:20 AM
