Old 11-14-2017, 07:17 PM   #1
monkeybike
Drives: 86
2018 6AT spec? 205hp engines?
I am thinking of picking up a '18 6AT next year.
3 hours a day in peak hour traffic getting to work blah blah blah....... it's going to be a 6AT.
Has there been any indication that the '18s might get the high spec 205hp engines like the MT or will they be stuck with the older 200hp?
Seems pretty stupid. I initially thought they automatics had the older spec due to a surplus of older parts and it was only going to be for the first few batches of Koukis. Paying extra for the automatic with the lower spec engine isn't my idea of fun.
monkeybike is offline   Reply With Quote
Old 11-14-2017, 07:20 PM   #2
funwheeldrive
I'm pretty sure the 2018 BRZ is available for order already and I never heard of the automatic getting the revised engine. I doubt the 86 would be any different.
Old 11-14-2017, 07:34 PM   #3
monkeybike
Drives: 86
That would be bad.
Have Toybaru ever given a reason for the lower spec in the 6AT?
Surely it can't be to protect the drivetrain from an additional 5hp.
Old 11-14-2017, 08:03 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Why would they? As mentioned in another thread, this is a niche car for an already niche market. They don't need to explain a great many things to something that covers less than 1% of their entire global portfolio.
If I were to speculate, I'd speculate the tradeoff from good fuel economy (torque dip) + automatic transmission shifting efficiency + other factors regarding transmission warranty provided by Aisin and emissions requirements meant that the AT engine had to be based on the old spec/old tune.
They wouldn't make two versions of the same engine if there wasn't a really good reason, I'm guessing emissions and government test cycles plays a huge part of this.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
EdBoy (11-14-2017), Tcoat (11-14-2017)
Old 11-14-2017, 08:15 PM   #5
monkeybike
Drives: 86
-alex
That's why I'm puzzled.
It's a niche of a niche of a niche and they are maintaining two distinct spec engines. Seems over complicated and expensive for something pretty insignificant in their global strategy as you say.
Old 11-14-2017, 08:23 PM   #6
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
That would be bad.
Why would it? Aftermarket interest in the 17 engine seems to be DOA. Options for the "original" engines are endless.
PetrolioBenzina is offline   Reply With Quote
Old 11-14-2017, 08:39 PM   #7
mav1178
mav1178's Avatar
Again, they won't give a reason for this.
It also simply could have been that to make this car, Subaru needed to produce X amount of engine blocks, and that the reason why there's two blocks is simply to sell off existing production units from the first run.
A lot of OEMs would stipulate MOQ to produce item(s), even for large customers like Subaru or Toyota.
Who knows, no one at Toyota will give you the answer you want.
Old 11-14-2017, 08:56 PM   #8
Veloist
Veloist's Avatar
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
They aren’t changing the engine for the 6AT so I would take advantage of Toyota’s incentives right now for the 86...either 0% APR for 72 mos or $1500 rebate plus dealers wanna get rid of the Auto let alone the 86, so you’ll save a lot more.
Only advantage with going with a 18 BRZ is apple car play and android auto. You can’t order them yet.
Veloist is offline   Reply With Quote
The Following User Says Thank You to Veloist For This Useful Post:
Tcoat (11-14-2017)
Old 11-14-2017, 09:06 PM   #9
Nope. It would be cheaper for them to buy out the contract than to have line complexity to carry two engines. They wouldn't over estimate the number of engines needed by 50% of a whole model year either.
The AT engine internals and blocks have almost all of the same updates as the MT engine. It is really just the intake, manifold and header that are still the old style on the AT not the whole engine.The European spec MT also still use the old fuel system and header.
My guess remains that the difference with the AT is something related to emission control and millage requirements.
Adam_L (11-15-2017), Lonewolf (11-16-2017), mav1178 (11-14-2017), Veloist (11-15-2017)
Old 11-14-2017, 09:17 PM   #10
monkeybike
Drives: 86
Are you saying the AT got the new pistons, block ribbing, valve assembly etc etc as the MT engine? I hadn't heard that. I thought they were distinctly different short blocks. If it's only the bolt ons then that's not too bad. The header and intake are usually replaced anyway.
Old 11-14-2017, 09:24 PM   #11
Oh, heck ....... with 3 hours a day in stop and go traffic, you wouldn't notice the additional 5 HP anyway ........ just be happy ......
EdBoy (11-14-2017)
Old 11-14-2017, 09:26 PM   #12
Yep that is exactly what I am saying. The only exception to the internals is that only the MT got the hardened pistons. The AT and European spec got all the other internal changes. The AT engines are not the "old" ones they just didn't get all of the new parts. Take a look at the "Applicable to" section of what I attached.
Old 11-14-2017, 09:32 PM   #13
monkeybike
Drives: 86
Thanks for the info. I could live with that if it comes to it, that's pretty good then.
The Following User Says Thank You to monkeybike For This Useful Post:
Tcoat (11-14-2017)
Old 11-14-2017, 09:35 PM   #14
It is pretty deceiving since everybody refers to it as the "old" engine. It really is just a slightly different version of the new engine.
humfrz (11-14-2017)
2018 BRZ STI raven1231 FR-S / BRZ vs.... 19 06-26-2017 11:39 AM
Where are the 2018's ??? ~el~jefe~ FR-S / BRZ vs.... 41 05-24-2017 12:03 PM
VR6 engines... dem00n Other Vehicles & General Automotive Discussions 29 01-25-2013 01:41 AM
100 hp/l NA engines einzlr Other Vehicles & General Automotive Discussions 95 11-15-2012 07:55 PM
So you think you know engines? Ryephile Other Vehicles & General Automotive Discussions 43 02-04-2012 03:49 AM
