Old 11-07-2017, 07:53 PM   #15
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Shifts seem to get rougher around the 35-45k mark on OEM fluid. Havent had the some reaction on Redline ATF anywhere near as often, though I also do 30k intervals if I have driven the car hard and 45k if no track days and minimal canyon driving.
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
nos145 (11-14-2017), VoltsFRS2013 (11-07-2017)
Old 11-07-2017, 07:56 PM   #16
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
I have never tracked the car (at least under my ownership as im the 2nd owner)
Around 55-60k i plan on doing a transmission service. Just going by what the book tells me
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 11-08-2017, 12:17 PM   #17
finch1750
finch1750's Avatar
Fair enough, just wanted to share my experiance. I have used the OEM fluid twice and each time it starts to shift rough more often well before the 60k interval which is why I change early. For reference I am at 136k miles and about to have my ATF changed for the 5th time in another 9k or so.
But definitely consider Redline over OEM as it has held up much better imo. There is a thread on ATF somewhere to get others feedback as well, just make sure you use the correct Redline
nos145 (11-14-2017), VoltsFRS2013 (11-08-2017)
Old 11-08-2017, 12:28 PM   #18
VoltsFRS2013
For sure. Around 50k i'll probably have it tinkered with then! I plan on taking the car to toyota to have them mess with it so I'll probably have to end up using oem fluid. I dont trust myself enough to try to do a fluid swap
Old 11-08-2017, 12:44 PM   #19
finch1750
finch1750's Avatar
Not sure where in VA you are but PTuning would be worth looking into for a reputable private shop vs. going to the dealer
Old 11-09-2017, 12:03 AM   #20
VoltsFRS2013
PTuning is 20 mins away
Old 11-14-2017, 05:05 PM   #21
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
If I were you, I would NEVER take my car anywhere but PTuning. Just saying.
nos145 is offline   Reply With Quote
The Following User Says Thank You to nos145 For This Useful Post:
VoltsFRS2013 (11-14-2017)
Old 11-14-2017, 05:07 PM   #22
VoltsFRS2013
For sure. Ptuning hosted 86Expo and i got to check then out then. Its either going to ptuning or the dealer.
Old 11-14-2017, 05:09 PM   #23
nos145
Cognite
nos145's Avatar
Also, if you feel the tranny getting jerky, put it into SNOW mode for the first 5-10 mins of driving. Helps a lot with the quality of drive in those moments.
Old 11-14-2017, 05:13 PM   #24
nos145
Cognite
nos145's Avatar
dealer will take 2x more and do 2x-4x shittier job. guaranteed.
start going to ptuning and chatting them up. bring a big jug of StarBux coffee and the variety pack of their strudels when you come in for big jobs.
you will be known as the "cool guy with the snacks" and trust me, your car will get the golden treatment.
treat them like kings, they will treat you like a king.
Old 11-14-2017, 05:18 PM   #25
VoltsFRS2013
Ptuning is great and I'll be most likely taking it there. I think they quoted me between $225-$275 last time I called and checked. Also about the snow mode thing, is it like harmful at all to run it in snow mode like that? I've considered using snow mode in creeping traffic but didn't want to mess with it. If I'm driving carefully and slow for the first 5-10 minutes is it like okay to just leave it in snow while it warms the transmission up?
The Following User Says Thank You to VoltsFRS2013 For This Useful Post:
nos145 (11-14-2017)
Old 11-14-2017, 05:29 PM   #26
nos145
Cognite
nos145's Avatar
Smile
I drive about 50% of time in snow mode (year round), it shifts QUICKER (aka the shifting points are set to lower RPM) and it doesn't go into 1st gear.
I do this because most of the time I want a super smooth, chill ride with 0 jerks. Literally drives like a Caddy.
I would do following: start car up, let the RPMs drop (i always do this, sometimes takes fkn 3mins), go out on street, as soon as you feel it hit 2nd gear, press SNOW MODE on button. You are golden.
Technically, it should be safe to go in and out of the snow mode at any time due to how the auto trannies work, but I always switch in/out of it while the car is in 2nd+ gear (there is a fallacy here if you want to put it into R).
My recommendation would be to give it a go tonight and see how it feels.
Old 11-14-2017, 05:36 PM   #27
VoltsFRS2013
Why wouldnt you just let it warm up for those 3-4 minutes in snow mode then drive? also what is the error with going into reverse in that mode?
Old 11-14-2017, 05:42 PM   #28
nos145
Cognite
nos145's Avatar
absolutely none. hence the fallacy of my reasoning.
I just never did it before.
So, for science, and you, I will go test it out right now and post in 45 mins when i am back from my short drive.
Automatic Transmission devinclfalcons Engine, Exhaust, Transmission 60 04-29-2014 09:42 PM
Automatic transmission question carbonBLUE Engine, Exhaust, Transmission 11 11-30-2012 10:29 AM
Automatic Transmission :( Almighty Bob Southern California 14 11-06-2012 01:13 PM
Which transmission do you have ? Manual or Automatic ? PRO Import Tuners Engine, Exhaust, Transmission 14 08-24-2012 09:21 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
