Old 11-13-2017, 11:46 PM   #1
JOE APO
Drives: Blue Man FRS
2017 diff swap
Has anyone attempted to swap out their stock differential with the new 2017 rear diff? I've been thinking about doing this to mines due to the more aggressive gear ratio,but i'm not sure if the new diff has different dimensions that would cause some sort of issues. If you've tried this or have some insight, comment below. Thanks guys!
JOE APO is offline   Reply With Quote
Old 11-14-2017, 08:26 AM   #2
You don't need to swap the whole diff. There are final gears available that you use with your current one.
http://www.ft86club.com/forums/showthread.php?t=66866
stevesnj (11-14-2017)
Old 11-14-2017, 08:44 AM   #3
mrg666
pessimistic skeptic
mrg666's Avatar
Final drive replacement is a tradeoff, not really a power upgrade. Your engine will be working harder to do the same work. Acceleration will be quicker but sustained speeds will be at higher rpm. You might like it in the city since the car will feel quicker. But freeway driving will be worse; engine will be running at higher rpm on freeway, it will be noisier, and gas mileage will be lower. Even on track, you will be compromising your top speed for acceleration.
You want more power. So the right solution is getting more power. I recommend one of the followings.
- header + tune
- forced induction
If I had the 2017, I would go back to 2016 final drive and upgrade with FI again.
The Following User Says Thank You to mrg666 For This Useful Post:
Teseo (01-21-2021)
Old 11-14-2017, 08:58 AM   #4
stevesnj
stevesnj's Avatar
Final drive is a great way to go. It's a great analogue upgrade that is simple and effective as is the trans gear upgrade they did in the 2017's. The combination should net noticeable results. The 2017's have 4.33 gears now I believe. Not everyone needs to go FI. What is your goal with the car?
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Tokay444 (11-14-2017)
Old 11-14-2017, 10:03 AM   #5
mrg666
pessimistic skeptic
mrg666's Avatar
Old 11-14-2017, 10:10 AM   #6
stevesnj
stevesnj's Avatar
Originally Posted by mrg666 View Post
What don't you understand?
Old 11-14-2017, 10:40 AM   #7
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
If you can get one out of a totaled car, great. Otherwise it can be much cheaper to change gears in your existing differential...
Note: the 2017 only went from 4.10 to 4.30, and only on the manual cars.
This small of a change is very, very subtle. I went all the way to 4.56 and I sometimes wish I had gone to 4.88 on my manual daily driven car. I personally would not think the change to 4.30 is worth the expense.
Gas milage takes a very small hit. With AC off, level freeway driving I still get 32 US MPG. Overall I average 26 mixed city/highway.
Engine turns faster, but benefits from mechanical advantage - e.g. it may actually be under less stress.
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
The Following 4 Users Say Thank You to nextcar For This Useful Post:
brandonblt2 (06-14-2018), fika84 (11-14-2017), stevesnj (11-15-2017), Tokay444 (11-14-2017)
Old 11-14-2017, 10:41 AM   #8
mrg666
pessimistic skeptic
mrg666's Avatar
You assert that final drive swap is "great: without giving any reason. Then ask "what is your goal?" as if you care. What is "great"? How is "great"? How does that greatness fit to the "goals" you asked?
We are discussing a technical topic, I would expect a little more logic and reason in the discussion.
Old 11-14-2017, 10:44 AM   #9
gtengr
Drives: 2017 BRZ
An extra ~165 rpm at 80mph in 6th is negligible. Top speed is drag limited, so the gears will actually help in that department.
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
Old 11-14-2017, 11:05 AM   #10
Teseo
Drives: frs
Watch "BRZ 4.1 to 4.88 Final Drive Thoughts" on YouTube
I'd really want to do the swap but on my opinion price keep me away
The Following User Says Thank You to Teseo For This Useful Post:
chaoskaze (11-18-2017)
Old 11-14-2017, 11:23 AM   #11
nextcar
Have no idea why his labor cost was so high and they needed 3 days...
If you can do the labor the parts and oil are $600. The only tricky part is gear setup - and that is about $300 at a reputable shop. If you need full service (e.g. can not swap the differential yourself) that is another $300. All in should be about $1200 and one day.
Pull out
Old 11-14-2017, 11:27 AM   #12
fika84
fika84's Avatar
This is what i was thinking.. 4.10 --> 4.3 isn't that big of a change. I have 4.88 and wouldn't have it any other way for an NA car.
Best way to go is get a used diff carrier from an IS300, you can find some with an LSD already, or get a "fun" differential :p, by the gears and swap it at your own leisure taking your time with the shims. At least, this is what I did and it worked out great. I'm using the MFactory Mechanical LSD, had the innards WPC treated, fine tuned the preload and lock capacity and after the 3rd oil change I hardly have any chatter. That might be a little far from what you want to do, but DAMN is it fun!
Just my 2 cents.
fika84 is offline   Reply With Quote
Old 11-14-2017, 11:40 AM   #13
mrg666
pessimistic skeptic
mrg666's Avatar
Top speed is determined by the combination of power, drag, and gear ratio. Since drag is proportional to square of speed and power is a function of rpm, obviously, power will be balanced with drag force at a certain speed. If that limiting speed balancing power and drag is below the theoretical speed determined by the gear ratio and engine specs, the top speed will be limited by drag. Do you have the numbers and equations to back up your claim for our cars? It will not be as easy as saying 3000x4.1/4.33 -3000 ~ 165 rpm.
Old 11-14-2017, 11:54 AM   #14
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Even with a 4.88 swap the difference is not that much. You have faster acceleration in same gear, but you have to shift sooner and the longer final drive ratio catch up..
Here is a comparison:
[ame="https://www.youtube.com/watch?v=9X_jYLtoCMg"]BRZ 4.1 vs 4.88 Final Drive Comparison - YouTube[/ame]
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
brandonblt2 (06-14-2018), lantsalot (11-16-2017)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Lexus is300 diff swap M98 3.91 ogrowup Engine, Exhaust, Transmission 5 02-28-2017 10:45 AM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 02:59 PM
RR Diff swap Triumphrider Engine, Exhaust, Transmission 25 10-21-2014 08:34 PM
Diff swap help wootwoot Engine, Exhaust, Transmission 30 06-10-2013 11:05 AM
