Old 07-14-2017, 02:26 PM   #155
Freddy@PTUNING
Freddy@PTUNING's Avatar
Drives: Honda S2000 & Acura RSX Type-S
Send a message via AIM to Freddy@PTUNING
Originally Posted by 86Tony View Post
Does any other BOV fit this kit?
Yes if you wish to cut off the BOV flange and weld on your BOV flange of choice.
Freddy@PTUNING is offline   Reply With Quote
Old 10-24-2017, 12:33 PM   #156
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
Sorry for the delayed. Finally got around to updating the broken image links in initial post from photosucket over to imgurl. Thumbsup to Imgurl.com
Mrc@ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to Mrc@ptuning For This Useful Post:
CxG (01-22-2018), Teseo (10-24-2017)
Old 11-11-2017, 03:34 AM   #157
NLS8520
Drives: N/A
Touching base to see if/when you plan to adopt the new Garret G series turbo models. I understand the Garrett G25-660(G2567R), will supersede the GTX2867R gen 2?
NLS8520 is offline   Reply With Quote
The Following User Says Thank You to NLS8520 For This Useful Post:
Hicklinc (01-31-2018)
Old 11-13-2017, 10:56 AM   #158
Mrc@ptuning
Drives: S1000RR
We've had a few inquiries about the new G turbo since the SEMA show. The turbo looks very promising but we're not sure if there's going to be enough demand for it given the $2000 price tag vs the $1800 gtx2867R. If we get enough inquiries for this turbo with our kit, we'll pick one up for testing and make the necessary changes to accommodate this new turbo.
The Following User Says Thank You to Mrc@ptuning For This Useful Post:
Old 12-28-2017, 11:00 AM   #159
86Tony
Drives: 2015 AOZORA EDITION
I have the ptuning kit on my car, im looking to use the 350z CD009 trasmission swap is there any way you guys can make new brackets and piping to use?
86Tony is offline   Reply With Quote
Old 12-28-2017, 05:47 PM   #160
Mrc@ptuning
Drives: S1000RR
That's going to be a bit difficult without us actually having done the conversion and test fitting this transmission ourselves. Looks like something you're going to need a fabricator to custom fab the necessary components to make the kit work with the 350z tranny. Not sure how the 350z transmission is going to even fit inside the existing transmission tunnel without some modification to the sheetmetal/chassis itself since it's a relative large transmission compare to the 86.
Old 01-11-2018, 08:48 PM   #161
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
I've looked into this a good bit.
The CD009 swap has a fitting kit, and a lot of cutting for new mounts of the trans. It does fit - but its pretty tight. It would take some fabbing to get the PTuning kit to work due to the turbo placement and front-pipe.
A better idea (for this kit specifically) is to look into the Jack's Transmissions upgraded trans for the BRZ/FRS. Additionally, PAR makes straight-cut gears to open/swap in with the 4th gear thrust-load fix. Also, I believe Velox is making FT86 upgraded gears/trans parts.
I'm not sure how much these cost... but IIRC the CD009 swap being offered is ~ $4K or more.
SpectreRT is offline   Reply With Quote
The Following User Says Thank You to SpectreRT For This Useful Post:
CxG (01-12-2018)
Old 01-20-2018, 02:36 AM   #162
Mingo
Drives: 2015 BRZ Limited
@ptuning.
Although the GTX2871R has faster spool and the area under the torque curve is larger with a flatter torque table relative to the GTX3076R, I’m curious as to the EGT temp between the two. I prefer to have a lower EGT and bump up the boost. Your response would be greatly appreciated. Totally digging the kit.
Mingo is offline   Reply With Quote
Old 01-20-2018, 08:00 PM   #163
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Originally Posted by Mingo View Post
@ptuning.
I'm heading out to the track in February and I'll get some logs of EGT with my 2867. I already have loads of logs for the 3076 so I can get a comparison. IMO - 28xx series is a much better suited for this turbo kit as installation and maintenance is much easier with the smaller turbo. Not to mention many other benefits if you're running lower power like me.
rb6freak is offline   Reply With Quote
Old 01-28-2018, 02:19 AM   #164
Randoman5
What size tires are guys running with this setup? The dynos suggest this thing makes tons of torque. The dyno charts aren't dissimilar to this 991 GT3 RS, which comes with a 325/30 21! and has 61% of its weight over the rear wheels, not to mention a giant rear wing. Can you put the power down at all in corners?
http://www.dundonmotorsports.com/blo...y-surprise-you
Randoman5 is offline   Reply With Quote
Old 02-01-2018, 10:19 AM   #165
sam69
Drives: GT 86
Haven't read the whole thread but was wanting to know if this kit will fit RHD cars
sam69 is offline   Reply With Quote
Old 02-01-2018, 11:01 AM   #166
Freddy@PTUNING
No unfortunately it will not.
Old 02-02-2018, 03:10 AM   #167
sam69
Drives: GT 86
Would it be possible to modd it for RHD or would it be to much of a hassle do you think as I like the idea of low mount and keeping the weight towards the back ?
Old 02-06-2018, 10:32 AM   #168
Freddy@PTUNING
I guess anything is possible with the right amount of money
garrett, ptuning, tial, turbo, turbosmart
PTUNING Spec-SS Turbo System with GTX2867R option ptuning Forced Induction 52 06-11-2018 10:25 AM
PTUNING: FR-S/BRZ/GT86 Spec-SS Turbo System (Now Shipping) ptuning Forced Induction 151 09-23-2016 11:48 AM
PTUNING Equal-Length Competition Header RJasonKlein Engine, Exhaust, Bolt-Ons 5 07-07-2016 01:43 AM
PTUNING: 501WHP 377WTQ 20psi Stock Motor PTUNING Spec-SS GTX3076R Turbo System ptuning Forced Induction 47 06-16-2014 04:52 PM
