#71 |
Drives: Panda FR-S
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
#72 |
Drives: Panda FR-S
Vortech SC. I'm nearing 150k miles on the car now. 130k boosted. I think I have a vac leak. The car cuts power when I floor it. =P
| The Following User Says Thank You to Cal3000 For This Useful Post: | Astroboy (11-11-2017) |
#73 |
Drives: None
#74 | |
Fiebru
Drives: Scion FR-S and Integra Type R
Sorry for the late reply.
Current Cars:
2017 White Platinum Ford Fiesta ST 2013 Raven Scion FR-S 2012 Spruce Mica Toyota Tacoma TRD Off-Road 2000 Phoenix Yellow Acura Integra Type R |
#75 |
Drives: None
#76 |
Platinum Member
Drives: Toyota 86 Vortech SC
New car Mar 2013, Vortech SC Nov 2013 @ 23,000kms.
Now on 101,000kms, only DI injectors replaced and a few minor issues. Despite having done 51 track days, of which about 15 were competitive time attack events. I worked out that my car has been red-lined (say 7000rpm+) more that 12,000 times on racetracks alone. And some say the FA20 isn't reliable if boosted. I can assure you that it's not made of glass ![]() My opinion is that it's relative to bhp-greed. If you want big hp, it'll bite you. If you're content with up to 250whp, I reckon you'll have a long and enjoyable FA20 ![]() But YMMV
| The Following 12 Users Say Thank You to Fish Eagle For This Useful Post: |
#77 |
Drives: Toyota GTS 86
240 rear wheel Kw - say 400 flywheel horsepower - on a water to air intercooled turbo using e85. Engine had 60,000km before being boosted and had 4 bent rods 7,000km later with only some spirited driving and one track day I used to shakedown the turbo install.
Built engine being done now. |
#78 | |
Drives: frs
#79 |
Platinum Member
I was a lot quicker than him in the corners. About the same with power.
He was on 255 road tyres. I was on 225 semis and I had a lot more grip. The photo was accelerating out of the left turn onto the pit straight. I cut inside him coming out the turn, and the photographer just happened to be there. Must have sounded awesome too, because for the track, both the Z and my car run open exhaust, and they're both very loud.
| The Following User Says Thank You to Fish Eagle For This Useful Post: | Teseo (06-06-2018) |
#80 |
Drives: Panda FR-S
At 160k miles now and throwing 3 codes in relation to timing chain and faulty cam phasing. lol
It's worn down now.
| The Following User Says Thank You to Cal3000 For This Useful Post: | sroby (07-26-2020) |
#81 |
Drives: frs
| The Following 5 Users Say Thank You to Teseo For This Useful Post: | Cal3000 (06-11-2018), solidsnake11 (06-29-2020), sroby (07-26-2020), Turbo (06-28-2018), weederr33 (06-10-2018) |
#82 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
We need a hat that says something along the lines of, "make the boxer great again"
| The Following 3 Users Say Thank You to weederr33 For This Useful Post: |
#83 |
Drives: 2017 Subaru BRZ
| The Following User Says Thank You to mrloko For This Useful Post: | solidsnake11 (06-29-2020) |
#84 | |
Drives: FR-S Turbo
Are you sure those numbers are in PSI and not measured in inches of HG? If they're inHG you're running ~8psi daily and 10.5psi peak which is far more realistic. Unless, of course, you are running a fully built engine. |
| Boosted's BRZ | Boosted | Member's Car Journals | 41 | 11-05-2018 09:32 PM |
| Alpine's Boosted BRZ Thread | alpine | Member's Car Journals | 262 | 02-04-2015 09:31 PM |
| The Boosted Exhaust Thread | The Racers Line | Forced Induction | 49 | 06-05-2014 01:13 AM |
| cj's WRB boosted thread | cjsporl1996 | Member's Car Journals | 3 | 05-12-2014 11:47 AM |
| Boosted BRZ | mike the snake | Member's Car Journals | 3 | 12-28-2013 11:11 AM |
