Old 11-08-2017, 09:54 PM   #29
Xa9128
Sorry to revive an old thread but did anyone get this figured out? Mine just started doing this. It seems to go away after it warms up and I think may go away when the clutch is depressed (just started today so I haven't had much time to test it all out). I've had the car for about 2 yrs and this is the first time I'm hearing it.
Xa9128 is offline   Reply With Quote
Old 11-08-2017, 10:51 PM   #30
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
your manual is acting like the op's auto problems?
HKz is offline   Reply With Quote
Old 11-08-2017, 11:22 PM   #31
IIRC it turned out to be the throwout bearing. I never would've guessed it.
Old 11-09-2017, 08:09 AM   #32
Xa9128
More like this
Originally Posted by DandoX View Post
I'm at 68k and I just started hearing this sound in my manual FRS. Only when cold, after driving for about 10 mins the sound goes away completely. I never heard this sound until now and I've had the car since it was new. This sound to me is not normal and indicates something is up. I suspect it is low trans fluid, that's my only thought. I'm gonna bring it by a shop to check it out. I'll update if we figure out what the issue is.
It shifts just fine so I don't think anything is up with the tranny/clutch but the sound changes when the clutch is depressed.
So after listening to it more closely it is coming from the engine area. I don't hear it when not under load after it warms up. I found a video that has the exact same noise, could anyone take a look and let me know what they think that sound may be?
Video example:
In the comments it is mentioned this is due to a bad alternator diode can anyone with experience confirm or refute this?
It sounds pretty similar to this which sounds like it may different from the OP's problem so I may keep searching or start a new thread. I took a couple vids I can upload after I get off work the should help get to the bottom of it.
Old 11-09-2017, 08:39 AM   #33
More like this
Pretty much guarantee it is the TOB. I could play a little song with mine just by varying the pressure on the clutch. Always went away after it warmed up.
DaBoBo21 (11-09-2017)
Old 11-09-2017, 10:28 AM   #34
Xa9128
After looking up vids of throwout bearing noise, I'd say you nailed man. I'll check threw the diy and maintenance sections and see how simple/complicated the job is. Hopefully it's something I can do myself. Thanks for quick replies guys.
Old 11-09-2017, 10:35 AM   #35
It difficult if you can get the car up in the air and have some basic tools.
Old 11-09-2017, 11:11 AM   #36
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
More like this
Hey yeah it sounds like the TOB. In my case I can confirm it was the TOB, check the thread I started for my issue: http://www.ft86club.com/forums/showthread.php?t=121318
DandoX is offline   Reply With Quote
Old 11-09-2017, 12:58 PM   #37
Xa9128
I've got tools but no jack that will fit under so I guess it's a no go.
Thanks. Do you remember how much it ran you to get the TOB replaced?
I'll still probably post the vid when I get off but it sounds like you guys have already figured it out.
Old 11-09-2017, 01:04 PM   #38
There is a service bulletin for it so if in warranty it should not cost anything. If out of warranty and you talk nice to the dealer they may still do it.
http://www.ft86club.com/forums/showthread.php?t=117440
Old 11-09-2017, 02:17 PM   #39
DandoX
Senior gif poster
DandoX's Avatar
Yes but keep in mind I'm in Northern California (Bay Area) so prices may be a litte different. Also I had a trusted speciality shop theracersline do the repair who does great work for reasonable prices.
TOB full cost was 460 I think (+labor). I got a new clutch kit installed so I paid more than that. I think my total was 650ish. Honestly I could be off by $100 on both prices.
Old 11-09-2017, 02:51 PM   #40
The bearing should be around $50 for the part.
Old 11-09-2017, 03:00 PM   #41
DandoX
Senior gif poster
DandoX's Avatar
Right, I didn't word it right. The total TOB job was around 460 including labor of If I remember correctly. I remember him telling me the charge for the actual TOB was around 30 to 40ish.
Also note that the 2017 86/BRZ got an updated TOB (same part but with updated grease compound or something). The new 2017 version is rated to be slightly more durable and last a little longer. So when buying the part or going to a shop be sure you get the 2017 version of the TOB for that updated grease.
The Following User Says Thank You to DandoX For This Useful Post:
Tcoat (11-09-2017)
Old 11-09-2017, 03:02 PM   #42
The updated part number is on the TSB that I linked earlier.
DandoX (11-09-2017)
Transmission noise at startup Toxicmilk45 Issues | Warranty | Recalls / TSB 2 01-28-2014 11:03 AM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 03:22 PM
transmission noise when reaching 23-25m/h Mokiki Issues | Warranty | Recalls / TSB 7 05-09-2013 09:13 PM
White line transmission brace noise Mathewgzlz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 01-07-2013 07:21 AM
transmission noise (when going to downshift) Hotlava86 Issues | Warranty | Recalls / TSB 5 09-03-2012 10:04 PM
