Old 11-04-2017, 12:54 PM   #15
EigenGuy
Originally Posted by Astroboy View Post
I'm planning on swapping mine out because of the p0018 issue I am having. Also, if I had a custom tune using the ecutek, will I need to recalibrate the tune, or can I just program the tune righ back in?
Sorry to bring up an old issue. I am working through P0018 issues myself on my 2013. With the TSB I've narrowed it to the ECU. My plan is to buy a replacement (should I get new or used?) and somehow reflash the Jackson Racing CARB legal tune. Has anyone had any luck with ECUtek re-licensing different ECMs?
EigenGuy is offline   Reply With Quote
Old 02-18-2019, 07:24 PM   #16
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
I'm curious, how did this work out for you? I also have a 2013 BRZ and am not familiar with this recall / did not take it into the dealer so maybe I need to do it myself.
slizoth is offline   Reply With Quote
Old 03-22-2019, 02:59 AM   #17
Chasen
Drives: toyota camry
it is very nice write up,i want to try it if my 86 get ecu problme
Chasen is offline   Reply With Quote
Old 08-10-2019, 01:39 AM   #18
DenisSlob4
I have a 2013 BRZ limited. I can't replace with ecu from any other year, correct? If I do replace it with the correct ecu, will my key/button still work or needs to be reprogrammed?
DenisSlob4 is offline   Reply With Quote
Old 08-11-2019, 11:13 PM   #19
steve99
Drives: FT86
Yes you will need to resync ecu to get car to start its easy tgough
http://www.ft86club.com/forums/showthread.php?t=102810
Old 07-17-2020, 02:43 PM   #20
Flukester
Flukester's Avatar
Drives: 2019 BRZ - Raiu
(Reviving this old thread).
Thank you very much for this write up.
I obtained a spare (used) ECU and wanted to test it, so that I would not have a bad surprise if I ever really needed to use it. My car is a 2019 BRZ 6MT and I swapped in a used ECU that came from a 2017 BRZ 6MT.
All the pictures and explanations of the original post were very useful. Also as noted by Jason@Nameless in one of the replies above, the BRZ does have an additional module with 3 connectors and a separate bracket (2 small bolts, 10mm heads as well) which needs to be removed in order to access and remove the engine ECU.
I disconnected the car battery before starting this whole procedure. Just as a warning to others, if you have opened the car windows before attempting this whole procedure, the additional module (with 3 connectors) mentioned above controls a lot of functions, including the electric windows. So if it starts to rain, you have to reconnect that module (even if it's hanging by its cables and not properly installed), before reconnecting the car's battery and being able to close the windows. Don't ask me how I know...
I then proceeded with resyncing the security modules, as described by steve99 in his thread (https://www.ft86club.com/forums/showthread.php?t=102810) and that also worked properly once I properly looped the two pins in the OBD2 connector. See that thread for details.
Thanks everyone!
Flukester
Flukester is offline   Reply With Quote
The Following User Says Thank You to Flukester For This Useful Post:
radroach (07-19-2020)
Old 02-04-2023, 03:40 PM   #21
znelbok
Drives: Grand Vitara
Hi guys
I am used to the older Toyota ECU's where the security is in the ECU. If I swap out the ECU do I need a key from the donor car as well to work with the replacement ECU or will the original wireless fob still work (that I suppose is the assumption that the security is a separate ECU in the car)
znelbok is offline   Reply With Quote
Old 02-05-2023, 01:19 AM   #22
Originally Posted by znelbok View Post
Hi guys
A few posts above...
Yes you will need to resync ecu to get car to start its easy though
Badge Removal DetroitJake Cosmetic Modification (Interior/Exterior/Lighting) 5 10-01-2013 02:35 PM
Dent Removal 7thgear Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 10-23-2012 06:38 PM
snorkel removal Bu-Tang Engine, Exhaust, Transmission 4 09-01-2012 11:40 PM
headlining removal encity5 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-21-2012 07:06 PM
Clear bra removal. Any one try it? digital_assassin Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 07-13-2012 02:30 PM
