Old 10-31-2017, 05:00 PM   #15
Originally Posted by paiceyfan View Post
I think I saw a headline that Subaru subwoofers could possibly cause a fire...not sure if there is a recall...you might want to look into that before purchase.
Nice catch but a totally different sub and cabinet.
Nothing to worry about.
THE Subaru WRX is being recalled in Australia because the subwoofer speaker fitted in the boot might spark a fire.
While loud sound systems are a common accessory fitted by WRX owners, the recall affects subwoofers installed by Subaru.
The recall of more than 4000 WRX sedans (2015 models) was triggered after one car caught fire in Tasmania.
The recalls.gov.au website says there is a “risk of fire if the subwoofer speaker overheats”.
A statement from Subaru says: “the recall is due to the possibility of an electrical short circuit that may cause the subwoofer speaker to overheat and risk a fire”.
A wire to the subwoofer, which is located in the boot, may be moved out of its normal position and touch the metal frame of the subwoofer, “resulting in an intermittent short that could create a continuous electrical current, overheating the subwoofer,” says Subaru.
Owners of affected vehicles will be contacted by Subaru Australia, advising them of the recall — or they can call 1300 550 994 to check if their car is on the list.
Subaru says it will fit a “spacer clip” to prevent the wire moving from its normal position.
Old 10-31-2017, 05:08 PM   #16
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
Ahhh...thanks for getting the details, Tcoat!
Sent from my Moto G (5) Plus using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 10-31-2017, 05:11 PM   #17
I was curious since the wife's new Impreza has a sub.
Old 11-15-2017, 12:09 AM   #18
Joeyb860
Joeyb860's Avatar
Drives: 2017 860 SPRINTEK
Does anyone know if the Subaru sub for the BRZ will work in the Toyota 2017 86 860?
Joeyb860 is offline   Reply With Quote
Old 11-16-2017, 10:41 AM   #19
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Why on earth would you want it to? I am sure your local audio place can install a much better sub and amp for less than the cost of that Subaru kicker sub.
why? is offline   Reply With Quote
Old 11-16-2017, 11:05 AM   #20
Yes
Old 11-16-2017, 02:26 PM   #21
Joeyb860
Joeyb860's Avatar
Thanks.
Old 11-16-2017, 11:41 PM   #22
phaqew
phaqew's Avatar
Drives: 2017 Subaru BRZ Automatic
I have a 2017 BRZ w optional subwoofer. The problem with it is theres no actual volume control for the sub other than the eq, which cuts too much bass in the cabin as well to be effective. the sub is simply too loud with no way to attenuate the volume. I wish there was a reasonable upgrade for this head unit. crutchfield told me theres nothing available in the US that will fit it without major mods.
phaqew is offline   Reply With Quote
Old 11-17-2017, 03:05 AM   #23
~el~jefe~
Drives: 2019 MX-5 RF
my car did not come with a sub in trunk until I met one and demanded they get in the trunk and stay there.
~el~jefe~ is offline   Reply With Quote
Old 11-17-2017, 03:54 AM   #24
johan
Drives: '14 981CS, '99 NB1
If it is tied into the rear speakers as someone else said - could you just fade the sound forward to lower the sub level? It's not like the rear speakers do anything anyways.
johan is offline   Reply With Quote
Old 11-17-2017, 12:30 PM   #25
ncted
Drives: 2017 BRZ Limited
If you get the Canadian Dash Trim: https://parts.subaru.com/p/Subaru__B...6077CA200.html , you can put any Double DIN headunit that will fit the '17 Toyota 86.
It sucks that you have to pay extra to replace the dash trim, but it is what it is.
ncted is offline   Reply With Quote
2018 brz, factory stereo, oem audio, subwoofer
FS: Scion Frs Factory Car Stereo $50 NorCal_Guy Interior Parts (Incl. Lighting) 9 03-27-2015 11:44 PM
Factory Subwoofer Installed go2brz BRZ First-Gen (2012+) — General Topics 0 07-19-2013 10:14 PM
Any one hear about the factory subwoofer yet? theredtape Electronics | Audio | NAV | Infotainment 38 03-28-2013 12:26 PM
BRZ Factory Stereo Crossovers? Skippman Electronics | Audio | NAV | Infotainment 0 03-06-2013 06:33 PM
Does anyone have the factory upgraded stereo? redwing634 Electronics | Audio | NAV | Infotainment 8 08-22-2012 02:38 PM
