Old 10-30-2017, 07:52 PM   #953
Low&Slow
Low&Slow's Avatar
Drives: 10 Series #845
Anybody know if a 3 bar sensor is imperative if the power goal is around 300whp on 91 Octane? ( I know I’d probably be around 285-295whp realistically with 91.) ����
Low&Slow is offline   Reply With Quote
Old 10-30-2017, 07:55 PM   #954
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
If you're planning on surpassing 14 or so psi of boost, then yeah. Otherwise, it's hardly more expensive, if at all, to get a 3 bar instead of a 2 bar sensor.
Rybot is offline   Reply With Quote
Old 10-30-2017, 08:11 PM   #955
Low&Slow
Low&Slow's Avatar
Probably won’t run more than 10psi for the meantime, thanks!
Old 10-30-2017, 08:55 PM   #956
Rybot
Rybot's Avatar
Keep in mind, you still need to get at least a 2 bar sensor if you're boosted.
Though I'd REALLY recommend just getting a 3 or 4 bar to be done with it.
Up to you.
Old 11-01-2017, 12:39 PM   #957
nelsmar
Just to clarify... I have ran ~18PSI on stock injectors on 91 octane on a 2871 with a 3" exhaust. (Different kit but it should give you an idea). I want to say i was at 95% duty cycle on the stock injectors. IIRC the car did have an aftermarket pump. But for pump gas you do NOT need to swap your injectors. And there are absolutely no benefits. There are downsides such as having incorrect low pulse width calibration of your after market injectors giving poor transition into port injection mode. Always swap the least parts possible... If you are not planning on running E85 there is no reason to go further.
Also 300 WHP on 91 octane can be done but its really pushing the envelope of 91 octane IMO. 93 makes it easier. My personal kit could do it with my large turbine and a free flowing exhaust. But I also have a massive intercooler and my IAT temps are barely above ambient. Also this heavily depends on the type of dyno you are using. On a dyno jet sure you could probably still hover around there with a GTX30R and a 3" catless exhaust.
My flickr - Canibeat
Local magazine scout
Old 11-01-2017, 12:55 PM   #958
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
My car is an early 2013. Bought it used with 10k miles, currently has 72k without seeing a dealership. As far as I know, it is the original ecu version. (I've had low idle dip forever and the DRLs flicker below a certain rpm).
Would it be wise to bring my car into the dealer for them to flash the ecu to the latest revision before committing to a F/I kit while it is essentially (motor wise) 100% stock?
Or would an EcuTek tune do that for me when it gets tuned?
Jesse36m3 is offline   Reply With Quote
Old 11-01-2017, 07:13 PM   #959
choiboie
Drives: 2013 Fr-S UltraMarine
Depends when your planning to boost. If it’s really soon then I wouldn’t see any point in taking it into the dealer and flashing it twice. Whoever your tuner is will tweak everything out for you.
choiboie is offline   Reply With Quote
Old 11-08-2017, 10:15 PM   #960
Captain
Drives: 15' Raven FR-S
Anyone with dyno sheets care to share what kind of power you're making and mods with the kit?
Captain is offline   Reply With Quote
Old 11-08-2017, 10:40 PM   #961
AllSickLike
Drives: iso white BRZ
anygood v2 footage ?
AllSickLike is offline   Reply With Quote
Old 11-13-2017, 10:27 PM   #962
Jesse36m3
Jesse36m3's Avatar
After 4 years and 72k miles, it's happening. Ordered my JDL kit on Friday and paid today.
I am beyond excited and can't wait to put everything together .. too bad the winter is coming up. Oh well; gives me time to get the kit together without rushing.
ended up going with the gtx2867r, no-cut intercooler, 2.5" recirc wg, oil pan, bronze thermal coating, catted/res front pipe/over pipe combo, mxp comp RS exhaust and a south bend daily clutch with Exedy flywheel (oem).
The guys over at 86Speed seriously hooked it up .. give them a call.
The Following User Says Thank You to Jesse36m3 For This Useful Post:
choiboie (11-14-2017)
Old 11-13-2017, 10:33 PM   #963
Votlon
Votlon's Avatar
Drives: Scion FRS || Ducati 899
Anyone running precision 48mm, wondering the manufacturing quality
Votlon is offline   Reply With Quote
The Following User Says Thank You to Votlon For This Useful Post:
Old 11-14-2017, 12:46 AM   #964
choiboie
I’m running the base turbo from pte believe it’s the 4854
Old 11-14-2017, 10:13 PM   #965
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Getting some baseline GTX2860R Gen2 numbers on a Mustang Dyno.
[ame="https://www.youtube.com/watch?v=TsevkF0EOts"]JDL Turbo Subaru BRZ baseline dyno - YouTube[/ame]
304whp / 255wtq on just the 9.4psi spring and E67 in the tank.
Pretty much what I expected! This turbo isn't even trying. EBCS and more boost soon!
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
Irace86.2.0 (11-23-2017), Trust86 (11-19-2017)
Old 11-28-2017, 12:57 PM   #966
nelsmar
A while back I did a pull to see where my base map landed so that I could make sure I wasn't over a desired power level until I swapped my forged block back in. I was doing burn outs on the dyno as my diffuser was hitting the dyno platform and i wasn't able to tie down the car easily. As I was just doing a quick pull I never removed the diffuser. Main power mods are as follows:
Stock block
JDL EL Turbo Kit with GTX3071 .82 Tial housing (medium sized). Turbine has slight damage on the exhaust blades.
JDL turbo kit, downpipe, and tial housing were ceramic coated
JDL recirculated wastegate
JDL fabricated intercooler (i think it was like a 700WHP core, not the standard intercooler).
JDL 3" Intake with 6" velocity stack
JDL 3" over pipe
JDL 3" resonated front pipe
Broken aluminum 3" exhaust (i think?)
ACT 6 puck with standard plate and lightest flywheel option
FIC 1100 injectors
China pump (dont ask...)
Fuel was ~80% ethanol.
The thick line was iirc ~14PSI. The one below i dont remember and i only plotted it to show that i was in fact revving up. IIRC i went to 7800RPM but i lost grip on both pulls. The thick line i lost tracking much earlier so I don't know what power it would have made. Probably 400-425HP range. Mind you this is also not a dialed in tune. My fuel trims were not ideal and my closed loop fueling in boost was aggressive to compensate for my laziness.
The dashed line is a factory car with factory tune.
Baseline on this dyno for 6MT is typically 130-135HP.
Of all the kits I have tuned I would have to say the JDL has been one of, if not the most power I have made per PSI. Mine however is not a standard kit so your mileage may vary.
The Following User Says Thank You to nelsmar For This Useful Post:
ShadowReaper (11-28-2017)
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
